Results 1 to 5 of 5
    Mar 2013
    Canada
    Default RT MID SIDE PANEL REMOVAL
    Good Afternoon All,
    Went for a short ride with my RT 2013 yesterday, when I noticed a large crack 1-1/2" long, and several other small cracks, at the rear, of the left of the Mid side panel, where the side storage compartment overlaps.
    Question 1 : Can I remove
    the side storage compartment, in order to fix the panel from behind without removing the panel.
    or
    Question 2 : Can I remove the Mid Side panel, without removing the mirror and top side panel.
    Thanks guys
    Dom
    Quote Originally Posted by poordom View Post
    Good Afternoon All,
    or
    Thanks guys
    Dom
    I'm going to say no and no. Almost everything starts with removing the mirrors! It's not that big of a deal, really. What you need to do first, IMO, is try to figure out why the panel is cracked. Something is haywire somewhere.
    To take the side compartment off you have to remove the entire rear module.
    Active Member Bob L's Avatar
    Oct 2014
    Massachusetts
    Once you have disassembled the body panels once it really is not difficult... and I am not a mechanic by any means! Here is a video that Shawn Smoak did:
    Good luck.
    Bob L.
    Worcester County Massachusetts
    www.rk-mass2.org
    Mar 2013
    Canada
    Default REPAIRING CRACKED SIDE PANEL
    Quote Originally Posted by Bob L View Post
    Good luck.
    Thanks for the video, really helped.
    Now that I have removed the panel, I need to fix it, any suggestions.
    Dom
    Jan 2016
    PA
    That tupperware material doesn't lend itself very well to repair.
    aluminum held with pop rivets on inside and pop rivets ground down is my only thought.
    Probably others here will have better ideas.
