Results 1 to 18 of 18
    Visionary Member
    Jul 2011
    East Tennessee
    Question UGH! Front tires
    My wife has 2010 RT-S and it's time for new front tires, the ones she is currently running are showing uneven wear on the outer edge....What is a good replacement tire instead of factory tires??? She only has 9K on these...We replaced her rear tire last fall...Is there a better choice with better longevity than the factory tires??
    Oct 2013
    Eden Prairie, MN
    Default tires
    Check the sponsor vendor on this site for Vee Rubber.
    Dec 2014
    Lee's Summit, MO
    If you do an advanced search, you will have more reading and information than you ever thought possible.
    Jun 2010
    Las Vegas
    If you have uneven wear on your front tires you should consider having a laser alignment. This will save you from having that issue on your new tires. With the 14" wheels you have several options available you just have to choose what is most important to you. Longevity, handling, cost...
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
    RE: Front tires. Sounds like a possible alignment or tire pressure issue. Even the OEM Kenda's should get about 20K. Uneven wear is a pretty good sign of alignment issues.
    Bryant, Arkansas
    6 year old tires should be replaced anyway you look at it, get a Lazer Alignment for sure.
    Cruzr Joe
    Very Active Member jtoro1's Avatar
    Feb 2013
    port st lucie fl
    Default Tires
    Tires will go over 20k miles you need a laser alignment you can get car tires for you bike online
    Very Active Member Don in E Texas's Avatar
    Feb 2009
    Gilmer, TX
    Default I agree with others..
    ...get the front end laser aligned - then new front tires. I don't remember members having negative comments on factory front tires - but there are other choices out there.
    Don
    Did own: 2008, Red, SE5 - and 2010, Black, RT-S Premiere Edition Number 670
    Now Own: 2014 Black RT-S SE6
    Visionary Member
    Jul 2011
    East Tennessee
    OK Who does laser alignments??? It's definitely an alignment issue.....Also, as for new tires looking for longevity/wet weather as my wife doesn't ride that much....
    minnesota
    I went with Bridgestone Potenza's. The factory front tires are ok at best. I felt a noticeable improvement in handling with the four ply tires. My fronts had a lot of thread left when I changed them, but like Joe said,I wouldn't run tires that old on a motorcycle or a Spyder.
    Houston
    Agree with the others. You need an alignment. Here is a laser alignment dealer locator:
    http://spydercomfort.com/dealers.htm
    For the 14 inch front tires, we recommend and install the Bridgestone Potenza tires in the stock size. There are not many good name brand tires in 14 inch sizes any more.
    Blue Flame Spyder F3-S
    2015 F3S , Blue Flame
    Very Active Member AeroPilot's Avatar
    Nov 2012
    Pueblo Colorado
    Default Alignment first, then find some Kumhos or maybe even some Michelin Defenders..
    Quote Originally Posted by joe schmoe View Post
    When we had our 2011 had some uneven wear which an alignment cured, but the last change went with Michelin Defenders in a 14" size with large grooves, and rolled and wore exceptionally well. Had over 30 K miles on them and still great tread when we traded.
    2015 RT , OEM Black Gloss
    Visionary Member
    Jul 2011
    East Tennessee
    Quote Originally Posted by AeroPilot View Post
    Which tire di you go with??? Michelin has 1000's
    Default As to who....
    check post #4....Joe and Ann from Squared away are the best and travel around the country helping folks out. check their schedule they may be coming your way sometime soon.....
    Nov 2012
    North Las Vegas, NV
    I am running 185/60/14's from General and they fit fine. You can even get Altimax rt-43's in that size.
    2016 F3 Limited
    2019 Ryker Rally
    2014 Suzuki V Strom 650
    2020 CSC TT 250
    Nov 2012
    Pueblo Colorado
    Default Michelin 175/65-14 on the 2011 RT
    The smallest 14 inch tire they have is 175/65-14...........Personally I'd look at the Kumho PS-31..............Mike
    Like Mike said, it was the closest size, and fit fine and rolled SMOOTH..... On our 2015 we just put on new Kumho Solus KH16's. Balanced up better than the OEM Kendas and rolling smooth so far. Only have a couple thousand miles on them so far, but liking the ride
    May 2013
    Indiana
    That should be:
    KING
    JOE
    KNOWS
    2021 Marsala Red Metallic RT Limited
