Page 1 of 4 1234 LastLast
Results 1 to 25 of 76
    Jun 2015
    AZ
    Default Things you want BRP to make standard on Spyders.
    1 bette sway bar
    2 blue tooth stero with USB port to play my music
    3 usb port for charging phones or gps
    4 speed ometer to be accurate
    5 clock that does not keep gaing time. ( $ 5. 00 watches are accurate )
    6 fuel door on seat
    Kenn
    Linden, CA
    As nice as that all sounds I would not
    hold your breath waiting for that to
    happen
    Quote Originally Posted by kbwitt View Post
    1 bette sway bar
    6 fuel door on seat
    Kenn
    Jun 2010
    Las Vegas
    Valve stem in an accessible place on the rear tire
    Tire pressure monitoring system
    Distance to empty readout
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
    Nov 2012
    North Las Vegas, NV
    Single sided swing arm so rear tire can be removed easier, like a slingshot.
    2016 F3 Limited
    2019 Ryker Rally
    2014 Suzuki V Strom 650
    2020 CSC TT 250
    Jul 2011
    Mitchell, Ontario, Canada
    2016 already have a usb music input.
    I don't care how accurate the clock is.
    I don't want a fuel door
    Active Member Jheck's Avatar
    Jun 2015
    sherburne, ny
    A D.E.S.S. System that works! Each and every time. This would make me more than happy.
    Active Member kml354's Avatar
    Nov 2009
    Oviedo, Florida
    Default wants
    Maybe a chrome plated kick stand would look nice.
    2015 RT-S SE Silver/Black
    Bryant, Arkansas
    Actually they can delete the clock.
    Cruzr Joe
    Bryant, Arkansas
    1 bette sway bar
    6 fuel door on seat
    Kenn
    How about a spell checker??
    Cruzr Joe
    Bryant, Arkansas
    Quote Originally Posted by kml354 View Post
    On each side
    Cruzr Joe
    Linden, CA
    Default Not just yes...
    But
    HELL YES
    how about SHAFT DRIVE like a
    GoldWing or BMW
    Sep 2012
    Junction City, KS, USA
    But
    HELL YES
    GoldWing or BMW
    Very Active Member GOZFST's Avatar
    Oct 2014
    SD &AZ
    A realistic speedometer that doesn't go to 200 mph.
    Bob S
    Jan 2016
    PA
    GPS that feeds video to the speedo screen
    What else is on your list: that was too easy!!
    (Back to Business...)
    Yeah... I'd like to see the rear valve stem repositioned.
    Having the GPS built into a larger center screen would be cool...
    The clock and thermometer are so small that I can't see them; they're not an issue for me.
    How about this:
    The top trunk and saddlebags are not well-designed.
    Make the saddlebags a bit wider, and about two inches longer (front to rear)
    The top trunk should also be extended rearward by the same amount...
    ...or at least moved rearward, so that some more rider/passenger space can be opened-up for use.
    Sep 2012
    Turn signal indicators that show up better on the panel.
    Sep 2012
    Louisburg, Kansas
    Default 3rd brake light should be standard
    The third brake light should be standard.
    A little higher ground clearance would be nice.
    Those are my two cents worth!
    2015 RT-Limited SE6-TricLED Fender LED's (Red and Amber), 3rd LED Brake Light/Tail Light, ISCI Handbrake with black small hands handle,Spyderpops Rock Guard. ,Can-Am Adjustable Wing Vents, Bumpskid, Bajaron's Sway-Bar with metal Heim Joints. Elkas Stage 2 Plus., TricLED Wide-VU Mirrors, TricLED Jumper Port, Laser Aligned!
    Apr 2014
    Beloit Kansas
    How about starting like a
    real vehicle, meaning after
    turning key ?
    Quote Originally Posted by Elembytes View Post
    I like the idea of more brakelights...
    Jun 2013
    queens ny
    optional hand brake
    Jul 2010
    Las Vegas, NV
    Default Standard items on a premium motorcycle
    TPMS
    heated grips and seat
    fully adjustable suspension, front and rear
    more power
    third brake light
    more luggage capacity with saddlebags that don't break
    turn signal indicators in mirrors
    LED headlights
    custom build program: order with options, colors.
    Turbo or Supercharger option
    Joe Meyer
    Very Active Member fireplug98's Avatar
    Sep 2011
    Arden Hills, MN
    Hey Everyone !!!
    I'd like to see better OEM speakers all around.
    Get ride of the analog gauges and add USB on one side and 12v plug on other side.
    :-) I would love to see BRP offer a 1300 - 1500 twin.
    I love the idea of a little bigger side bags and top box, also, I like the gas door idea.
    Tommy J.
    F3L SE5 Black -- F4 windshield w/wings, Reggie LED headlights, driving lights & Cyclops LED, Ultimate seat, Fox shocks, BajaRon swaybar, Lamont highway centerline pegs & 3rd peg, Lamont belt tensioner, K&N air filter, Baker air wings & cup holder, CanAm hitch.
    2019 F3L , Black
    Vermont
    Painted dashboard (See my posts for a picture).
    Deanna
    Gremlin Bell
    SpyderPops Missing Guard Belt
    Ultimate F3 Floorboards
    Sway Bar with Links
    Rolo Laser Alignment
    Half Cover
    Show chrome Trunk Shock
    Quote Originally Posted by cptjam View Post
    TPMS
    more power
    third brake light
    LED headlights
    Speaking of more power: has anyone heard anything more about the F3-Turbo?
    Wouldn't the "Custom Build" program, render our Farkling episodes pointless??
    Otherwise; I've already added the LED lighting, extra turnsignal indicators and brakelights.
