Results 1 to 16 of 16
    Active Member Lobo's Avatar
    May 2016
    Murrels Inlet, South Carolina
    Default Passenger speakers
    Just purchased a 2012 RT Audio and Convenience. I thought there were passenger speakers, but no sound. How can I find out?
    Default 2012 A & C
    My X - GF had that model and it had rear speakers.......Check your preferences screen and see if they are turned up loud enough so you can hear then........Although the sound won't impress you, the BRP - RSI 4" speakers break up sooner than the fronts .......IMHO........that's why I changed to the JBL - 2 OHM models................and they will ROCK YOU.........................Mike
    Very Active Member GOZFST's Avatar
    Oct 2014
    SD &AZ
    We got a new to us 2012 RT A&C last fall, you can barely hear the rear speakers, I've tried changing the fader and balance and it makes very little difference. Must just be one of those things, I couldn't hear it anyways unless I was stopped so it's not an issue for me.
    Bob S
    Oct 2011
    Jacksonville,Ar
    Go to the setting that will let you put more sound to the rear. I run 2 plus to the rear.
    15 rt , yes Black
    May 2016
    Default Passenger speakers don't work.
    Still no sound. How do I get inside the rear speaker housing?
    Default REAR SPEAKERS
    Quote Originally Posted by edcourtney View Post
    been there done that ( a few times )........The entire side housing must come off, and to do that a lot of the rear has to be re-moved first.................WHY do you want to do this ....maybe I can help before you do it .......Mike
    May 2013
    Stanton, ca
    The AC model did not come with rear speakers. That is an add on.
    If you want to put them in yourself you will need the speakers AND the wiring. There is a kit from BRP.
    http://store.spyder.brp.com/product/...Audio_Controls
    I did a video when I upgraded my Speakers and show you how to get at them in the front and rear.
    May 2016
    Just want to get sound out of the rear speakers. Suggestions?!
    Apparently Her A & C had the speakers as an ADD-ON......so as Bob said they aren't standard........Mike
    Very Active Member cyclelover63's Avatar
    Mar 2011
    Big Sandy, TN
    Thanks for the hard work with the video!!
    Quote Originally Posted by finless View Post
    Thanks for the video!
    (I just ordered speakers for my RT, and now I have a better idea of what I'm up against!
    The USPS has delivered me a HUGE project...
    I might just chicken-put, and call the dealer!
    May 2013
    Stanton, ca
    Turn about is fare play
    Once I got the coffee wiped-up; this is funny as all get-out!!
    Apr 2016
    Florida
    Default Rear speakers RT S 2015
    Ok I must be missing something because I am unable to get any sound out of the rear speakers. Does anyone have a suggestion?
    Yup!
    Start the bike, but leave it in neutral, with the parking brake on...
    Hit the "mode" button, until you see the personal preferences screen.
    Scroll down (down button), until you see "audio"
    Hit the "right" button
    Scroll down to the "fader", then hit "right" again.
    This should allow you to adjust the front to rear balance.
