Results 1 to 25 of 34
    Feb 2016
    California
    Default What is your highway "sweet spot" speed
    I've only had my 2016 Spyder RTS for 2 weeks and just did our first long ride to Laughlin River Run this week. Still doing a little bit of adjustment from 2 wheels but I love the Spyder. We hit lots of weather, wind, rain, etc. I got push around a little in the high winds but not bad. My husband likes to travel at 75 to 80 mph. I found that around 75 I had some shake going on. I have the baja ron sway bar but have not done the laser alignment yet (have to locate somewhere to do it). So what highway speeds do you travel at comfortably?
    Default Well....
    Freeways are not my thing but a must so I like to hurry on at about 85 traffic allowing. ..the Jag loves it 6000 rpm's is sweet...
    Feb 2012
    Spring City,Utah
    I like 70 when the traffic will allow. On my 2012 RT that corresponds to 5000 in 5th. I have ridden for miles at 80 on some of the freeways in UT and was just fine.
    Happy TRAils/NSD
    Paul
    2012 RT L
    AMA 25 years Life Member
    TRA
    PGR
    Rhino Riders Plate #83
    Venturers #78
    TOI
    Jul 2010
    Las Vegas, NV
    Default Sweet spot
    80. PM sent. Joe
    Joe Meyer
    Apr 2015
    Brockville ONT
    I like cruising the back roads about 55mph or 90 kph.
    Bill
    2018 RT Anniversary , Brake pedal extended
    Nov 2014
    Rural Hall NC
    I like to be the 2nd fastest vehicle on the highway. That way if he is going just a bit faster than me, the Leo's will get him and not me. I like about 77mph. No vibrations and moving at a reasonable pace.
    Dec 2015
    Galax VA
    Quote Originally Posted by Ex Winger View Post
    Bill
    Same with me.
    Jun 2013
    queens ny
    i like 65 to 70
    Active Member Scotts8826's Avatar
    Jun 2014
    Kansas
    I cruise between 70 and 75 mph on the interstate. Not for the bike, it does fine, but for me. At that speed I can "goose" it a bit when I need to, control a relative quick stop and adjust to changing road conditions comfortably.
    My sweet spot is usually two to three miles above the posted limit.
    Here, I drive 60 in the 55's, 68 in the 65's, and 73 in the 70's. I get no shaking of any kind, the gas mileage is "normal" at 31 or so for the 998 and 39-41 for the 1330. When you get past 70, the mileage will go down a bit--but--for most, that is not an issue.
    Jul 2015
    Dorr, michigan
    Bill
    2020 RT Limited , Petrol Blue
    Sep 2014
    Argyle, Texas
    Quote Originally Posted by cptjam View Post
    80.
    Houston
    About 80 - 85 MPH
    Bossier LoUiSiAna
    Well first off I have to get out of state to enjoy any speed , not just the limits but the quality of roads But at spyderfest I did enjoy the 60-80 range where I could
    However was short lived as I'm back home now i still have my routs but more for views & destinations than the speed I get there Im a happy laid back no rush redneck anyway
    Jun 2011
    Lynden, WA
    With my 2014 I get my best miles per gallon around 55 but other than that I drive the speed limit + 5%, so 60 will be 63 on the GPS or 64 on the speedo. I do not believe I have a favored sweet spot, I have been over 100 mph and no issues.
    SpyderLovers Sponsor spidergreg's Avatar
    Sep 2015
    Jamestown, KY
    Default about 83
    On the Eway I usually set the cruise at about 83 and the GPS states about 80, Ride is smooth and comfortable. I generally set about 10 over regardless.
    Greg and Debbie 2012 RTS
    Our Mods
    Feb 2015
    McLain, MS..
    Default The faster the Sweeter..
    Between 82 and 85 is best for me, I get a little belt harmonics (not much) between 75 and 80 but just a tad faster and it smooths out...but I can pretty much run any speed if needed...
    Low & Slow here: about 65 mph...
    But should the need arise... I can crank it up!
    Active Member ES44AC's Avatar
    Sep 2015
    Mocksville,NC
    I like 75 but, my spyder belt vibration is bad. So I have to do 76.
    2021 RTL Marsala Dark Edition 4.13.2021
    Lamonster Riser
    Spyder Extras Docking station
    Zumo XT (my own Plug & Play cable)
    WrapMySpyder Carbon fiber partial kit.
    Baja Ron ultra performance sway bar and end links
    2015 RTS SM6 Intense Red
    born on date 3/2015 (mine on 9/12/15)
    Sold on 4.13.2021 33k of fun.
    Jun 2014
    Schenevus NY
    102 I believe, eh Bob?
    Trb-- (Roger)
    2022 White Pearl F3T
    Spyder States Visited
    May 2015
    Dutchess County, New York
    I am a 5-7 MPH above the speed limit to avoid the flashing lights. I get a belt vibration about 73-76 so I stay away from that range. I will admit to ocasionally opening it up to "clean it out"
    Active Member Gunkandpudge's Avatar
    Nov 2011
    Hot Springs Village, Arkansas
    Default WARRENTY ISSUE
    I asked Lamont at Spyderfest if I had a warranty issue? The issue is that above 100 mph I hear what sounds like a woman screaming. He just looked at me! Well I've learned that if I stay below 90 mph I have absolutely no problems.
    Very Active Member AeroPilot's Avatar
    Nov 2012
    Pueblo Colorado
    Default Like some others, I like the Blue Highways...
    Running 66-68 on the secondaries hits the sweet spot for me. 3400-3600 RPM gets me close to 40 MPG unless the headwind gets in the way...To each their own.
    2015 RT , OEM Black Gloss
    Vermont
    I go 70mph on interstate. No Problems.
    Deanna
    Gremlin Bell
    SpyderPops Missing Guard Belt
    Ultimate F3 Floorboards
    Sway Bar with Links
    Rolo Laser Alignment
    Half Cover
    Show chrome Trunk Shock
    Quote Originally Posted by Trbayth View Post
    It was higher than that...
    It's to read the GPS when you're above the posted limit; the display is red!
    ...But it showed me 105!
