Results 1 to 25 of 27
    Oct 2011
    Kalamazoo, Mi
    Default RT to RS handle bar swap
    A bid shout out to JimboRTS for selling me his RT take of bars. They are now installed on my 2014 RS and will allow me to ride long distances more comfortably and upright not leaning forward. There is now a comfortable bend @ the elbows where as before my arms were fully extended.
    Will try and get some pictures attached.
    2018 F3-T
    2018 F3-T , Pearl White
    Default Congratulations. ...
    Well done. Looks amazing... should be a nice relaxed ryde for you now...I can still handle the RS stock and love it but know it is not the best for all. Good to know you can make the swap....
    Oct 2013
    rome new york
    Put the sts on my rs
    GREAT
    Jul 2010
    Las Vegas, NV
    Default Sweet
    Nice job! Can't wait to see it! Joe
    Joe Meyer
    Oct 2014
    cohoes ny
    Looks good, I would not be able to ride My rs without my 4" risers
    Oct 2011
    Kalamazoo, Mi
    Default RT to RS Handle bar swap
    Thanks, Yes the swap is "easy" bolts right up but only 2013 and forward. Spent a few trips back inside to look at the shop manual during the change over. The ugliest part was figuring out where the two 10 mm bolts that held on the forward plastic shroud in front of the ignition switch!!
    Al in Kazoo
    2018 F3-T
    Oct 2011
    Kalamazoo, Mi
    Took the bike out for ~ 100 mile jaunt on the back roads. OMG what a difference in how my back and neck feel!!!
    My arms are now bent ~ 40 degrees @ the elbow, my spine is straight and the ease of steering to turn a corner is night and day difference. I feel I have much better control of the bike when changing directions off a straight line.
    I don't feel like I'll need to replace the backrest now. Am looking forward to my trip to California to visit my sister in July.
    Al in Kazoo
    2018 F3-T
    Houston
    Halfway through the swap on my wife's RS now. I'll be looking for a black set of these bars for mine too!!
    Oct 2011
    Kalamazoo, Mi
    Quote Originally Posted by hdlongrod View Post
    You will not be sorry you made the switch; just that it took tou so long to do so!!!
    2018 F3-T
    Feb 2016
    Southern Maryland
    Default Making this swap on different year Spyders
    Hi,
    Interested in making this swap on my 2011 RSS with bars from a 2011 RT. You seemed to indicate it may not work for earlier model years... It that definitely the case ?? Any insight appreciated ! Thanks
    Regards,
    Brion
    Quote Originally Posted by IGETAROUND View Post
    Al in Kazoo
    2014 RTL , Black
    Sep 2009
    La Valle, WI
    I just replaced my 2015 RTS bars with the Tri Axes bars. I would sell them. They are black.
    2018 F3 Limited , Oxford Blue
    Active Member JonYiong's Avatar
    Singapore
    Hi IGETAROUND,
    I'm contemplating to do the same to improve the ride position.
    Please advice what are the parts I need to replace my 13 ST Limited handle bar to RT handle bar.
    Thanks in advance...Cheers
    Oct 2011
    Kalamazoo, Mi
    Default rt to rs handlebar swap
    JonYiong
    Hi IGETAROUND,
    Sorry for the long delay, this just popped up today!!! Hopefully you have done the swap, if not the things that you will need different is the covers that fit underneath the bars and keep all the wiring covered. Make sure that you order the covers for the SE as they are configured differently than those for the SM. All the other parts are interchangeable from 2013 forward.
    2018 F3-T
    Singapore
    Hi IGETAROUND,
    Thank you for responding.
    Apologized for my ignorance, wonder is it possible for you to post the picture of the exact parts I need to get.
    Thank you so much.
    Sorry for the long delay, this just popped up today!!! Hopefully you have done the swap, if not the things that you will need different is the covers that fit underneath the bars and keep all the wiring covered. Make sure that you order the covers for the SE as they are configured differently than those for the SM. All the other parts are interchangeable from 2013 forward.[/QUOTE]
    Singapore
    [QUOTE=JonYiong;1213891]Hi IGETAROUND,
    Thank you so much.
    By the way:
    Am I right to say that the items I need are:
    1) Handle Carbon Black cover with small black cap in the bottom of the center cover.
    2) LH Steering cover for SE5 (semi auto transmission)
    3) RH Steering cover
    4) And required screws & bolts
    Hear from you soon...Cheers
    Very Active Member Warlock's Avatar
    Oct 2011
    Magnolia, Ms
    Quote Originally Posted by MDBrion View Post
    Hi,
    Regards,
    Brion
    Will only work on the 13 models and later. 08 thru 12 will not work.
    David
    Oct 2011
    Kalamazoo, Mi
    [QUOTE=JonYiong;1214076]
    Quote Originally Posted by JonYiong View Post
    Hi IGETAROUND,
    Thank you so much.
    By the way:
    Looks like you have it covered; on line Green manuals will give you the exploded view pictures you need. Good luck on your swap. Pictures when it's done!!
    2018 F3-T
    Singapore
    Thanks for your reply. Meanwhile I need to get hold of these parts 1st.
    Btw is it very difficult job to change the handlebar?
    Oct 2011
    Kalamazoo, Mi
    Figure ~ 3 hours the first time, the second would probably be about an hour
    2018 F3-T
    Singapore
    Is it a direct swop without removing other parts besides the handle bar cover and handle controls?
    Saw a YouTube video on a RT changed to a Tri Axis handle bar, very complicated.
    Oct 2011
    Kalamazoo, Mi
    Yes just the handle bars, get yourself a manual
    2018 F3-T
    Singapore
    Thanks for providing me these valuable information.
    Your patience is greatly appreciated...Cheers
    We added 3" risers to the bars on both the 2008 and 2009 GS/RS versions. The crotch rocket position got real old, real fast. There were no risers in those days except for the factory 1.5 inch ones--and IMO--they did not help much. My dealer custom made the 3" risers and I got one set free for beta testing and the other for installation time only. They worked for me. Dealer no longer has them for sale.
    Default RISERS - CUSTOM ?????
    I'm surprised they " custom made " them. I was in the same position as you in 09 and I bought Snowmobile risers and used those .... worked great ...... Your dealer does have snowmobiles - ?????? ...... Mike
    Yes on the snowmobiles. He sells the most in the US. I did not even think about snowmobile risers. I don't ride em.
