Page 4 of 4 FirstFirst 1234
Results 76 to 99 of 99
  1. #76
    Quote Originally Posted by stebrock View Post
    Does this affect the 2016's?
    The TSB is only mentioning the 2015 model year bikes; so I'd guess "no".
  2. #77
    N. Va
    Quote Originally Posted by BRPcare View Post
    Hi all,
    There was indeed a proactive warranty campaign released on January 12th regarding chassis reinforcement on the F3 and F3 S, to halt or prevent a crack around the welding of the rear shock absorber upper bracket. The reinforcement kit will ensure full long-term structural reliability of the frame section. It's important to note that in the unlikely event any further crack or deformation should appear in the same area addressed by this warranty bulletin, BRP will cover this frame repair under a lifetime warranty.
    Also note that this is not a safety recall. You should still get this bulletin performed to avoid any preventable damages. General dynamic behavior and handling capability are not affected.
    Its good to see the move to preserve the integrity of the chassis, but why not solve the cause of the problem - the rear spring is too weak to prevent the rear suspension from bottoming out. You need to change the rear spring to eliminate the constant bottoming out impacts to the chassis. (http://www.spyderlovers.com/forums/s...up-shock/page3)
    The constant bottoming out is like having a small jack hammer beating away at the chassis until metal/weld fatigue gives way.
    The cheap way to fix the problem is to reinforce the part of the chassis that is failing. The problem is that your reinforcing of the chassis in a specific area will only transfer the impact loads to the next weakest point in the chassis. Who knows where that would be - hint: it will be a part of the chassis connected to the rear shock absorber upper bracket.
    It seems to me, this could become a safety issue if the upper rear shock frame/bracket fails, the rear of the bike could collapse causing a possible loss of control of the bike. BRP should not characterize this as a proactive warranty campaign.
    My 2 cents. I will go back to riding my ST now...
    Jerry
  3. #78
    Nov 2015
    Northport, NY (2015 Spyder F3-S)
    Quote Originally Posted by Darren111 View Post
    Just heard news about F3 Warranty Campaign. Chassis reinforcement is needed due to reports of some F3 chassis breaking.
    Going to ring my dealer in morning to get some more clarification on issue. Apparently all F3 models are affected.
    Would be great to hear from others on this issue.
    I called my dealer and he didn't know anything about it. He said the parts would be auto shipped to him. He didn't seem to care anything about it either.
    John
  4. #79
    Nov 2015
    I called BRP today. They said it is a Recall and my bike was one of the ones recalled. They made case and assigned me a number. Now bak to the dealer...
    John
  5. #80
    Dec 2014
    NY
    How many total warranty campaigns have there been so far with the 2015 F3? I'm aware of the chassis and brake line. Any more??
  6. #81
    Very Active Member armyspydervet's Avatar
    Nov 2015
    Occoquan, VA
    Default You Belong
    Quote Originally Posted by vondalyn View Post
    which is a closed group so those of us who don't belong, can't read anything. Care to copy and paste the info?
    This is for 2015s, not ALL models. Also, it is considered a closed group on FB just so you don't get the whole world posting or trolling on the page. All you have to do is request access and tell Whit you are a spyder owner and he will approve you to join. A lot of good info is posted there.
    Chris
    2016 F3-T SE6
  7. #82
    Mar 2015
    Westminster, SC, United States
    Lamonster I know you use FB and I am hoping you will tell us how genuine this recall info is, its just come from nowhere.
    This is genuine, had it done on my last set of tires at dealer. No big deal where it is....under your seat'us...
  8. #83
    Nov 2015
    Harvey, La
    I got mine done about 2 weeks ago after hearing about it on here alittle time ago. I asked the dealer if they knew about it and they said yes. I asked why they did not contact me? No answer. But they did have the parts on hand to do it right then. I just walked around while waiting.
  9. #84
    Mar 2015
    US
    I called my dealer and they ordered the bracket and installed it when I had my service last week.....
    mark
  10. #85
    Nov 2015
    Default Cover up
    The fitting of the bracket is not a fix, only a cover-up . Bewarned the cracks and breakdown of the frame will still happen as anybody that knows anything about Fatigue in steel will verify.BRP should be held responsible BRP state that they will give a lifetime warranty on the frame , I ask how can this occur after they have done a COVER-UP REPAIR can they be trusted???????????? FIX IT UP NOW. Des Downunder in AUS.
  11. #86
    Aug 2015
    fargo n d 58103
    I also installed the new occ. 2 up shock made a world of difference in handling & ride, well worth the $215 I spent
    Sent from my XT1080 using Tapatalk
  12. #87
    May 2009
    Connecticut
    Quote Originally Posted by sinner45 View Post
    Can you install this shock with just a Decent Jack and wrenches or is there anything more involved.
    I'm good at the front shock swapping! Is the rear different?
    Sea Doo GTI-SE 90 Jet Ski!!
  13. #88
    The process should be about the same... Jack up underneath the bike to take the load off of the shock, unbolt, remove, replace, and re-bolt...
    IF you have enough room to access the mounting hardware!
  14. #89
    Jun 2015
    jefferson georgia
    Default chassis reinforcement
    Hi all,
    some on the forums have replaced the rear shock. does BRP have a better shock for F 3 and whats the part number and price,thanks
  15. #90
    Member Phatjac's Avatar
    Oct 2015
    North Carolina
    Default 2015 F3 upgraged shock
    Quote Originally Posted by lazor1 View Post
    Part#219400739 ($179+tax), just installed mine this week, big difference/improvement over stock!!
    Phatjac
    2015 F3s - sold
    2016 RTS - sold
    2016 F3 Ltd Special Series
    2016 RTS (wife's)
  16. #91
    Nov 2015
    Harvey, La
    Quote Originally Posted by Phatjac View Post
    Did you order the shock through BRP or somewhere online? I want to do this but I have a few small parts from BRP online and it took forever to get them and they were only about $8 for each part.
  17. #92
    Apr 2010
    Ellicott City, MD
    Put the new shock on yesterday and rode for a good 70 miles. Much improved- as dramatic of an upgrade as an alignment or sway bar.
  18. #93
    Very Active Member ABQSpyder's Avatar
    Jun 2013
    Green Valley AZ.
    So when BMW had a problem with there suspension this what they did.
    Told riders to stop riding.
    BMW Motorrad USA has given owners a choice of three options.
    Those happy to wait will be compensated $2,500 (£1,470) once the repair is complete. Owners wanting a loan bike will be provided with one until a repair on their bike is complete, providing them also with $1,000 (£587) to use against BMW accessories or the payment of their RT. For owners no longer wanting to keep their R1200RT, BMW Motorrad USA will buy the bike back from them at original purchase price and give them $1,000 to use towards the purchase of a different BMW motorcycle
    Read more: http://www.visordown.com/motorcycle-...#ixzz46sT2qt17
  19. #94
    Active Member CharlieIndia's Avatar
    May 2011
    Washington Pa.
    Default safety
    Had the upgraded shock & spring put on at dealers last week, gave me the old parts. Anyone know what there good for? Trash? Didn't like the idea of paying for the spring? BRP should of fixed this on their dime.
  20. #95
    May 2015
    Arlington, WA
    Quote Originally Posted by CharlieIndia View Post
    Be careful. I wrote something similar (along with a few other issues) in another thread, and several members on here seemed like they were going to bite my head off! You'd better watch out now... just sayin! LOL
  21. #96
    Mar 2012
    NJ
    Quote Originally Posted by griffontamer View Post
    The old people around here get grouchy when it gets close to nap time. Don't pay it any mind. [emoji38] [emoji106]
    Sent from my Nexus 6 using Tapatalk
  22. #97
    Dec 2015
    New Brunswick, Canada
    Default F3 recall
    Found my model number on EC Certificate of conformity, mines on list so I will await dealer call.
    Don't wait for your dealer to call. Mine wasn't even made aware until I informed THEM. I just had mine done today.
  23. #98
    Mar 2015
    US
    The problem is that many here would rather excuse away the engineering defect in the F3 than to admit they paid so much money for a bike with problems. It's like it reflects on them somehow so they will use all kind of excuses. I feel that this is the reason mother BRP has not fixed the problems. Why should they when their customers make excuses for them....
  24. #99
    Default I GET IT - HOWEVER
    Quote Originally Posted by Nyparrothead View Post
    There is another similar thread " NEW FRAME F3s " started by member " Des " I posted a comment and go see what Capt. Bob from Fla. had to say to me ...... It's so enlightening what some of the New people can teach us Old timers Mike
