SpyderLovers Founder
Guessing we do away with the BRP rubber boot, that is on there now, when we upgrade?
What is the degree of difficulty to install? Can-Am doesn't always make it easy to get at the bulbs.
Thanks....
I just ordered mine and will finally make the headlight match the LED's on the from end of my F3s
Will there be an install video for these guys?
Mark Hood
![Quote](images/misc/quote_icon.png) Originally Posted by Bfromla
The rubber boot is reused. The heatsink will unscrew for insulation.
![](http://www.spyderlovers.com/forums/attachment.php?attachmentid=128408&d=1461158060)
![Quote](images/misc/quote_icon.png) Originally Posted by CharlieIndia
What is the degree of difficulty to install? Can-Am doesn't always make it easy to get at the bulbs. ![don't know](images/smilies/shrug.gif)
It's a pain to get to the bulb but it's no harder than replacing the stock bulb.
![Quote](images/misc/quote_icon.png) Originally Posted by Nyparrothead
Thanks....
Mark Hood
I have no plans for a video right now because it would take too long to shoot. I try and keep everything under 10 minutes and that's not going to happen on this. Best to get a service manual to help you.
What
![](signaturepics/sigpic13524_7.gif) White 2013 Spyder RT Limited. BajaRon Swaybar, Custom Dynamic Third Brake Light. Ultimate Custom Black and White seat with driver and passenger back rest. Gloryder Led Wheel lights.Custom Dynamics Led Bright sides, Amber and Red Fender lights, and Saddle Bag Bright sides.
![Quote](images/misc/quote_icon.png) Originally Posted by Lamonster
Will you be doing installs at Spyderfest, or is it too time intensive?
Chris
2016 F3-T SE6
![Quote](images/misc/quote_icon.png) Originally Posted by Pirate looks at --
Nothing for the RT?
The RT is a 9005 and they are in route.
![Quote](images/misc/quote_icon.png) Originally Posted by armyspydervet
No, we are limited on our time so that one will suck up too much time. Sorry
I will look forward to their availability.
SpyderLovers Sponsor
RT 2014
Lamont, get a set in, I'll buy them for Ann, we can video the install. I replaced her headlight bulb in a mud parking lot in northern Canada. Should be easy in your shop or the fairgrounds! Much less mud!!
Joe
Joe Meyer
![](https://www.spyderlovers.com/sponsors/squared.jpg)
![Quote](images/misc/quote_icon.png) Originally Posted by cptjam
Joe
Thanks. I hope they make it in time. The F3 is harder than the RT to install, that's why we won't be doing them there.
Installation is pretty simple, if you access the headlight bulbs per BRP instructions you will need the following; T15, T25 and T27 Torx drivers, 7mm wrench, small wire cutters and 6 ea. 7" zip ties. I've been told, after the he fact, that you can just remove the screws holding the side rails on and slide to one side replace bulb and then do the other side.
![Quote](images/misc/quote_icon.png) Originally Posted by fencepost
Could you explain... There is a different way other than the BRP manual?
mark
By removing the screws holding the side rails you will be able to lift the panel up and to the side to access the headlight bulb. I would suggest that you tape off the of the fairing so as not to scratch it when you move the panel to the side. I did not do it this way, I followed the BRP instructions and would do it again if the need to access the bulbs was needed. Having total access is more important to me than trying to hold a panel to one side. Even with the tape I would still be concerned with scratches on the fairing.
What are you calling the "side rails"?
The correct name is Console Header they hold the instrument cluster.
We use microfiber towels. No issues.
Fingers crossed!
I hope they come in for Ann. Meanwhile, my buddy Sue on an F3 wants a set. Of course, I need to install them! However I can help, just let me know. Videos, instructions, whatever. Stock lights suck! More light is always better! Joe
Joe Meyer
I pick up my F3 Wednesday, my lights should be here by then. I plan on installing both the headlights and fog lights on Thursday or Friday. I will take some pics as I go.
Ann really doesn't want them.
2014 RTL-SE6 8,600 miles
2011 RTS-SM5 5,000 miles
2010 RTS-SM5 59,148 miles
2010 RT- 622
![Quote](images/misc/quote_icon.png) Originally Posted by 900Dave
Thank u in advance for posting pictures as u go including panels please - also any tips/lessons learned along the way appreciated. Fog lights easy but I am concerned about getting to the headlight bulbs. How many Spyderlovers does it take to change a headlight bulb in 2015 F3s? Beats me. I only know that the time is to long for a video installation guide - HEY! we need a Bob Finless for F3's.
I have read the owners manual steps to changing headlight bulbs but perhaps there are some missing details or easier ways of doing it.
Cheers and the best of luck.
![](signaturepics/sigpic2300_15.gif) 2020 RT Ride Frequent Stay Safe
Aftermarket Aux Light, GPS mounting/wiring, Lamonster Garage Mirror Lock, Lamonster Garage Belt Tensioner
Backrest Home Brew Mod
2008 RS from 2008 through 4/2015, 2015 F3-S from 4/2015 through 9/2020
