Results 1 to 13 of 13
    Jun 2015
    AZ
    Default do you rotate the front tires
    If so at how many miles
    Thank you for your responses
    Kenn
    Very Active Member GOZFST's Avatar
    Oct 2014
    SD &AZ
    The tires are directional, so it requires dismounting, remounting and balancing. Most owners don't do it.
    Bob S
    If your Spyder is properly aligned, spell that laser aligned, and you maintain equal pressure in both tires you should not have to worry about rotating.
    Bryant, Arkansas
    Short answer NO.
    Cruzr Joe
    Jun 2014
    ny
    i won't do it unless i see a problem starting in the tread, the i would flip & cross
    Default ROTATING TIRES = BRP - BS
    This is BRP's way of fixing the fact that they can't seem to send out Spyders with properly aligned tires 75 % of the time.......All front tires on all Spyders should get at least 20,000 miles ( or more ). If they are properly aligned.....I'm not making this up !!!!!....If your FRONT tires aren't wearing evenly they are OUT OF ALIGNMENT and this needs to be corrected, otherwise you suffer premature tire wear for as long as you own it........So forget the tire rotating thing and get your Spyder aligned with someone using the Rolo / Outlaw Lazer system......Most Dealers do not have this system...........Mike
    Add wandering, lousy handling and lower fuel mileage to the list for a poorly aligned Spyder.
    Jun 2013
    Almost 22,000 miles on my OEM Kendas, and still plenty of tread, and wearing evenly. I attribute this to a laser alignment, done when I had fewer than 1,000 miles on my 2013 RT. I've read too many problems that folks have had, after rotating, that I opted not to do so.
    Default Curious. ....
    As I remember rotating your tires on the old bias ply was crisscrossing them. As the newer radials came out the rotation was simply front to back. Many of the folks that did rotate them as indicated only had more problems and it did not help at all. Once the laser alignments came out tires wore evenly. I had one tire wearing on the edge and once aligned eventually evened out and they lasted over 30,000 miles....Still your choice...
    and I have had a couple that got 23K before they were retired. (was that a pun?)
    Jun 2013
    queens ny
    i found that when i ride forward, the tires rotate forward. same in reverse, sorry i just had to
    Coolidge Arizona
    Quote Originally Posted by cuznjohn View Post
    Wow Cuz
    Mine Rotate in reverse not forward when I back up
    Sorry Cuz just had to say it
    with Dan and John: my tires only get rotated around the hubs!
