Here's what I found...
For whatever logic the grab bar (handle) is in the luggages section and they are different. The RT part # is different and the RT-S and RT-ltd are the same. As to the harness I am not sure. When we made harnesses it was cheaper to make a full harness and use only the connections for each model than it was to make a harness for each model. I would imagine it is there and you just need the proper wire to hook up...
The harness connectors are there for the heated grips. It looks like they just plug right into the grip. There is no wire with connector shown coming off the grip, and the connector illustration shows it to be a rectangular male with probably female terminals, i.e., a typical plugin connector.
The grips are definitely different between the RT and the others. $79.99 for the RT, $104.99 for the Ltd.
They are different from the others but the RT-S and the RT-LTD are the same. So if the S and LTD come with heated grab bars this is what you will need to get. ..then plug them up.
Originally Posted by latony007
Thank you all, im quite certain the last place i would have checked was the luggage section
So in looking at the diagram its weird, i selected the RTS SM6 and it shows 2 parts# one says RT standard and that part # says passenger assembly heated. The other parts say S, Limited, SPE and it is says those parts are not available for this model, strange.
Basically though it should cost about 210 to put heated grips on a base model. Wonder how hard they are to get to.
Thanks again everyone.
I don't know why the RTS parts page says not available. I can see why the RT page does. The std is the base RT. Go to the parts page for the Ltd. You can find the part numbers there. Make sure the control switch is part of the handle. I'm sure it is, but double check.
