Results 1 to 14 of 14
Thread: Oil Level
    Active Member View from behind's Avatar
    Aug 2015
    Taylors SC
    Default Oil Level
    We changed the oil and filter on 2015 RT Limited last fall while preparing for winter storage. Purchased the XPS kit for the SE6 and after draining all the oil and replacing the filter, o rings and seals added 5 quarts of oil. Today in preparation for the start of our riding season per the instructions in the shop manual we let the Spyder run for 35 minutes (live on a dirt road and can't get out to ride yet)and within 2 minutes checked the oil level which was slightly above the "min" on the stick. Is this normal? Does it actually take more than 5 quarts?
    Default WELLLLLLLLLLLLLLLLLLLLLLLLLLLLLL
    If you really let it drain for a long time ( and lower it so it's level ) after fully warmed up and change the filter, I have found it takes another 4 oz. in the 1330 engine to bring it up to 3/4 full..............and that's where I leave it..........Mike
    Mar 2015
    Brockport, NY
    Default I think mike nailed it.
    Thats exactly what mine took to get it to the middle of the OK zone of the dipstick. 5 and 4oz
    2014 RT-S Pearl White
    Default It Does
    will depend on the way the change is done. Is the warm or cold, level or askew, how long you let it drain etc. Always good to the check it cause all the manuals are reference and the dip stick is the way to go.....
    The spec is 5.3 qts when changing filter.
    Aug 2015
    Taylors SC
    Default ?
    Has there been an update to the manual? Our manual clearly states 5 quarts.
    Dec 2014
    Garland, Tx (near Dallas)
    Question A Related Question
    We are told in order to check the oil level accurately, we have to make sure the engine gets hot, then shut it off, give it a few minutes to drain into the oil pan, then check the level. Why not just check the level when the engine is cold? Checking it cold should give the same result as getting the engine hot, then waiting for the oil to settle back into the pan - which is where it will be when the engine is cold.
    Quote Originally Posted by Professor View Post
    See post #13 in this thread:
    http://www.spyderlovers.com/forums/s...+engine+amount.
    See this thread for additional rationale:
    http://www.spyderlovers.com/forums/s...0-Oil-Level-on.
    FWIW, in my first DIY oil change I had the front of the Spyder up automobile wheel ramps. If you look at the diagrams of the engine and clutch cover you can see that the drain plugs are located toward the rear of the casings. I let the hot engine drain for an hour or so, did the five quart refill and test restart. When the oil light went out I backed the Spyder off the ramps, restarted and ran it until the fans cycled twice, turned off the engine and waited a minute before checking the dipstick and the oil level was at the Min mark. I subsequently added a total of 10 oz in two top offs, restarted the warm engine, let the fans again cycle twice and which raised the level on the dipstick to the bottom of the Full bulge.
    Aug 2015
    Taylors SC
    [QUOTE=JayBros;1111238]See post #13 in this thread:
    Wow, well what we are planning on doing is to add 4 ounces now and after the next ride out check again and add if necessary to be somewhere between 3/4 and full based on the dipstick.
    Thanks to everyone that has taken the time to reply.
    Jun 2011
    Near Lexington, NC
    Put exactly 5 qts in an forget about it.
    Two Wheelers from 1963-2011
    Three Wheelers:
    2011 RT(Red)
    2014 RT(white)
    2016 F3T(red)
    2022 RT current ride(silver)
    __________________
    2016 Slingshot
    2018 Vanderhall
    2019 Slingshot
    Quote Originally Posted by View from behind View Post
    I was writing from memory, having just changed the oil the evening before and looking it up in the PDF copy of the 2014 service manual. I remembered the number correctly. I missed seeing it was litres, not quarts. It's a good thing too. I put in 5 qts, warmed up the engine, checked the level, and added about 8 oz more. I'll have to check it now that I've ridden a couple of hundred miles and see where it's at.
    Did BRP ever send out a correction sticker for the owner's manual? I haven't looked at mine, relying entirely on the e version I got from canammanuals.com, and it has the original specs in it. Any idea when the manuals were changed?
    Jun 2015
    Hobart, IN.
    Default Oil Change
    Checking when cold is fine, been doing that forever.After draining I let it set until cooled off. Then put in five qts. and check where it is on stick, mark it and that's where it will be in the morning when you check it. Works for me,Been checking oil like this for 74 years................
    Default YES.............BUT
    Quote Originally Posted by manxman View Post
    From what I've read here I don't think this works well with an OIL reservoir system like ours .......but I could be mis-taken on this ................Billy B !!!!!!!!!........................Otherwise just check it AFTER every ride ......Mike
