Results 1 to 12 of 12
    Invalid Emails
    May 2013
    Butler County, Western PA
    Default Minimum size trailer for 2 Spyders
    Can you please tell me what the minimum dimensions would be for a trailer for 2 Spyders? Thanks!
    Active Member GearHd's Avatar
    Mar 2015
    Connecticut
    At 9' long you'll be talking a pretty long trailer. If they have no luggage you might be able to get creative pulling one on then backing the other on at an angle. I've got a 7x16 enclosed that my motorcycle and our ST-L fit on but even my bike has to go on at an angle.
    Wife has a 2014 ST-L
    2014 ST Limited , Silver Platinum Satin
    Active Member duke50's Avatar
    May 2014
    IL
    Bikes would fit fine in a 7x18 trailer.
    Mar 2015
    Connecticut
    Quote Originally Posted by duke50 View Post
    That would be my suggestion. That's a big trailer and if it's enclosed you'll need a decent size tow vehicle. If it's a V nose you may need to back the first Spyder in.
    May 2014
    IL
    The v is a bonus 30" So trailer would be 18' inside plus v nose.
    Keep in mind if you get a v nose your tongue will be considerably shorter
    you really have to be careful backing up. If v nose is your choice get 1 with an extended
    tongue problem solved. Like you mentioned an enclosed would be very heavy unless its all aluminum
    I myself have a open 18' open trailer with ramp weighs about 2300lbs
    May 2012
    sussex, nj and tug hill, ny (west turin)
    jill, duke is spot on for his advice. knowing that you are eventually going to be towing this behind a big rv, the short tongue is a definite problem. if I had the chance to buy my again, i'd have checked for an extended tongue on the trailer. on my friends!!
    Quote Originally Posted by GearHd View Post
    You might even be able to make a 7x16 footer do the job, with some creative side to side overlapping of the bikes...
    Sep 2008
    TX
    We have a7 X 16 with a V-nose. Back one in, drive the second one in. Room to walk on sides and between noses but not around the ends. Go as low as you can on the height. Search for my other post that had a picture of the Spyder's in the nest (I can't get it to reload from my phone).
    Wayne
    pauly1 - SpyderDeb's 'wrench'
    IBA #48220 SS1000 BB1500
    Invalid Emails
    May 2013
    Thanks for all of your replies / advice. Like Chuck mentioned, we will be pulling the trailer behind a motorhome and don't want to make any mistakes as far as the trailer is concerned.
    Nov 2013
    Oro Valley Arizona
    Quote Originally Posted by spydaman60 View Post
    I use a 12" hitch extension for my V-nose. Works great. They come in 6-14". Slides into hitch receiver then the hitch adapter goes into it.
    Jack
    2015 BMW R1200R LC
    2014 RTL SE6 Pearl White
    2012 RT-622 trailer viper red
    2011 Polaris Ranger green
    2016 Can Am Maverick
    May 2014
    IL
    I would also check weight of your trailer loaded and compare that with receiver load capacity. If your camper is a class C you probably have a 3500# receiver. That's what on mine anyway. Class A no problem.
    May 2012
    Quote Originally Posted by jaherbst View Post
    Jack
    that's what i'm getting for the new rv!! thanks!!
