Page 1 of 3 123 LastLast
Results 1 to 25 of 55
    Active Member ssmcclub's Avatar
    Apr 2013
    massapequa ny 11758
    Default general altimax rt43
    general altimax rt43 has a bigger diameter 215/60/15 then stock tire 225/50 15 will it hit the rear fender on a 2014 rss ? do you have to shim the fender?
    richie spyder
    Oct 2011
    Kalamazoo, Mi
    Quote Originally Posted by ssmcclub View Post
    Will fit just fine, tight but fine; and no you don't need to shim the fender.
    As an added bonus your speedometer will be accurate to the GPS's MPH readings throughout the entire speed range!!!
    2018 F3-T
    2018 F3-T , Pearl White
    Dec 2014
    Lee's Summit, MO
    I believe you will. A good place to find out more information is in the advance search. Type in tire, tire size or tire and fender. You will pull up more information than you ever knew existed for tires.
    Dec 2014
    Lee's Summit, MO
    Quote Originally Posted by IGETAROUND View Post
    Thanks for getting me straight on this. I know one of the models usually needs the fender shimmed if going to a different sized tire.
    Apr 2013
    massapequa ny 11758
    ok thanks guys will be installing one next week
    richie spyder
    Vermont
    I am also running the General Altimax RT 43 tire on my 2014 RTS-SE6.
    I posted pictures of the my General Altimax RT 43 tire on the "Tire" thread.
    I am very happy with the General Altimax RT 43 tire. The spyder handles fine. I choose the General Altimax RT 43 for the ratings. I do not notice a difference. Deanna
    Gremlin Bell
    SpyderPops Missing Guard Belt
    Ultimate F3 Floorboards
    Sway Bar with Links
    Rolo Laser Alignment
    Half Cover
    Show chrome Trunk Shock
    Default TO SHIM OR NOT.....
    The issue won't be if it will hit any fender parts or bolts/nuts..............However the wiring needs to be PERFECTLY attached so it does not get scraped by the tire..................been there done that....Mike
    Oct 2011
    Kalamazoo, Mi
    Yep that wiring loom going to the licence plate light needs to be properly positioned and checked that it stays where it is supposed to be; or something bad will happen, yes it will.
    2018 F3-T
    Pragmatic Member
    Mar 2015
    San Tan Valley, AZ
    I installed one earlier this week and I have plenty of clearance. So far, I love this tire.
    Pam
    Vermont
    Quote Originally Posted by Pampurrs View Post
    Pam
    Pam, Keep us up dated on new your rear spyder tire. Deanna
    Gremlin Bell
    Sway Bar with Links
    Half Cover
    Jul 2013
    peru, illinois
    Default Tire 43
    Will this same tire fit a 2012 RSS? Thank you. John
    Vermont
    Quote Originally Posted by spyderwing View Post
    John, Read post # 2 posted by IGETAROUND on this thread. Deanna
    Gremlin Bell
    Sway Bar with Links
    Half Cover
    Hi Dee,
    How much air (in PSI), are you running in your rear tire?
    Active Member cyclekid58's Avatar
    Sep 2014
    Post Falls Idaho
    Default Altimax RT43
    Hi Dee,
    Not sure what Dee is running in hers, I have the same tire and running 26psi, just rode today and feels great.
    Greetings from Idaho
    2014 RT-S,
    Barjaron swaybar, chome luggage rack, Ram Mount GPS, 12 volt dash outlet, spyderflap mudflap, Rivco flag mounts, drink2go and custom handlebar drink holders,Driver Backrest,Tri-Axis Handlebars, TRICLed turn signal lights. Custon Dynamic Magic Strobe Brake Modulator, Triple Dash Pouches, "Squared Away" Laser Alignment, Spyderpops Bumpskid, TricLed "Knightrider" LED
    2014 RT , White (Mine) Cognac (wifes)
    Vermont
    Quote Originally Posted by cyclekid58 View Post
    I am running the
    General Altimax RT 43 tire on the rear of my , and I am running 26psi. Deanna
    Gremlin Bell
    Sway Bar with Links
    Half Cover
    Thanks!
    (I'm running 25 psi in my Kumho...)
    I wondered about your tire pressures, since Mike is such a proponent of running them with around 21psi or so in them...
    Default TIRE & PAINTED DASH
    Thanks!
    Bob, if you knew how long it took me to convince Her ( to allow me ) to Paint Her Dash " Cognac ", you would know why I gave up at 26 PSI............Mike
    Greenville Tx
    I went with the Yokahama S drive 215-55-15. I got it delivered yesterday but have not installed it yet. I figure the 55 is still larger than the kenda 50 but not give me the clearance issues of the 60. Also if you get mud on the tire, It will rub on the fender. Im sure the 60 is fine on the RT but on a RS or ST you need to go a step smaller
    2017 F3 Limited
    Oct 2011
    Kalamazoo, Mi
    Pam
    But Pam, you've got a big RT where everything is more roomy
    2018 F3-T
    Bob, if you knew how long it took me to convince Her ( to allow me ) to Paint Her Dash Cognac , you would know why I gave up at 26 PSI............Mike
    How does that old saying go?
    "You can lead a Beautiful Young Lady to water; but she's got to actually WANT to take a drink from it."
    Nov 2013
    Oro Valley Arizona
    Bob you smooth talking silver tongued devil you!
    Jack
    2015 BMW R1200R LC
    2014 RTL SE6 Pearl White
    2012 RT-622 trailer viper red
    2011 Polaris Ranger green
    2016 Can Am Maverick
    It's kept me alive for many years...
    Pragmatic Member
    Mar 2015
    San Tan Valley, AZ
    I thought that saying goes, "You can lead a horse to water, but you can't make it drink".
    Pam
    Greenville Tx
    Horses are much easier to train than woman.
    2017 F3 Limited
    Jul 2015
    Boise, Idaho
    Oh !!!! "Dead Man Walking"
