2016 F3 Limited
2019 Ryker Rally
2014 Suzuki V Strom 650
2020 CSC TT 250
Any idea if/when...
So does anyone know if/when VEE Rubber will be coming out with a new compound "FRONT" tires for the 2012's and below using 165/65R14? I saw posts earlier stating that the new compound are out, but all I see is for the 15" tires...
Lamont said that he was working with the MFG, and would be selling them at his store, but nothing recently.
Any news?
Originally Posted by den2614
gypsy_100, please give me the website were you ordered the Arachnid. I'm assuming you are talking about the H80, not the H68.
Originally Posted by Highwayman2013
den2614 if you read my post #19 you would see that I did not have to order a tire through a retailer. Mine came direct from Vee Rubber as part of a compensation program. Highwayman provided a link to a site where they stock and sell all four varieties: both size fronts, both rears. I think there are other retailers, also, but check the various posts and then ask them who they bought from. Or just order from SpyderComfort.
RT and Gold Wing States & Provinces
Originally Posted by billybovine
I just looked at the web site and there was no listing for 15 inch fronts for 2013 and later Spyders.
Did you get the right front tires?
Front for the Vee Rubber Arachnid is V35003 - 165/55r/15.
Rear for the Vee Rubber Arachnid is V35004 - 225/50r/15
Kinda Rear Tire
Just to add into this pot, I just had my 1st annual service done on my 2014 RT-S. My mileage is at 5,900 and the report says my rear tire has 30% treadwear left. I'm also researching the Arachnid.
Tri-Axis Chrome Handlebars
Sena SM10 BT Dongle
Double USB Port/Volt meter
LaMonster Magic Mirrors
BajaRon Swaybar
HALO Skid Plate
Shorty Antenna
LaMonster Cat Delete
Akrapovic Muffler
FOBO2 TPMS
Rear Trunk Rack
Bruce Erickson
Chilliwack, BC
Canada
2014 RTS-SE6 - Cognac
The Arachnid is a soft tire much like the Kenda. You won't get much better mileage out of it. I have had 3 of them so I speak from experience. It is a nice handling tire like the Kenda but it is soft. If you want long tread life get a car tire. They are cheaper and last much longer.
2014 RTL-SE6 8,600 miles
2011 RTS-SM5 5,000 miles
2010 RTS-SM5 59,148 miles
2010 RT- 622
Thanks for the advice Ann, but I'm part of the crowd who thinks that they recommend MC tires for a reason and I do believe that Safety is the key reason. I do wish and fervently hope that you never have a safety issue, but I'm not willing to take that chance. Maybe I'll change my mind, but for now, it's MC tires as recommended by BRP.
Sena SM10 BT Dongle
BajaRon Swaybar
HALO Skid Plate
Shorty Antenna
Akrapovic Muffler
FOBO2 TPMS
Rear Trunk Rack
Bruce Erickson
Chilliwack, BC
Canada
I have over 3 K on my Vee rubber and still look almost new. I know it will out last the Kendas only got around 5800 .
Many choices good luck
I just replaced my rear Kenda on a 2015 rts se6. 7700 miles and was pretty well worn out. Installed an Arachnid from motorcycletiremaniac.com. $135. Delivered no steel sidewall belts. Hope it lasts longer than the Kenda
Sent from my SM-T530NU using Tapatalk
