Results 1 to 23 of 23
    Sep 2009
    Martinsville In
    Angry Dealer labor rates
    I went to my local dealer where I bought my F3s to order the heavier rear shock. On a new sign the have posted the labor rate for the Spyder is $150.00 per hour.
    They are a multi line dealer and the rate for motorcycles and ATV's is $100.00 per hour. I think both rates are outrageous but a 50% increase because it is a Spyder is insane.
    To me it says they do not want to work on Spyders even though they are a dealer. Worst thing is both dealers in my area are owned by the same person so rates are the same.
    Looks like I will be doing all my own work.
    Only good thing is I got a 20% discount on the shock.
    I like the people at the dealership but will only buy parts there.
    Bill
    Very Active Member Big Arm's Avatar
    Jul 2008
    Sioux City, Iowa and Tucson, AZ
    Sounds like a good plan !!!
    2008 GS.....PE # 2888
    Nov 2013
    Central Texas
    That is pretty darn high. I suspect that they do not have a trained (by BRP) technician, so they are padding their rates because they know it is going to take an untrained wrench turner longer to do the work. Spyders are complicated machines, and it can take some time to sort things out. My dealer, who is a multi brand dealer, charges a flat rate of $99.00/hour, and they do have a trained technician. In fact, I believe they have two. Keep in mind that BRP has a flat rate table of how long it should take a trained technician to do a given task, such as an oil change. I think you are getting hosed by a "stealership". Just my opinion.
    Default COST OF WORK
    ..I have done all maintainence and routine service on Spyder ( 2014 RT ) since I purchased it. I am not a professional mechanic............The 1330 requires very little service and it's not complicated what there is.......You would be surprised at what you could do if you tried..........good luck.......Mike
    My last look a month ago was $110.
    My Dealer increased their Labor rates to $65.00 per hour...
    ...From $50.00!
    I guess that I should be thanking them...
    Very Active Member crazycanuck's Avatar
    Dec 2008
    Bellevue, WA
    ...From $50.00!
    Stop showing off
    Sorry...
    But sometimes, you just have to be happy!
    happy old fart stillriding's Avatar
    Apr 2010
    Elyria, OH
    Quote Originally Posted by IndyBill View Post
    Bill
    ​That's criminal! Why don't they just point a gun at you when you ride in?
    Apr 2015
    Boise Idaho
    Getting my F3 back tomorrow. My dealer installed the fully sintered brake pads on all 3 wheels, Baja Ron links, cannon ball seat, cut fender, big city baffle plus checked the line for the hand brake to make sure nothing hot is near the line. They sent a trailer from Caldwell to pick it up in Boise and are bringing it back tomorrow after a good washing and detailing. Total bill was 340.00. They also took care of the recall but I wasn't responsible for that.
    not sure what they charge per hour but I know they are sure treating me right! I paid the dealer in Boise more than 340 just to put my elka's on my RS.
    Mar 2013
    Maumelle, AR
    Bill
    Welcome to reality!
    If you're willing to travel (maybe 100 miles) a little, you can go to Maximum Power Sports at 2990 S US 31 Peru, IN 46970. Their labor rates are $85.00 an hour. They only charge one hour (plus parts) for an oil change. They're very reasonable... all things considered.
    2020 RT Limited , Chalk
    Jun 2010
    Las Vegas
    Wow, we need to raise our rates.
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
    Default Have to agree...
    The labor rates are unbelievable... the spyder is no harder to work on than a goldwing. I have worked on them both and would prefer the spyder. The space would be the only problem. Have seen some problems with them not wanting to deal with the warranty work. You can't make as much there and actually have a ryding buddy who was told not to bring his spyder in for service. (he has an ongoing oil leaking problem). I do my own work but know it is not that easy for others. Last time I had a dealer hook me up to buds he cleaned up all but the hours without service...some 785 hours no service and they can't erase that because I don't have the work done with them....
    Sep 2008
    Carmel, In
    Quote Originally Posted by Copperman View Post
    Welcome to reality!
    Agree! Good people at Maximum and their tech has been there for years. The Service Manager has been there for over 25 years.
    Very Active Member retread's Avatar
    May 2008
    Bargersville, IN
    Indybill, the rates at that dealer for Spyders have ALWAYS been $150/hour, they raised their rates for other bikes. Try Maximum.
    john
    Mar 2012
    Walsenburg, Colorado
    $60.00 here for labor. They also now have laser alignment.
    mtbear
    That's even cheaper than my guys!
    I'm glad to see that somebody else found some reasonable pricing!
    Jan 2015
    Outside L.A.
    wow that is crazy. i thought the 110 here was high. I like the guys at 60 an hour. I may ride out to CO for my next service!
    i did oil changes on my RS by myself but it was so easy to get the tuperware off of it. Looks like a PITA on the new RT i have and am afraid im going to break the mirrors trying to get them off lol. would certainly be nice if the design was such you could so simple things like an oil change without having to remove every panel from the bike.
    Apr 2013
    Monument, Colorado
    Quote Originally Posted by mtbear View Post
    mtbear
    What is the name and location of the dealer??
    Nov 2013
    Oro Valley Arizona
    Well let me explain the higher math to you "Three Wheeled Pilots". Our two shops here in town charge $120 per hour. Yikes! Not so quick "highway
    breath". They use the Can Am book rates i.e. the calculated time Can Am has decided it takes to do a certain job. If they run over that time which
    they usually do, you are only charged the book rate time. i.e. if Can Am says it takes 2 hours to do the job you are only charged $240 and not for the
    3 hours it took them. ($360) I think this is fair. It prevents " on the job training" for junior mechanics.
    If your shop only charges strait time and not book rate even at the lower cost per hour you could still be paying more.
    A thought to ponder on.
    2015 BMW R1200R LC
    2014 RTL SE6 Pearl White
    2012 RT-622 trailer viper red
    2011 Polaris Ranger green
    2016 Can Am Maverick
    Apr 2015
    Oregon/arizona
    Default Rate raising Las Vagan
    No ! No ! You are perfect as you are now ! Thanks for the excellent work.
    Dec 2014
    S.E. Michigan
    Bill
    The dealership I use to go too was pretty high, and the tech said he could not figure my parking brake out.
    Realized that there was a closer place, cheaper and the tech ACTUALLY LOOKED AT THE PARKING BRAKE!
    ~Sandee~
    ~Sandee~
    2016 RT-L (Purchased used in February 2018)
    RT Dash Mount (from JT's Spyder Store)
    Kuryakin Trident Highway Pegs
    Hopnel Pouch
    Magic Mirrors
    Spyderpops Foam Handgrips
    Iron Butt #35273
    Girls on Spyders #2779
    Northern Kalifornia
    Here's two possibilities. #1, they don't want to work on spyders, or #2, they only need to work on a couple of spyders to make wages that day. It's like selling apples for $100 each. You don't need to have very many apples and some dumb so-in-so is eventually going to come along and buy one.
