Results 1 to 23 of 23
    Dec 2015
    Arkansas
    Default Exhaust Question
    Hi, I'm new to this site and was hoping to get a little feedback on exhaust setups. I have a 2015 F3-S and would like to give it a more aggressive sound. I don't really care if it gets a little louder from where stock is, just not obnoxious. I was going to trying playing with the baffles a little bit but after looking at the exhaust setup I'm really not sure on how that would work. If anyone has any experience playing with the stock exhaust to change the sound a little I'de love to hear it. If not, I'm considering going to TwoBrothers. Only problem with that is its going to play with the computer since that setup removes the converter and replaces it with a straight pipe.
    Very Active Member Devious56's Avatar
    Oct 2015
    N.E. Florida
    Why don't you give this guy a call ( http://www.spyder1attitude.com ) and let someone who doe exhausts for a living tell you all about it. His prices are reasonable, and I know he has a good selection of mufflers to boot, not to mention he is a forum sponsor.
    David
    Active Member NM Wrench's Avatar
    Apr 2014
    Albuquerque, New Mexico
    Check out pitbull's exhaust. It is sweet and reasonably priced.
    Sent from my VS990 using Tapatalk
    14 RT-S , Stock Large brake pedal White Pearl
    Dec 2015
    Arkansas
    Man I'll be honest though those spyderattitude pipes just don't look too hot. I mean sound is important but it does need to look good.
    Dec 2015
    Arkansas
    Does Pitbull have any videos of stuff he's done running so I can hear it?
    Why not just try removing the catalytic converter first, and see if that'll fit the bill?
    Oct 2011
    Jacksonville,Ar
    If you install the cat bypass you will like the sound.
    Spyderpops did that an it is very nice sound.
    15 rt , yes Black
    Apr 2014
    Default I think so
    Quote Originally Posted by CaptainX92 View Post
    They did some videos of the exhaust they made for the F3 just before spyderfest this year. It is stainless and a complete exhaust system from front to back!
    Oct 2015
    N.E. Florida
    Quote Originally Posted by samewok View Post
    I did mine that way at Biketoberfest and like it also, but am thinking I'd like just a little more.
    David
    Dec 2015
    Arkansas
    could you possibly post any links to the videos?
    May 2012
    sussex, nj and tug hill, ny (west turin)
    I did the cat bypass on mine and kept the same oem tailpipe. lamonts performance pipe is all you might need!
    Henderson, NV
    I really like the 2 Bros with the P1X. Sounds mean when you give it a twist but sounds better than stock when you feather the throttle.
    Nov 2012
    North Las Vegas, NV
    Call Pitbull, they have a full stainless exhaust.
    2016 F3 Limited
    2019 Ryker Rally
    2014 Suzuki V Strom 650
    2020 CSC TT 250
    Sep 2008
    TX
    I removed the honeycomb structure from inside the primary muffler and did major surgery on the secondary muffler: cut the end off remove all of the packing and baffles, welded the end back on. Increased the depth of tone, get a bit of the rumble, and he wind noise will over power it at 50+ mph. I opted to keep the flow path of the OEM to maintain some backpressure in the system: we are running in the torque curve, not drag racing top rpm hp.
    No, I don't have a sound clip. Any cell phone-like capture will not project the real sound level as they apply a sound leveling algorithm to avoid hearing damage on he play back.
    The primary muffler bypass and stock muffler sound OK. Internals on the OEM F3S muffler have the gas flow making an abrupt 90 deg turn into a small chamber, then enters the two tubes that you see at the discharge end. Other than the initial turn, the exhaust is straight through the muffler - no turn baffles, etc. The tubes are perforated and the whole thing is packed with a very large-diameter, fiber (glass?) packing.
    I also polished and painted my primary muffler as I didn't care for the stainless steel finish.
    You might be told that you could save weight by removing the primary. While this is true, the machine suffers from too much weight up from and not enough on the back, especially when riding solo; in full riding gear I weigh around 180#. Lots of wheel smoke ensues when grabbing a hand full of throttle. I kept the primary, then, to assist in the weight distribution.
    Wayne
    pauly1 - SpyderDeb's 'wrench'
    IBA #48220 SS1000 BB1500
    Apr 2010
    Thorn Hill, TN
    I had the TB system on my F3 and we had the Lamont pipe on my wife's F3. I found the TB to be to loud for long trips and liked the exhaust note on my wife's F3. Both pipes had decell poping, which from what I know and have been told is caused by a lean fuel/air condition. I removed the TB system and went with Lamont's pipe and added a Big City Thunder baffle to both. This ballel is very easy to install and adds enough back pressure back into the system to improve mid range performance and take care of the decell poping and has an excellent exhaust note which will not become tiring on long trips.
    Dec 2012
    Morrton,Il.
    We went to Spyder fest and listend to several different set ups . Found the catalytic eliminater to be the best sound and it also was the lowest price. So we put one on our F3 and have no regets, the sound is good but not too loud for trips. Jim
    May 2015
    Arlington, WA
    Be careful with Two Brothers exhaust. I LOOOVE mine on the V-twin, it looks and sounds fantastic but it is pretty obnoxious. Most of the neighbors hate it and I don't think I could handle it on a long trip (done an hour at a time on it, no issues but any longer and I think I'd be a bit deafened).
    Bay of Plenty New Zealand
    I have now done 2 F3 mufflers after mods they sound just like the Akrapovic.
    Oct 2015
    N.E. Florida
    Quote Originally Posted by Devious56 View Post
    David
    If you aren't in that big of a hurry, I have ordered Pit Bull Power Sports stain steel system for my RT and should have it in a week. I will provide a video after I have it on.
    David
    Bruce B,
    What are you doing to them, and can you post a video with some sound?
    Oct 2015
    South Carolina
    Has anyone found any modifications to the stock exhaust. I had to ride my stock 2015 F3-S behind a 2015 RT-S with the A exhaust after they took the silencers out. Sounds like a different bike, I really don't want to spend money on a new exhaust system just yet.
    Apr 2015
    northern ontario
    [QUOTE=CaptainX92;1068794]Hi, I'm new to this site and was hoping to get a little feedback on exhaust setups. I have a 2015 F3-S and would like to give it a more aggressive sound. I don't really care if it gets a little louder from where stock is, just not obnoxious. I was going to trying playing with the baffles a little bit but after looking at the exhaust setup I'm really not sure on how that would work. If anyone has any experience playing with the stock exhaust to change the sound a little I'de love to hear it. If not, I'm considering going to TwoBrothers. Only problem with that is its going to play with the computer since that setup removes the converter and replaces it with a straight pipe.[/QUOT
    Just get the Akrapovic slip on and leave the CC in place, awesome sound and not irritating..
    Invalid Emails
    May 2011
    Gulf Coast of Texas
    you from Ark. you need some shovelhead drag pipes..
