Results 1 to 14 of 14
Thread: 12v outlet
    Sep 2015
    williamstown nj
    Default 12v outlet
    Hi all I have a 2012 spyder RT want to put a 12v outlet but were can I put one??? I have one in the trunk... Could you send me some pics to give me an idea Thanks All!!!!
    Bossier LoUiSiAna
    Rear trunk or frunk? Should be area ready in frunk fyi my frunk liner kinda in wayImageUploadedByTapatalk1448149481.094249.jpg heres one with flap up & flashlight plugged inImageUploadedByTapatalk1448149520.592664.jpg when in front of bike looking in its about 1/2way up the back wall on RH side. G'luck
    Oct 2011
    Kalamazoo, Mi
    ​check Finless videos
    2018 F3-T
    2018 F3-T , Pearl White
    Very Active Member armyspydervet's Avatar
    Nov 2015
    Occoquan, VA
    Default USB Rocker Switch
    USB
    May 2014
    Benson, NY
    Default 12v
    If you don't have gauges.
    2015 RTS Special Series
    Russell Day Long seat
    F4 Customs windshield
    Sena 20s
    Nov 2012
    North Las Vegas, NV
    Speaker grille.
    2016 F3 Limited
    2019 Ryker Rally
    2014 Suzuki V Strom 650
    2020 CSC TT 250
    Jan 2015
    southern WI
    Another vote for either one of the speaker grilles. Easy access. Pull one out and check it out
    2016 RTS , Pearl White
    Jun 2014
    People's Republic of NY
    left speaker grill
    May 2013
    Stanton, ca
    Speaker grill...
    Very Active Member robmorg's Avatar
    Oct 2013
    Pottstown, PA
    I mounted a weatherproof 12v outlet from Battery Tender on JT's accessory bar on top of the glare shield. Keeps the wires out of the way and easily accessible for charging my phone, also mounted there. I keep a duel USB charger inserted in it.
    Rob
    2013 RT Limited
    My "Mods & Farkles" Link
    May ALL your roads be beautiful
    Greisemer's Mill Bridge, Oley, PA
    2013 RT Limited , Lava Bronze with Antler Brown Seat
    Dec 2010
    Telford, UK
    On the left side of my 2011 RT just inboard of the left passenger grab handle I found a mounting blank already moulded into the plastic. it was a simple job to press out the blank and install a power outlet fused to 10 amps for my wife's electrically heated vest. The socket is very convenient in this position to supply 12 volts to the vest. The aim was to keep the wire to the vest as short as possible. if i needed an electrical supply for a different purpose I would obviously mount the supply socket close to where it was needed, I would hate to have exposed or trailing wires running around my Spyder. BRP made a good looking machine, it's not my job to turn it into a cluttered-looking mess.
    Very Active Member jthornton's Avatar
    Feb 2013
    Poplar Bluff, MO
    You could mount it on the dash or in place of a gauge.
    Oh the bezels are satin black now...
    JT
    Sep 2015
    williamstown nj
    were did you get that use????????😊
    Feb 2013
    Poplar Bluff, MO
    Quote Originally Posted by steriltech View Post
    were did you get that usb????????😊
    I make the mounts and sell them in my Spyder Store.
    JT
