wiring diagram for turn, break, running lights (2011 RSS SE5)
Does anyone know where I can locate a simple diagram?
Good luck BRP does not like to share technical info, even techs I know are better off drawing their own. Of which I do not have a pic sorry. Should be straight forward ,whatever your trying to do, have spare fuses & good tester/voltmeter. Plz share if you do find 1. Thx
I have the Spyder master manuals in a digital copy. I'll take a look tomorrow and look for a diagram for you.
Sent from my Nexus 6P using Tapatalk
Don't have a simplified version but have uploaded a copy of the wiring diagram for the RS (2008-2011) to my OneDrive where you should be able to open and download it:
https://uem6kw-sn3301.files.1drv.com...011.pdf?psid=1
I sent you the parts list, I posted the photo of the parts you will need the plug and play parts you will get from tricled that will be 2 turn signal connectors and 1 break light connector just go to there website and match up the photo then you will need to go the the auto store and get the trailer connection and LED tail lights be sure to get the one that has seperate break and tail lights and is compatable with LED lights when I used the standard lights they blinked to fast. The Connector is White:ground, Red:break light, Green:rt turn, Yellow:lt Trun, Brown: park and tail lights the wires from tricled are, Orange: Break, White:tail/running Lights, Black:Groung the turn signals are pluged into the wire with the strip the solid black wireis the ground hope this is clear good luck
Yes you did....and it help immensely....I currently waiting on two additional connections to arrive from Tricled. In fact I spoke to Reggy on the phone.....he recommended two additional connections in addition to the ones your recommended. I have the trailer connection/wiring setup that was recommended.
I was simply attempting to understand the placement of the second set of connections that Reggy recommend. It was on Sunday that he called....we was taking time out of his trip to see his kids.....I understood what he was saying...I did not want to waste any of his family time with my questions....I just wanted a visual representation of what he was describing prior to me opening the back end of the bike up.
I just need to purchase the trailer hitch assembly next.....and then work this into my never ending list of projects that pop up around the house.
Thank you.....
Originally Posted by PistonBlown
The tip for using the broom handle is a great one.....thanks.
Did you drop the rear brake assessmbly or work around it? The instructions have you drop it out of the way.
