Results 1 to 20 of 20
    May 2015
    Duluth Mn
    Default Uh-oh! What is this?
    Mighty and numerous Spyder sages, I have a problem. Specifically, my Spyder is piddling on my garage floor when I'm not looking, and has on my driveway also.
    From what I see in the garage, I have 2 puddles side by side located roughly just in back of the "wings" of my front wheel arms.
    I have asked her if she wants a litter box, but she refuses to answer me.
    The liquid looks like a very light pink water, and is slightly slippery when rubbed between my fingers.
    Can you tell me what the fluid is, and can I add more so that I can safely ride it 100 miles to the dealer for whatever fix is needed before the snow falls?
    Thanks,
    Active Member NM Wrench's Avatar
    Apr 2014
    Albuquerque, New Mexico
    Sounds like anti-freeze
    14 RT-S , Stock Large brake pedal White Pearl
    Invalid Emails
    Mar 2012
    Gore,Quebec,Canada
    Slippery, sounds like anti-freeze.
    2012 RT , stock Lava Bronze
    Bossier LoUiSiAna
    Worth checking all fluids. If has a bitter smell may be brake fluids not something you want to try 100mile dealer trip on. Laydown some news paper large enough to cover from foot pegs or floor boards to the front, & as wide as both tires, take pics if you can get good view before you move bike. Dealer will have to pull tupperware off to look for wetspots & splatter. Be prepared will not be quick. Hope is simple for you.
    Default ANTI-FREEZE
    IMHO.......just re-move the Tupperware on the right side. It may just be a clamp, or the tank may have a crack...this is a known issue.............Mike .................. PS, It's always a good idea to tell us what Spyder you have and the year..........sometimes it makes a BIG difference .........Nice color combo!!!!
    May 2015
    Duluth Mn
    Thanks! Any suggestions as to where I go from here?
    The temps have been in the 50's here; do you think that the wind chill driving at freeway speeds would provide enough cooling to safely get to the dealer?
    Or maybe I should just contact the dealer for their opinion...........
    May 2015
    Duluth Mn
    Thanks!
    May 2015
    Duluth Mn
    Thanks everyone, I appreciate it!
    Jun 2014
    Schenevus NY
    Can't tell whether you have an RS or an ST and your profile doesn't specify which.
    If you can, pull off the right side Tupperware just above the radiator cutout. If you look in you'll see a hose coming from the bottom of the coolant tank going into the top of the water pump; this hose has a worm clamp instead of a crimp clamp. On my ST and several others here, that clamp was loose. A couple of turns of a screwdriver was enough to stop the leak.
    Trb-- (Roger)
    2022 White Pearl F3T
    Spyder States Visited
    May 2015
    Duluth Mn
    Of course, I intended to but was sort of focused, Lol. 2015 ST S Thanks on the color.
    May 2015
    Duluth Mn
    Quote Originally Posted by Trbayth View Post
    Thanks! you are a huge help!
    Oct 2011
    Kalamazoo, Mi
    Yep, sounds like anty freeze. For confirmation find a stray cat and have them taste test it for you. (just kidding)
    New spyders seem to do this, mine leaked a little from the top radiator hose
    2018 F3-T
    2018 F3-T , Pearl White
    May 2015
    Duluth Mn
    Quote Originally Posted by IGETAROUND View Post
    Lol. I may have to see about getting more added, depending on the reservoir size since I have lost a bit. Well, that's tomorrow's job I guess.
    Default ANTI-FREEZE
    If the anti-freeze is low and you have to ADD some .......BRP uses a type ( they claim ) shouldn't be mixed with other types ( I believe them )......Be careful when putting the cap back on it's very easy to NOT GET IT TIGHT and this will cause it to over-flow making the problem worse.........good luck......Mike
    Jun 2014
    ny
    sounds like your is not paper trained
    Very Active Member Darren111's Avatar
    May 2015
    Leeds, England
    Default Colour combo
    If it wasn't for the F3-S, I would have bought a 2015 RS-S with same colour combo has yours. Love the colour combo.
    2019 F3-S Special Series , Liquid Titanium with orange frame
    May 2015
    Duluth Mn
    I hadn't gotten around to (maybe) thinking of that, so Thanks! Lol, I'll probably have to have the dealer mail some to me, tho I'm just guessing.
    I just got my first look at the the cap, so I still have a panel to remove to get to the heart of the matter.
    Jun 2013
    When replacing the cap, it has two detents, so don't stop at the first, keep turning. You should feel both of them before trusting that it is tight.
    Quote Originally Posted by Hayfield View Post
    Amen... This is what Mike was referring to; thanks for expanding upon his explanation!
