Results 1 to 25 of 27
    MelloYelloSpyder
    Guest
    Default AIR PANEL REMOVAL FOR AN INSTALL
    Ok... I know I know...search the forum buy a shop manual. I have been trying to search the forum and well I just can't wait for a manual to arrive. I just received my JT air filter kit and I am trying to figure out what panels need to be removed from the bike. I have a 2013 STS. I can not figure out how to get the top panels off that kinda surround the mirrors. I took off the center panel with no problem and the air deflectors around the mirrors. I also removed a couple of screws one front and one back on that top panel but there is obviously something holding it in place as it will not budge and I am pretty sure that panel has to come off to get the air box out. Any help or pointing me to a video that shows how to remove the ST panels would be appreciated. I see all sorts of videos for the RT but nothing on how to remove them for the ST. Thanks all and happy ryding.
    Start at page 40 of your operator's guide.
    MelloYelloSpyder
    Guest
    I will have another look in the owners manual but I don't remember seeing anything about removing those panels.
    Jun 2013
    Fleetwood, PA
    If you think those panels are hard to get off wait until you get to the OEM air box!! It comes out but good luck! PS, when you are about to pick up the hammer and start swinging take a deep breath and walk away for a while LOL!
    Feb 2014
    Roswell NM
    There is a small Allen or torx bit that needs to come out in front. Under the headlights.
    MelloYelloSpyder
    Guest
    Quote Originally Posted by Craniac View Post
    I saw those two screws under the headlight through the black plastic but wasnt sure if those were the last two holding them in place or if I was missing something else. I think I am going to put this off till next year as the Spyder is going back into her winter lair in about a week or so
    MelloYelloSpyder
    Guest
    Nothing in the owners manual shows how to take off the upper panels. It shows the mid and lower panels but nothing in regards to the panels I was talking about. Thanks for the help though.
    Feb 2014
    Roswell NM
    You also need to remove the mirrors and the black backing panel behind the mirrors.
    MelloYelloSpyder
    Guest
    Damn....how many hours is this going to take. I am beginning to think I should have just left well enough alone. So I now assume that I will have to take the whole upper part of the bike off to get the mirrors off so that I can then take off the upper panels to get the airbox out.
    Feb 2014
    Roswell NM
    Remove the clear wind deflectors. Remove the tupperware on the mirror. Give the mirror a sharp upwards rap from the palm of the hand. The mirror should now be loose. Uplug the turn signal wires. Remove the four bolts that hold the mirror base.
    That bolt under the headlights is a LOT more trouble.
    MelloYelloSpyder
    Guest
    Thanks for all your input..I appreciate it greatly. As soon as spring starts rolling around next year I will get it done. How's the weather in Roswell? Used to live in Clovis when I was stationed at the airbase back in 87-91
    Nov 2012
    North Las Vegas, NV
    Since you are waiting until spring to do that air filter job think about doing the spark plugs and wires while you have the bike apart.
    2016 F3 Limited
    2019 Ryker Rally
    2014 Suzuki V Strom 650
    2020 CSC TT 250
    Jul 2015
    Simi Valley, California
    Wait until you put it back togeather. Trying to get the mirror to catch the top pin is one thing. But then installing the side panel to get the pins in the two rubber grommets is another thing all togeather. They keep pushing out and do not a line. Good luck still trying to get mine back togeather
    Sent from my SM-N910T using Tapatalk
    Jul 2015
    Quote Originally Posted by chiptown View Post
    Quote Originally Posted by MelloYelloSpyder View Post
    Feb 2014
    Roswell NM
    Cold and rainy today.
    What part of Michigan?
    Jun 2010
    Las Vegas
    It can be frustrating to get that panel back in but try starting with the front pin first then bow the panel a bit to insert the rear pin in the grommet. It also helps if you spray a little Windex in the grommet holes first. Good luck.
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
    MelloYelloSpyder
    Guest
    Live in the capital city..
    Jul 2015
    That worked, thanks for the help
    Feb 2014
    Roswell NM
    Have family in Owosso.
    Dec 2014
    florida
    Default take your time
    I just got mine done.. It is a bear.. but the best advice is already on this thread. walk away when it becomes a fight. I studied it for a day or two and after I looked at it from every angle.. it became simple. If you can get an extra set of hands from someone it will be much easier. Thank goodness my son has small hands.. Best of luck.
    a day you don't ride> is a day you cant have back!
    Aug 2013
    SF Bay Area
    I used a Stanley tool similar to this to remove the screws under the headlight.
    Those headlight screws plus screws under center panel and the mirror mount screws with mount plates all have to come out to get top panels off.
    This is what you'll see when you get the panels off. That black wedge shaped thing is the air filter housing.
    2021 F3 Ltd , Magna Red
    Greenville Tx
    I needed one of those tools when I installed my missing belt guard. Ill have to look for one.
    Is your spyder the one they show on the Corbin site? I ordered that exact setup only mine will match my current cognac color.
    2017 F3 Limited
    Aug 2013
    SF Bay Area
    I found my tool at Harbor freight but they're available almost any hardware store.
    Yes, that is my bike on Corbin's website. Corbin borrows new model bikes to configure their seats and other items they make. Corbin had my bike for over two months and the weather was fantastic.
    Very Active Member AbNormy's Avatar
    Apr 2012
    SW Austin
    Costco has them for $10 right now complete with torx bits & some sockets
    Norm H Austin Tx
    2012 RT A&C bought new 42312 sold July 2018 56k miles currently driving a 2014 RTSE6 LTD bought October 2018 w 6800 miles nicely farkled
    2014 RT SE6 LTD , White
    MelloYelloSpyder
    Guest
    Default Biting the Bullet
    Well after doing as much research as I can find about doing this I have decided to leave it up to the shop where I bought the bike to do the install on the JTAirfilter Kit. They said they would do it for about 150-200 bucks. I figure yeah it is a chunk of change but with my temper and lack of patience on doing things this is best left to those that know what they are doing. This shop treats me right and always discounts there shop rate for me as I have been a repeat customer for many years. I am going to go drop it off tomorrow and will post back once it is done.
