Results 1 to 25 of 39
    Springfield, MO
    Default Coming soon for the F3 (air ride)
    Hope to have a very affordable air ride suspension ready to sell in the next few weeks for the F3. I want to make sure I get some miles on it first riding two up and then we will put the kits together. After seeing that they changed the swingarm on the F3-T to give it an air ride option I went forward with a project I already had in the works for the standard F3 and F3-S.
    This system will make the F3 a two up Spyder and will solve any bottoming out issues. It's an air and hydraulic system to give you a smooth ride with max preload adjustment. I'm very excited about this project.
    Sep 2012
    Spokane, WA
    I will be excited to see this one. can't wait.
    Default Good to know.....
    always on top of things..good luck with the project hope your testing will prove it to be great and you can add it to your product line...
    Dec 2014
    NY
    Hope it will be a bit cheaper than the Elkas!
    Great. That will solve one area of discussion.
    What is it going to cost? If you don't have the exact number, how about a ball park?
    Thanks in advance.
    May 2012
    sussex, nj and tug hill, ny (west turin)
    if you need a four hundred pound team of testers, we're available!
    Mar 2014
    Germany
    That sounds awesome!!! I just hope it will be affordable for a poor German college prof😉
    Springfield, MO
    Thanks in advance.
    I'll have options but hope to have the base kit without a compressor for around $300.00
    Oct 2007
    Johnson City TN
    Cool
    Jun 2014
    Atlanta, GA
    Looking forward to hearing more about it.
    Very Active Member Mike,P's Avatar
    Sep 2011
    Wales , Michigan
    Quote Originally Posted by Lamonster View Post
    Any more news on the clutch lever issue (heavy pull) yet???
    Springfield, MO
    Quote Originally Posted by Mike,P View Post
    I just looked and the parts list has not been posted yet. I'll post them as soon as I get them.
    Sep 2011
    Wales , Michigan
    Thx!!
    Vermont
    Good luck with your F3 ( Air ride) project. Give us an update when you can. Deanna
    Gremlin Bell
    SpyderPops Missing Guard Belt
    Ultimate F3 Floorboards
    Sway Bar with Links
    Rolo Laser Alignment
    Half Cover
    Show chrome Trunk Shock
    May 2012
    lamont, is this going to have a spring change with it as well as the shock?
    May 2009
    Connecticut
    When Is BRP Going to address the Clutch you have to be "Rocky?" to Hold down?????
    Sea Doo GTI-SE 90 Jet Ski!!
    Mar 2013
    Oz
    Quote Originally Posted by Sarge707 View Post
    See http://www.spyderlovers.com/forums/s...ghlight=clutch
    Springfield, MO
    Quote Originally Posted by spydaman60 View Post
    There is no spring, this is a replacement shock with full displaced valving for a smooth ride in compression and extention. It's also a lubricated air sleeve for smoother operation.
    Springfield, MO
    BRP is going to list the parts needed to give it the same pull as an RT but it is not a recall or warranty issue. The F3 pulls the way it was designed to pull.
    May 2012
    sign me up for the first one off the line!!
    Springfield, MO
    I got my bushings in and tested my setup and it did not go as planned.
    The good news is I already have the parts on order for a better way of doing this and hope to have the prototype done before the end of next week. I'm 99.9% confident that this will be the ticket for the F3. I have one bracket to fab up and the install will be a snap and give us all that extra help we need riding two up or if you're just a big guy.
    Very Active Member Ron2andia's Avatar
    Jun 2012
    Phila
    Can't wait!
    Live, Love, and Ride! God Bless!
    Oct 2007
    I can't wait to see this available.
    Springfield, MO
    My first attempt failed. The shock I used was not strong enough and I was still going to have to build a safety bumper in case you lost all your air.
    I ordered new parts and I was 99.9% sure this would work and I ran into more issues.
    Today I ordered some more parts and I'm not going to say for sure now but my bike is all tore apart till I get something to work. I didn't think it was going to be this hard. Hang in there.
    Nov 2015
    West Coast, Canada
    I eagerly await updates on this. Are you still looking at a $300 price range or have the problems driven up the costs? Either way look forward to hearing about the progress. Also what kin of compressor are you running?
