Results 1 to 21 of 21
    Active Member SpyDerSts's Avatar
    Aug 2015
    Columbus,Ohio
    Default Serious HI-INTENSITY LED Brake Lights
    . These are called (Tomar Rect-13LS) Tomar Intelligent LED Series. They have a programmable internal flasher with 20 programs. use just shy of 0.4 amps at 12volt.
    Mar 2015
    PA
    Those look great. I have been looking for something like that. They look really bright - would you say that they could be too bright? I am looking for something that bright but not bright enough to "blind" the driver behind me.
    Aug 2015
    Columbus,Ohio
    Default Not too Bright
    Quote Originally Posted by iGot2Fly View Post
    These are the same mini LED lights used on Undercover Police vehicles. They are SUPER Bright and dependent on the position u mount them,they could cause the driver behind you to see spots. I have them mounted in just about the right location so as to Gain Formidable Attention and Be Seen. I have a set on my GL 1800 and I was told that they are almost blinding from behind. I love to make sure my wife is seen when she's coming to a stop. We've noticed people stop a lot further back from us when they see the lights come on.
    Sep 2014
    East Texas
    Default Are they legal?
    Quote Originally Posted by SpyDerSts View Post
    IN my state, brake lights may strobe a maximum of 5 times before they go solid. People stop farther back because they don't know what they are coming up on. Don't be surprised if a police officer stops you and has a "talk" with you about what is basically a strobe light instead of a brake light.
    Very Active Member WA5VHU's Avatar
    Cooper, TX
    Nice and bright!
    If I am seeing it right, the light hanging above the rear tire won't last long as a good bump or dip moves the swing-arm and the back tire/fender up to almost touching the bottom where the light is mounted. I put side cases on my RS and the kit moves the blinkers down to the rear fender and I thought I would be smart and put an extra brake light between the blinkers. Made the first road trip and noticed the brake light had hit the above part and it was broken! Below is a picture before it was broken.
    Charles
    Current:
    2016 Honda CTX700 DCT ABS (faring model)
    Kip Moto SherpaX Cargo Trailer
    Wife Has:
    2014 Can-Am Spyder RT Limited
    2016 Lees-ure Lite Camping Trailer
    Previous:
    2013 Can-Am Spyder RS SE5, zoom-zoom!
    2011 Can-Am Spyder RT-S SE5, Foot Burner - Gasoline Boiling Stinker - Gas Tank Vacuum Puller
    Aug 2015
    Columbus,Ohio
    Default Reply to -WA5VHU.
    Well she's put over 1000 miles with those lights on there, and hasn't broke them off yet... So it seems her STS suspension doesn't move that much. I've followed her and that suspension seems to stay at least 4 inches or better from hitting the light. We've already chatted with multiple Po-lice and there's not an issue with the rate of flashes or type of lights. They are just happy that they aren't swirling...definitely gets noticed for sure.
    Jan 2012
    Menlo, GA. 'Lookout Mountain'
    Aug 2015
    Columbus,Ohio
    Default Tomar
    Quote Originally Posted by Cavman View Post
    we have a physical store that sells to the public these kinds of lights...
    Jun 2014
    Yorktown, VA
    Can they be set to flash a certain number of times then burn constantly?
    Sep 2015
    Metairie, LA suburb New Orleans
    Quote Originally Posted by gparr View Post
    I purchased this tiny module and installed one on my bike and my cars' third brake light
    It is adjustable for both speed of flashing and number of flashes before it goes solid
    http://www.ebay.com/itm/110976580384...%3AMEBIDX%3AIT
    Jun 2014
    Yorktown, VA
    Thanks for that info!!!
    So will the Tomar light burn constantly to be able to work with this module?
    If so, this seem like a MUCH cheaper alternative to some of the other brands out there.
    Jan 2012
    ....and the name of the store is?
    Jan 2012
    Video shows how to set up one of the 41 flash patterns of the Tomar Rect 13LS.
    https://m.youtube.com/watch?v=peIkEaKcpas
    Aug 2015
    Columbus,Ohio
    Yes yes they can
    Oct 2015
    Wales
    Quote Originally Posted by PatriotRider View Post
    But it won't work on a Spyder because of the CAN-BUS system.
    May 2013
    Stanton, ca
    Quote Originally Posted by Big Mac View Post
    And where did you hear this misinformation?
    The lights are NOT on the CAN-BUSS....
    Bob
    Aug 2008
    MA & NH
    Sad that you even need items such as these. If only people paid attention.
    Aug 2012
    CO
    Hmm.. the light sticks and some of the minis - can they be used as aux running lights up front (in white, of course)?
    JLohPhotos
    2008 GS , Millennium Yellow
    Jan 2012
    If you watch the show Castle, I think the lights in the grill of Becket's car has these lights. Quite bright.
    Aug 2015
    Columbus,Ohio
    Default And the Name of the Store Is???
    D&M Distributing 724 east Hudson st Columbus Ohio 43211
    614-268-2222
    dmssp.com
    I just kinda fell outta the boat since I hadn't been riden lately so I apologize that I missed ur question by a long time. .... Sorry bout that.
    Vermont
    Quote Originally Posted by Saluda View Post
    they are there cell phones. Deanna
    Gremlin Bell
    SpyderPops Missing Guard Belt
    Ultimate F3 Floorboards
    Sway Bar with Links
    Rolo Laser Alignment
    Half Cover
    Show chrome Trunk Shock
Tags for this Thread
