Page 5 of 6 FirstFirst 123456 LastLast
Results 101 to 125 of 134
  1. #101
    May 2013
    Stanton, ca
    Quote Originally Posted by Desert Spyder View Post
    Stopped at my nearest dealer re the air scoops today before reading this thread. The service mgr is aware of the recall not the "Good will" recall. He asked if I had anything in writing or was it hearsay. He had no parts in the shop and they won't be ordered UNLESS I leave the bike in the shop, THEN they will be ordered. Basically the bike is a hostage. He said it would cost $300. Not sure if this was parts and labor or what. I mentioned BRP said $75 for parts and $150 or so for labor. Again, nothing on paper. I asked how long it would take to get parts? He said sometimes they are on backorder and may take 3 weeks plus customs. Three weeks hostage for parts? Bull****!
    Take it to another dealer!
    Mike from SRA-LA just had his 2011 done at Whittier Fun Center for free.
    Bob
  2. #102
    Nov 2012
    North Las Vegas, NV
    Just got my kit ordered today for the "good will recall". When the parts come in they will be installed by the dealer.
    2016 F3 Limited
    2019 Ryker Rally
    2014 Suzuki V Strom 650
    2020 CSC TT 250
  3. #103
    Active Member RockyMountainRider50's Avatar
    Mar 2014
    CO
    Default Air scoop intake
    Quote Originally Posted by pslawing View Post
    Has anyone heard of dealers doing any heat recall work on 2012 RT's like they are doing on the 2013's?
    I contacted one of our dealers here in the Mile High who got authorization from BRP to install the Air scoop intake on my 2012 RT LTD at no cost to me. Will be dropping it off on next Wednesday and pick-up on Thursday. Will see if any changes after the install is complete.
    2012 RT LTD & RT-622 , Pearl White
  4. #104
  5. #105
    Apr 2010
    Montreal,QC
    I pay and install myself. Was 73$cnd 85$cnd. Ask you parts service for the scoop only.
  6. #106
    May 2013
    Stanton, ca
    Interesting thing I notice in your pictures and it makes sense!
    The kit provides a tie bar (bracket) on each side for when the Acoustic panels are removed.
    Having removed the acoustic panels before on my 2011 I did notice the bottom part was loose e.g. can move up and down.
    So that tie bar is important!
    You should not remove your acoustic panels without having that!
    Bob
  7. #107
    Nov 2012
    North Las Vegas, NV
    I did remove them Monday for our Tuesday morning ride. No change in the heat at the front of the seat for my wife. Still need those scoops.
    2016 F3 Limited
    2019 Ryker Rally
    2020 CSC TT 250
  8. #108
    Registered Users LoveMyRyde's Avatar
    Jul 2015
    Ocala, FL
    Talking Results
    Quote Originally Posted by LoveMyRyde View Post
    My dealer talked to BRP and they are going to order the kit and install it at NO COST TO ME! This is way more than I expected . They have ordered the parts and said it should take about a week to receive them. Meanwhile I'm enjoying my bike and waiting for the call .
    Had the scoops installed this past weekend. We immediately went for an 80 mile ride. The temperature was in the mid nineties. What a difference . The heat level went from uncomfortably high to barely noticeable! I think they even look cool. Very happy with the fix.
    2011 Spyder RT Limited (Artie)
  9. #109
    GOS member (Girls On Spyders) pslawing's Avatar
    Jun 2012
    Kings Mountain, NC
    Just went to dealer with all my notes from this thread. She said of course!!! We don't even have to open a ticket with BRP we will just order the parts and install them since you are still under warranty! Will call when they are in!
  10. #110
    May 2014
    Benson, NY
    Quote Originally Posted by Mickay View Post
    Did you use the chainsaw to cut the hole for the scoops? If so nice job.
    2015 RTS Special Series
    Russell Day Long seat
    F4 Customs windshield
    Sena 20s
  11. #111
    Jun 2012
    Kings Mountain, NC
    Lake Norman Powersports in NC did mine at no Cost! What a difference! Side panels cool to touch! Loving my machine!!
    Thanks guys for all your input! Your the best!
  12. #112
    Apr 2010
    Montreal,QC
    Quote Originally Posted by Bensonoid View Post
    I cut nothing. I leave the original hole vent. The scoop run the wind through oem hole.
  13. #113
    Knoxville, TN
    Default recall
    YES, and under some circumstances, BRP might cover the cost.
    Seth
  14. #114
    Quote Originally Posted by ravseren View Post
    Seth
    Technically; no...
    I'm pretty sure that what is being done for the 2010 to 2012 RTs, is being handled as an "accommodation" only...
  15. #115
    May 2013
    Stanton, ca
    If you did not cut the panel how did you get the "lip" of the scoops in the hole so the scopes did not have a gap from the panel?
    Bob
  16. #116
    Nov 2012
    Jacksonville
    Default Two Bulletins?
    I read the whole thread and saw reference to two TSTs (apart from the 2013 bulletin):
    TST61Y010S09
    TST#112333
    Are they both correct? I've seen the 2nd one multiple times but the first one referenced just a single time?
  17. #117
    Nov 2012
    Jacksonville
    Default Also..
    For those who have installed the block off plate and knocked out the floor panel beneath it, how does this fix affect and/or interface with those mods/fixes?
  18. #118
    Nov 2012
    Jacksonville
    bump
  19. #119
    Danbury Connecticut
    Technically; no...
    Yes, my understanding is that BRP will cover the cost of installing the vents on the 2010 to 2012 RT's as a "courtesy" warranty.
    This may require a little pull from your dealer, but the RTs with the 998 engine seem to have some sort of heat issue, though not as severe as the 2013 MY.
    I've read of someone installing the vents on a 1330 ACE RT, but this would be at the owners cost should they prefer the vents.
    IBA #47122
    2020 RT Limited Asphalt Grey
  20. #120
    Invalid Emails
    Mar 2011
    NE TN
    Thumbs up Thanks Y'all
    My thanks to y'all and specially Doc-Riverside! BRP will be Good-Will comping me the air vents on my 2011 RT.
    BTW: that will be at East Tennessee ATV in Elizabethton, TN.
  21. #121
    Thanks for letting us know about a successful outcome!
  22. #122
    Sep 2016
    Parma, Idaho
    Default Air Scoops
    Quote Originally Posted by jtoro1 View Post
    My dealer have the scoops kit for. 2012 and earlier $67 got mine,
    Do you have a picture of the Spyder with the air scoops installed? I have the 2012 Spyder RT-SE5. Are these best left for the dealer to install, or can the owner easily install them?
  23. #123
    Dec 2015
    Oakley Utah
    Default Air scoops for RT
    Quote Originally Posted by mustangbob View Post
    Just got mine today, does make a difference, took the long way home and stopped for gas, the cap was actually cool to the touch. All work covered under "good will warranty". Here are the required pictures.
    Thanks. That is a big help in understanding what these look like and how they function.
    2014 RTL Platinum
  24. #124
    Active Member Danz28's Avatar
    Apr 2016
    East Haven, CT
    My dealer said he could put in request and they would do it for them if there was a customer complaint but they are not volunteering the recall for the 2012. I will be doing it this winter most likely... In fall and early spring the heat is kinda nice in New England
  25. #125
    Jun 2017
    Tucson, AZ
    Default RT Vents
    I just went to my dealer her in Tucson, As. They are going to work to get the vents for my 2012 RT-S approved. One of the service writers thinks theyshould have just wfitten the TST for all the 2010 to 2013 models.
    We'll see how it goes.
    2012 RT-L , Blue
