Results 1 to 23 of 23
    Very Active Member eddieshep999's Avatar
    Oct 2010
    Broadstone,Poole, Dorset, UK
    Default Anyone notice this on their RT
    When reversing on my RT SE6 2015 Model I select the 4 way hazard flashers to give extra safety
    I notice when you do this the R icon in the cluster also flashers
    If you don't put on the hazard flashers the R icon remains steady
    Just interested if others have found this as well
    Eddie Sheppard
    Poole Dorset UK
    Get a Spyder - See the World
    Active Member remark2013's Avatar
    Sep 2014
    Los Alamos, New Mexico
    I haven't noticed this, but I will check it out this weekend on our ryde.
    Kent.
    Ride Safe All
    2014 RT Limited (Charlotte) in Cognac, Kuryakyn Grips,Tri-Axis Handle Bars, Rivco Armrests, a "finless" BT Dongle, TricLed Fender, Saddlebag, 3rd & 4th brake Lights, Custom Dynamics "Magic Strobes Brake Flasher", BajaRon Sway Bar & Spring Adjusters, Lighted Bumpskid, Rivco Highway Pegs, Rivco Cup Holders and Baker Built Air Wings. 215/60R-15 General Altimax Rt rear tire. 155/60R15 Kumho Solus front tires.
    Oct 2011
    Kalamazoo, Mi
    My 2014 RS does the hazard lights automatically when reverse is selected
    2018 F3-T
    2018 F3-T , Pearl White
    Invalid Emails
    Nov 2014
    USA, FL, Venice
    Quote Originally Posted by IGETAROUND View Post
    i believe this is standard in Canada and other countries. I wonder why yours is configured that way?
    Default As I see it..!!
    All the ones I have seen turn on the four way automatically when you shift into reverse and the indicator flashes on the dash. This, unless you have backup lights, is the indication you are backing up and gives you some light if dark...
    Jun 2013
    Winchester, KY
    When I had my 2012 RS the flashers would come on when in reverse. Not sure if this is because they aren't as visible as the RT or not. I haven't noticed it on my 14' RTS yet.
    Mar 2012
    NJ
    My 12' RS and my friends 11' RSS both flash in reverse.
    Sent from my SCH-I545 using Tapatalk
    Aug 2013
    Quebec City, Quebec
    Quote Originally Posted by MisterP View Post
    It's not a standard in Canada. Only RS are configurated that way. Another engineer bright idea....
    May 2013
    Edmonton Alberta, Canada
    My 2014 RTL doesn't flash the hazard lights when in reverse...
    2014 RT-Ltd , Cognac
    Had to run an errand right after reading first post so I checked. My SE does not activate hazard lights when I shift into R but I have backup lights. I normally push R button with left thumb and shift into R with a left finger so I even did a two handed shift to make certain I was pushing the reverse button down far enough to make complete contact. If I push hazard switch R flashes in addition to lights. The 14 operator's guide addresses the hazard lights flashing when shifting into R on the SM model but not on the SE. It says in the info on the reverse button that backup lights turn on when vehicle is in reverse. In Basic Procedures section it explains the hazard flashing only when discussing operating in reverse on SM model. A quick look as the '15 operators guide shows explanations are the same as '14 manual.
    Very Active Member robmorg's Avatar
    Oct 2013
    Pottstown, PA
    Quote Originally Posted by eddieshep999 View Post
    From what JayBros says above, the 2014's do this as well. My 2013 RT SE5 does not. You can, of course, turn on the flashers in reverse, but the "R" does not flash.
    Rob
    2013 RT Limited
    My "Mods & Farkles" Link
    May ALL your roads be beautiful
    Greisemer's Mill Bridge, Oley, PA
    2013 RT Limited , Lava Bronze with Antler Brown Seat
    If I'm backing up; I guess I've already got more than enough to worry about!
    Nov 2013
    Oro Valley Arizona
    Quote Originally Posted by Purple Guy View Post
    Nor mine.
    Jack
    2015 BMW R1200R LC
    2014 RTL SE6 Pearl White
    2012 RT-622 trailer viper red
    2011 Polaris Ranger green
    2016 Can Am Maverick
    Vermont
    On my 2014RTS-SE6 my hazard lights do not flash, when I am in reverse either. Deanna
    Gremlin Bell
    SpyderPops Missing Guard Belt
    Ultimate F3 Floorboards
    Sway Bar with Links
    Rolo Laser Alignment
    Half Cover
    Show chrome Trunk Shock
    Vermont
    Quote Originally Posted by robmorg View Post
    my 2014RTS-SE6 the "R" does not flash. I will have to check the next time I go riding. Deanna
    Gremlin Bell
    Sway Bar with Links
    Half Cover
    May 2011
    Charleston,SC
    The RS does not have a rev.Light,so it uses the hazard lights in rev.,the RT have a Rev.(white) light so it does not use hazard lights. did no one notice this?
    Active Member djhobin's Avatar
    Costa Mesa, CA
    Default Flashing Hazard lights
    I have an 2013 ST and when in reverse the hazards have always flashed from day one.
    2013 ST , Black
    Oct 2010
    Just to clear up any confusion
    When using reverse. the twin rear reversing lights come on and the R in the display remains steading
    It's. when I operate the hazard switch manually when reversing that is when the R in the display flashes or course both the Green.arrows in the display also flash as well
    It maybe a safety feature to warn you that the Reverse is selected whilst you are dispylaying the Hazards as most would assume you are not moving due to a breakdown. etc
    Eddie Sheppard
    Poole Dorset UK
    Please remember when you put a '14 SE in reverse two Rs display, one on the analog speedometer and one in the digital cluster. If you push the hazard light switch it's the R in the analog speedo that flashes, not the R in the digital cluster.
    Jun 2010
    Las Vegas
    I don't think my hazard lights flash on my SM. I was going to go out to the garage to check but no one is here to tell me if they flash. I know for sure that the front hazard lights do not flash in reverse.
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
    Sep 2014
    I checked on our 2014 RTL and the hazards do not come on in "R", however if I turn on the hazards while in "R" the "R" does flash!
    Ride Safe All
    Check your manual. This may be a UK requirement. My 2013 RT does not flash the R regardless of which, reverse gear or hazard lights, I turn on first.
    Hazards on... bike in reverse...
    Nothing was flashing!
