Page 6 of 8 FirstFirst ... 2345678 LastLast
Results 126 to 150 of 182
  1. #126
    Active Member TCBoone's Avatar
    Dec 2022
    CA
    Default Important Update! – new Turn Signal Button Installation Instructions
    New Turn Signal Button Installation Instructions
    As the weather has started to warm up there is a possibility that the Turn Signal Button may become loose.
    It is strongly recommended as a precaution to apply a small amount of E6000 adhesive or something similar.
    It is a permanent adhesive that can be removed should the need arise in the future.
    This should solve any issues from prolonged sun exposure during the summer.
    2022 RT Limited Deep Marsala Chrome
  2. #127
    Aug 2018
    Piperton, TN
    What is so special about E6000? Why not Gorilla glue or Super Glue?
  3. #128
    Dec 2022
    CA
    The use of E6000 adhesive is only suggested, it would be ok to use something similar.
    The use of super glue would not be advised because it does not work well with plastic/rubber, it is not intended for porous surfaces.
    The version of Gorilla glue would need to be the epoxy adhesive.
    E6000 is suggested because it is tough, clear, and works well with TPU material.
    For more information on E6000 check out this link.
    https://craft-art.com/e6000-glue-review-and-guide/
  4. #129
    Apr 2023
    TX
    Great ideas for both mods; where can I obtain them?
    Thank you…
  5. #130
    Quote Originally Posted by SpiderBob View Post
    Thank you…
    See the very first post in this thread...
  6. #131
    Nov 2021
    NJ
    I acquired the directional button/shifter pad together from FrogmanDave. The shipment arrived in a couple of days and I tried out the Shift Pad on a 175 mile ride. After the ride, I had no pain in my left hand. Usually, the next day there is something like an ache or pulled tendon in that hand, because of an old injury, but this time there was nothing. I have not installed the directional button, because I don't seem to have a problem with cancelling the signal, but bought it too, just in case. I have been riding for many years and my first motorcycle, a 1976 Honda CB550, had a very annoying, factory installed buzzer connected to the directionals. As annoying as it was, it instilled in me the compulsion to cancel my directionals as quickly as possible, so maybe it served a good purpose after all.
    Last edited by Peter Aawen; 04-30-2023 at 03:35 PM. Reason: Removed other member's personal info iaw Rule 6 :-/
  7. #132
    Dec 2022
    CA
    Thank you everyone for posting your feedback.
    Please remember to not post personal information.
    https://www.spyderlovers.com/forums/...hp?do=vsarules
    Thank you
    Safe Riding
    TC
  8. #133
    Active Member MNBK's Avatar
    Mar 2017
    Circle Pines, MN
    Just installed the directional switch button on my wife's and my F3L's. Easy to do and just tried them in the garage and seems like a much-needed change.
    Dave....
    2016 Red/Black F3T w/ Audio
    Bajha Ron Swaybar, BRP driving lights
    F4 Windshield, Ultimate Tallboy Seat
    BRP Passenger Backrest
    Custom Dynamics fender lights
    Tricled Rear Bag lights w/ Flashing Brake Modulator
    Wolo Horn, Lamonster's Bungee Buttons
    Spyderpops Bumper Skid
  9. #134
    Sep 2020
    Beaver Falls, PA
    I finally got to ride with the new turn signal button. It's so much easier to cancel without just switching to the other direction. I also find it easier to activate the turn signal over all. Got the shifter pad also but haven't used it yet. Overall an excellent upgrade. Thanks for coming up with this.
    2022 RT Limited Deep Marsala/Chrome
  10. #135
    Feb 2020
    illinois
    Update, since installing the new improved switch button for the turn signals, I must of used it 100+ times. I had issues with the 2020RTL signal button not hitting the sweet spot all the times. Same with the 2022 F3L Limiited. Now, I have not missed it not once since switching to it. A little engineer tweek to the oem button has made a big difference at least for me after riding Harleys for many years.
  11. #136
    Active Member Jesster72's Avatar
    Oct 2021
    IL
    I added my drop of E6000 over the weekend, ready to head out on tour Friday!
    2022 Sea to Sky
  12. #137
    Feb 2020
    illinois
    Update- since installing revised turn signal switch button, I have not once had an issue with it. With the oem button, one had to be dead nuts on center to cancel or would turn on again or turn on the opposite side signal. This revised one hits the sweet spot every time with hundreds of cancellations now performed. Great job at re-engineering.
  13. #138
    Active Member johnv50's Avatar
    Jun 2018
    Tonawanda, NY
    Can anyone let me know the current source for these mods?
    Can not seem to contact Dave, the original maker.
    USMC RETIRED
    BLUE KNIGHTS NYV
    2022 F3T Glacier Blue Metallic
  14. #139
    Dec 2022
    CA
    Quote Originally Posted by johnv50 View Post
    Hi John
    Sent you a PM
  15. #140
    May 2020
    E. Central Illinois
    Requested both the t.s. and shift pad from Dave. I received them in a couple days and installed them. What a difference! Especially the turn signal button. You can be assured the signals are canceled. Because I have relatively large hands and long fingers, reaching the shift paddle wasn't a problem, but the addition of the pad puts the paddle directly under my thumb for effortless shifts.
    The signal button should be standard equipment. The shift pad would be very useful to someone with smaller hands and shorter fingers. That being said, I'm not going to remove it.
    Both are great products. Thanks TC and Dave.
  16. #141
    Very Active Member Peacekeeper6's Avatar
    Sep 2019
    Reno, NV
    If you have small hands like I do, this small mod is worth its weight in gold.
    Definitely the best bang for the buck mod !!
    SIGNATURE PIC CURRENTLY UNDER CONSTRUCTION
    2016 Toyota Sienna SE - hers
    2002 BMW 325i - his
    1994 Chevrolet Silverado K1500 Sportside Z71 - whoevers vehicle is in the shop
    2009 Harley-Davidson Sportster XL883 Low (Vivid Black) - his
    2018 Can-Am Spyder RT Limited - hers
    2007 Harley-Davidson Sportster XL883 Low (Pearl White) - hers (SOLD 02/29/20)
    2011 Tao Tao 50 - whoevers bike is in the shop
    2007 Reinell 186 FNS - the dog's
    1995 Fleetwood Flair 27R - EVERYBODY'S !
  17. #142
    Sebring, FL
    Turn Signal Button Improvement
    I have lost mine on a busy street. Can someone point me to the guy that's making them?
    Last edited by Peter Aawen; 11-11-2023 at 03:22 PM. Reason: Moved Post title into text after merge - post titles mess with Searching! ;-)
  18. #143
    Dec 2022
    CA
    Hi bikerbillone,
    Sent you a PM
  19. #144
    Jun 2022
    AZ
    This really sounds like a great solution to the problem. I guess I'll have to PM TCBoone.
  20. #145
    Sebring, FL
    TCBoone, Dave handled this 'lost item' in a very professional manner. He put a new 'revised' one in the mail and it ain't gonna fall off in a busy street. ....Thanks Dave.
  21. #146
    Active Member Poppie65's Avatar
    Jul 2023
    Springfield, OH
    I requested both items Friday evening and they arrived on Tuesday, that's downright exceptional. I won't be installing them until I take the cover off, but when I do it'll be the first mod.
    Thanks guys, much appreciated!
    2023 S2S
    Shoei RF-1400 Helmets
    Cardo Freedom 4x comms
    Both riders USMC vets
    2023 Sea to Sky , Green Shadow
  22. #147
    Jul 2010
    Las Vegas, NV
    Good idea! It solves a problem for many people, and that is exactly what this forum is about! Thank you for sharing your find! Joe
    Joe Meyer
  23. #148
    Northern Kalifornia
    Since my first post on this thread back in January of this year I hadn’t paid much attention to it until today. 147 posts!! WOW, a common problem. Yeah, hopefully, BRP has caught on. I don’t know. Such a small improvement and such a seemingly large problem and potential safety issue. As I mentioned in my first post #25, I don’t seem to have the problem that other posters have. I agree that 30 seconds is a long time in heavy multi-lane traffic when signaling and changing lanes at 60/70 MPH. Safety comes first! So, I began to rethink why I didn’t have the same issue; and then it came to me. Long ago I had Joe Meyer (Squared Away) install a small light strip on top of each of my rear-view mirrors connected to my turn signals. Easy for me to see and my rear-view mirrors are always in my peripheral view and my left thumb is always at or near my turn signal button. Everything works in unison and it all just seems second nature to me.
  24. #149
    Jul 2023
    Springfield, OH
    Installed! Easy-Peasy.
    My wife will appreciate the shorter reach on the shift paddle, and we'll both benefit from the turn signal mod.
    2023 S2S
  25. #150
    Aug 2019
    Stoughton, WI
    Both PM/email sent to TCBoone to get these items
    2022 RT Sea To Sky
