Results 1 to 8 of 8
    Default New Riken rear Tire review
    So before my vacation I had all tires re-placed .... Q-5's on front at 17 PSI, and my newly discovered RIKEN HP in 215/60-15 size... using 18 PSI ... In the dry, all auto tires will give good traction ( some better than others ) however WET driving can be quite different ..... So during my trip I actually drove in a couple of " gully washers "...... Although these tires sell for quite a bit less than the Altimax, and way less than Michelin or Vredestein .... they performed impressively. I could drive faster than I thought I could ( pulling a trailer 185 lbs total ). From a stop I didn't spin the rear tire, even when I launched with more throttle than needed. ...... For those of you who like the look of a 215 but not the price, I highly recommend the RIKEN.... The front Q-5's also did exceptionally well, but that was expected. Everyone here has been happy with them ...... I only did a bit over 750 total miles, so I'll keep you all posted as the miles increase. For those of you who aren't familiar with my tire choices.... I have been picking winners since 2013 ...... good luck ... Mike ........ Correction ..... I meant to type RIKEN not Riker .... but I can't change it .... But an administrator can .....please do ..... Mike
    Feb 2022
    very southern tip of Texas
    Installed the Riken (not Riker) Raptor HR 215/60 on my Daytona last week, as well. Pressure set at 18psi. So far, so good. When get my ContiProContact fronts on later this week, will be able to wring it out a bit and see how much better the performance is. Only rode about 2 minutes on wet roads so far, so nothing to add on wet traction here.
    White 2015 F3-S SE6 - “Gypsy” (hers)
    Yellow 2017 F3-S Daytona 500 SM6 (his)
    Oct 2013
    Wood Village OR
    Mike, will that Riken work on our 2021 RTL ?
    2014 RTL , Black Currant
    Quote Originally Posted by easysuper View Post
    I just answered your E-mail ..... Yes it will, PS, I had mine mounted ( did not remove center Hub only rotor ) ... and DID NOT HAVE IT BALANCED and it isn't vibrating. .... I think I've found another winner ..... Mike
    indpls in
    Just put one on my '21 RTL after 14750 miles on the original. Putting one on the wife's '21 RTL tomorrow. She has 15100 miles on hers. Used 15 oz of Ride On.
    Quote Originally Posted by fatboy View Post
    For Everyone's benefit please post some reviews ...... lots of folks like actual rider comments ...... Thanks ...Mike
    Very Active Member irvin48's Avatar
    May 2016
    mt morris il
    why 215 tire instead of 225/60 ?
    [joyce & irvin toms]
    Active Member shakin_jake's Avatar
    Nov 2011
    north central Fla.
    ~~~~14750 miles on the original rear Kenda? If so, thats impressive
    Best,
    Jake
    Reddick Fla.
    It’s never too late to have a happy childhood
    2021 Can Am Spyder RT Limited
    2020 Rally , Black
