Results 1 to 10 of 10
    Sep 2018
    greensburg,pa
    Default Friction tape in toy hauler?
    Im getting to old to fight gravity every time I back the spyder into the toy hauler. The linoleum floor already took a hit last year so I need some wisdom if Friction tape would help and what kind would be recommended. I think the wider the better.....6 Inches.......It rained in Erie, PA on Monday morning so it was tough getting her back in.....
    Thanks everyone!
    2018 RT-L , Blue
    Aug 2018
    north wis
    The non-slip safety tape has a lot of bite to it,have used it for a lot of things and that should help! If it's not enuff you may need to go to 1/4" expanded metal mesh.
    Sep 2018
    greensburg,pa
    Quote Originally Posted by woods View Post
    Never thought about the mesh!
    2018 RT-L , Blue
    Faribault, MN
    Most big box DIY stores sell adhesive backed non-skid tape for stair treads in garages and shops and the like, it's often 6 to 8 inches wide and you only need one tread's worth to lay down the middle.
    Amazon has a pack of 6 in https://www.amazon.com/Slip-Guard-No.../dp/B01HQXNBHW
    Safe Rides,
    David and Sharon Goebel
    Both Retired USAF Veterans
    IBA 70020
    Linden, CA
    I stock this stuff up to 30 in. wide and 10 feet long.
    Active Member ozarkryder's Avatar
    Nov 2018
    Anderson Missouri
    We had time backing our RT into our 5th wheel toyhauler last weekend. Ended up having to get a run at it to get it up the ramp, even though the ramp is made of that non-skid sandpaper like stuff. The wheel would just spin about half way up the ramp. Thought about it for a while, turns out it is just physics. Backing up the ramp effectively unweights the rear wheel, so no gription. Went up the ramp forward, and it just walked up into the garage liked it wanted to be there with the weight shifted to the rear wheel. Problem is I had to rearrange the garage so the Spyder woud fit and tie down.
    2018 Can Am Spyder RT Limited, 2013 Triumph Bonneville T100
    Motorcycle Rights: AMA Charter Life Member, MRF, FORR Life Member Local 11 Southwest Missouri, Mid-South MILE organizing committee member
    2018 RT Limited , Got one, on, then off then on until Gloria decides if she likes it or not. blue
    May 2017
    Mesa, Arid-Zone-A
    I have used the sticky-back traction strips for other applications and burned right through it. It may be OK for what you are doing. But, I would use the corrugated metal to insure good traction even when wet, muddy, or heaven forbid, snow. It's inexpensive, easy to install and durable..... Jim
    Semper Fi
    Active Member Dmetcalf's Avatar
    Jun 2017
    Texas
    We had a toyhauler that required me to back up the ramp to place it in place. That was a tight fit (as yours looks to be) and took some nerve when those front fenders entered inside it. I too used the same application of sand type tape on the floor for added traction
    2016 RT-Ltd
    Bajaron swaybar
    Spyderpops trunk light
    Elka stage 2 front shocks
    Extra longbrake pedal
    brake modulator
    Rivco dual flag holder
    with American and Texas flags
    Lamonster Magic Mirrors
    missing belt guard
    Lamonster led fog lights
    Baker air wings
    2019 Silverado Duramax dually
    2019 Cyclone 4007 toyhauler
    Rivco brand footrest
    spydermanexhaust.com exhaust
    Nov 2014
    Hammond LA
    Amazon has non skid stair strips with adhesive to stick to floor and 80 grit that will work just fine. 6" X 20", 5 in a pack for $16.00.
    PA-Pennsylvania
    This might be too aggressive, but it works great for snowmobiles and I don't slip at all driving my RT-L up the ramp.
    https://superclamp.net/product/super-traction-grid/
    2018 Spyder RT Limited , Champagne Metalic
