SpyderLovers Founder
New for the RT SE only
They have added a vibration dampener on the RT SE to help reduce any feed back that might effect the shifting. I've already been asked if this will do anything for the RS but the motor is mounted a lot different on the RT and that is why this was added. Thought this was some good info.
RT-S # 352; Timeless Black... faster than any other color. Mods: EasternBeaver PC8 Fuse Box, 12v digital dashboard display, RearTrunk internal Lights.
Pioneer XMP3 hardwired, KewlMetal highway foot rests, PolkAudio Speaker upgrades (dxi525 & dxi400), Custom Garmin Nuvi bracket and wiring, Panel Savers, Custom LED array third brake light and rear signal LED's. Custom mud flap lights. Daytime Running Lights (3wattsx6). Heated Corbin seat with 'Lamonster' cut. JBL 400watt Amp,
Other secret mods.
Originally Posted by Sopher
What about the RT SM ?
Like the title says, it's for the SE only and has to do with the shifting.
Registered User
Great info Lamont, thanks for passing this along. I would of asked the same question for the RS.
Parts online shows the same part #'s for SE and SM models.
sprocket 28 tooth, 705501201
flywheel, 705501235
flywheel, 705501235
I'm just going by what I was told yesterday. Maybe they decided to add it to the SM too and he didn't know that.
Is this damper a new product to be retrofitted to the RT S-E?
I just dropped my #528 off today for initial service. Is this already installed or should I mention it. I just completed a 900 mile run from Southwest Mississippi to LA (LA around here meaning 'Lower Alabama'!) and noticed there was a fair amount of vibration.. bike is too new to know what 'normal' is. (Brother in law rode back seat about 10 miles and said his feet vibrated.)
Found out I do need to set the shocks to max, but otherwise, the RTS runs like the proverbial bat out of heck. Had a good time.
Vibration Dampner
When was this added?
have they started shipping the new spyders with them yet?
How can I get one?
Thanks
Westgl
How can I get one?
Thanks
Westgl
If you have a SE RT you should have this. Have you looked?
Lamont,
Surely you jest. I wish I was half as mechanically competent as you are. Plus the bike is 150 miles away in the shop for initial service. I merely was inquiring as to whether this was something new or something that should be retrofitted.
Cappy
Vibration Dampner
I bought my SE in January 2010
I dont know when they started shipping with them.
I have not pulled my Spyder apart.
Can the Dampner be seen when a 600 mile service is done??
If so i may try to be they when the dealer does the 600 mile service.
Westgl
put on some old clothes , grab a flashlight , go lie down beside your bike and look around till you find the sprocket and it will be obvious which one you have .or you could pay your dealer 50 bucks to look , your choice .me , my bike does not have this new sprocket but i think i want one .
My 2010 RT SE was built in April 2010 and it has the vibration dampener.
New "Flywheel"
If you look in the “What’s New” section of the 2011 RT shop manual, you’ll find a picture of the new “flywheel” (as BRP labels it) with the following explanation:
“What’s New: Primary drive, PTO flywheel. Running change in 2010 to SM5 models. 2010 RT SE5 models all had this system. All 2011 models have this system.”
“Why: To reduce vibration level to riders during acceleration.
Notice: There are also internal changes involved. Do not attempt retrofitting models not equipped with output pulley flywheel.”
The photo shown in the manual matches Lamonster’s photo and matches what is on my 2011 SM5. If you’ve got an early 2010 SM5, you’d best not try to retrofit this.
Now maybe the new 2012's like Lamonster's took this a step further and the flywheel is different from the 2011's but at first glance it looks the same and the explanation in the manual seems to agree with what Lamonster was told, just that it happened about two years earlier. I guess a look at a 2012 manual for part numbers would tell the story. I checked part numbers for 2010 SM and SE versus 2011 SM and SE and they are all the same as detailed in an earlier post. The manual reflects the running change made during 2010 and does not show the earlier part on early 2010 SM5's.
RT and Gold Wing States & Provinces
Correction
Scratch my comment about "two years earlier". I saw the recent posts and thought this was a current thread. Now I looked at Lamonster's original post date and see it was early 2010. That makes the info he was given totally consistent with the info in the 2011 manual as detailed in the previous note. Probably has no relevance to his new 2012 at all. Sorry about the confusion.
