VALVOLINE FULL SYNTHETIC ON SALE
People here have asked to be told when WALMART has the " 4 T - stroke " in six-pack on Sale. Well it is ON-LINE in 20w50 @ $42 = $ 7.00 per Qt....... I add one Qt. to each oil change to increase the viscosity ...... Mike
Thanks...
Thanks for the heads up and letting everyone know when and where the deals are... it is a great deal for an excellent oil....
2012 RS sm5
Hi Mike,
Re: I add one Qt. to each oil change to increase the viscosity
Could you explain this further?
Do you add one quart to the other oil you put in, i.e., 3 1/4 qts of regular oil ( or whatever is req'd minus one qt ) + one qt of this?
Do you add one quart in addition to the other oil you put in?
Jerry Baumchen
'I'll never forget what's her name.'
'Things are more like they are now than they ever have been before.' Dwight Eisenhower
2008 GS SE-5
Why do you want to increase viscosity? Does it help bike run cooler in hot weather?
VISCOSITY
Originally Posted by JerryB
Hi Mike,
Jerry Baumchen
....I have the 1330 so it's 4- Valvoline 4T- stroke full syn 10w40 + 1- 20w50 ......5 Total ..... From reading ALL the LAB tests others have done .... it appears the oils start to lose viscosity at about 3,000 mi., I change at 5,000 so I add the 20w50 as an insurance measure ...... It's full syn , so it's not really much thicker than 10w40........( I think ) ...... Mike
viscosity
I also have the 1330 engine ( 2014RTS-SE6)and I also use the Valvoline 4T Stroke Full Synthetic sae 10W-40 in my spyder. I changed to the above last year.
This oil is for" Superior Wet Clutch Protection".
Synthetic formula maximizes power and acceleration,
outstanding wet clutch protection for maximum power transfer & smooth shifting,
Added protection against harmful deposits that can decrease engine performance,
Excellent wear & corrosion protective to help keep the engine performing its bests.
Exceeds API Services SJ/ SG/SF, JASO MA2.
Deanna
Gremlin Bell
SpyderPops Missing Guard Belt
Ultimate F3 Floorboards
Sway Bar with Links
Rolo Laser Alignment
Half Cover
Show chrome Trunk Shock
I always like to add a quart of peanut oil and a pint of kerosene just because I know those so called engineers and chemical engineers are really stupid and, like cooking, oil science is really just a matter of taste.
The Power of Logic.
Start Thinking.
For the last few seasons I've been running 20/50 completely in my 990. It's the same rotax Aprilia uses and they spec 20/50 in a much more demanding platform. I sometimes drop to a 50/50 mix of 20/50 and 10/40 to run over the winter. BRP is notorious for spec'ing all their machines for use on shared seasonal oils. Makes it easier for dealers to stock oil and idiot proof for consumers doing their own maintenance. While it may work, it also may not be the most ideal. It is easy though, and no issues with however one chooses.
Sent from my Nexus 6 using Tapatalk
Mike, the Rotella T6 has superior resistance to shear viscosity breakdown vs the Valvoline. Its also MA-2 rated for your wet clutch. Since you have a 1330, you would be dollars and oil quality ahead to use Rotella T6 vs the Valvoline motorcycle oil. We do use the Valvoline in the V-twins to meet the BRP spec for those.
ROTELLA VS VALVOLINE FULL SYN
................JC, I switched from the T-6 to the Valvoline because the "V" contains the second lowest amount of " Moly " ( Amsol is lowest ).....I can adjust for " shear ", I can't do anything about Moly ....... Mike
INFORMATIONAL POSTING
Actually what's really STUPID is your POST..... it's OFF topic because it's not meant to be HELPFUL or INFORMATIONAL ...... It's sole purpose is/was to be MEAN /NASTY to ME..... Since there are no smiley or laughing emoji's it wasn't meant to be funny or a joke. Why you PERSIST in this behavior is beyond my comprehension. If you don't like MY posts ....STOP READING THEM .....they have nothing to do with YOU ........... best regards ..... Mike
THE " moly " THING
When I was a lad back in the mid last century I read that in the high Arctic & low Antarctic, drivers of large machinery would use kerosene as their lubricating oil because the then available oils would turn to grease at the low temps.
They also lit fires under the oil pans.
Maybe they used peanut oil as well but more likely they drank that.
2008 GS SM5, Full Moon Silver
2007 Piaggio MP3 - 250cc
My company used to do a lot of work in a refinery. While doing some modifications in their blend house, their engineer told me "one thing you never want to do is mix viscosities because you never know what you will end up with." After reading here how some people add a heavier oil to increase viscosity, I contacted Valvoline asking about the different specs for their oil. This was their reply:
Though we do have products that cover the JASO MA, unfortunately we do not produce any in the 5w-40 viscosity. Since this is not produced and we do not recommend mixing the viscosities, we will have direct you to motorcycle shop or dealership for the appropriate fluid.
While true as to their 5w-40 oils the oils under discussion here are 4T 20W 50 and 4T 10W 40, both of which as per Valvoline's own labels do meet JASO MA 2
Happy TRAils/NSD
Paul
2012 RT L
AMA 25 years Life Member
TRA
PGR
Rhino Riders Plate #83
Venturers #78
TOI
Besides this is not an oil thread,this is just one member letting the rest ofus know where an oil we like is on sale and a reason why he buys it. Buy it or not your money your choice
Happy TRAils/NSD
Paul
2012 RT L
TRA
PGR
Venturers #78
TOI
Has anyone sent in a sample of the "Valvoline Full Synthetic motorcycle oil 4T stroke SAE 10W-40?
If so what were the test results?
Deanna
Gremlin Bell
Sway Bar with Links
Half Cover
The Power of Logic.
Start Thinking.
HUH
Oh Mike you are simply adorable.
The Power of Logic.
Start Thinking.
How you can take facts and twist them.
You could, if you were younger, get a job at one of the cable news networks that are so adept at changing facts.
Thanks so much for the belly laughs, kindly IM me with the proper emoticons to use so my post will be up to your standards,
Thanks again.
The Power of Logic.
Start Thinking.
