Sorry... That's normal, and your bike is idling at the correct setting.
The clunk is what all of these; and all other motorcycles do...
Nope
To quote a Tome Petty song...."Its just the normal noises in here!" You will notice that when you go from reverse to first the clunk is gone, but once yiu get used to it, it is your verification that the gear is engaged and you are on your way to FUN!
Constant mess
Motorcycles use a Constant Mesh Transmission. All gears are always engaged. This means when the engine is running (idling) the primary and secondary gears are all turning. The clunk you hear is the Dog Clutch sliding into a rotating gear. Motorcycles use this type of transmission because they are compact and shift sequentially, so you don't have to worry about an "H" pattern shifter. The clunk is normal.
1998 Honda Valkyrie
2006 Mustang GT. Varooooom!
US Navy Veteran
Member: American Legion
the idle cannot be adjusted. clunk is normal
That's the way it is....
They all do it but some a bit noiser than others. The big twins are the worst but they are built to work that way and you need not worry about it. It is only in reverse or first then your smooth
what kind of oil you using in the bike?
Gear Clunk
I am using factory oil at the moment. Would you believe the dealer could not say whatthe factory oil weight is?Dray
Is It Normal for the RT, Too?
I've got a 2012 RT-SE5, and it clunks when going into first from neutral. Doesn't clunk when going into reverse, only into first. Is this normal for the RT with the 990 engine?
I've had about 15 bikes in my life. They all had constant mess transmissions and they all "clunk." It's the nature of the beast. My 2011 RTS clunks in first and reverse. Yours will start clunking in reverse soon.
1998 Honda Valkyrie
US Navy Veteran
SpyderLovers Sponsor
You might try setting the clutch lever to one of the settings that are farther from the grip to give your clutch a longer stroke.
If you're going direct from 1st to Reverse or vice versa you don't get a clunk.
Clunk is Neutral to 1st or Reverse.
It is disconcerting but quite normal.
| 2015 F3-S | Heated Grips | USB Ports | RAM X-Grip | RT Sway Bar | '2 Up' Rear Shock | SHAD Bag Kit | Oxford Aqua 50 Dry Bag | BRP Rider Backrest |
