Results 1 to 18 of 18
    Jan 2016
    Rochester,NY
    Default Replacement front tires
    I have one damaged front tire on my 2015 RS SM5 and I'm looking to replace both fronts to keep them the same. Searching through the forum for replacements, the one to get seems to be the Kumho KH16, in a different size than the standard Kenda 165/55R15. I see 18# was mentioned for these. They are $67 each, before I make the plunge are there better ones out there or any problems with these for my RS, advice?
    Kumho Solus KH16 Radial Tire - 155/60R15
    Everyone loves pictures, so here's what an axe can do to a tire at 70mph.
    Bryant, Arkansas
    Quote Originally Posted by Graptor View Post
    We did not "AXE" for any pictures
    Cruzr Joe
    Default FEDERAL FORMOZA
    SpyderAnn who really racks up the miles ( 100,000 + ) liked these for Her front tires on Her RT ..... I 've seen them on E-Bay with Free shipping item #131920062070 ...two @ $117.00 ( $ 58.00 ) or best offer , this is a "V" rated tire .....................just a thought.......Mike
    Default Ooooo...!!🤔
    You have a lot to choose from... although the Kendas do a good job up front. I have run two sets and they get great mileage and handle well for me...bummer about the axe....glad you and the spyder managed it as well as you did....
    Gene and Ilana De Laney
    Mt. Helix, California
    ​2012 RS sm5
    Jan 2016
    Rochester,NY
    The Kendas are hard to find and expensive
    Jan 2016
    Rochester,NY
    I see them, nice price too. You had no problems? I ordered them up, being from around the corner, I'll just take your advice.
    Quote Originally Posted by Joel The Biker View Post
    I have Federal 595EVO front tires in the stock size and love them!!
    You can find them on ebay.
    Default THE EVO TIRE
    SpyderAnn had the EVO and didn't like it - She said the Formoza was much better , but then She ONLY has 100,000 + test miles on Spyders ..............Mike
    Jan 2016
    Rochester,NY
    Thanks for all the advice, the free shipping gets me every time :-)
    Vermont
    I am running "The Continental Contiprocontact" Size: 165/60 R15 on the front of my 2014RTS-SE6.
    I bought them this year. I am happy with them, the spyder handles great in the rain, and on dry roads. I am running them @ 19PSI. Here is are some pictures: New Front Tires ( Continental) 009.jpg New Front Tires ( Continental) 014.jpg Good luck!
    Deanna
    Gremlin Bell
    SpyderPops Missing Guard Belt
    Ultimate F3 Floorboards
    Sway Bar with Links
    Rolo Laser Alignment
    Half Cover
    Apr 2011
    GREENVILLE, SC
    Houston
    Deanna
    We have installed a number of sets of those and have been very happy with them. Then we discovered that the 175/55-15 in the same tire line is actually a better fit. Strangely enough its overall width is actually narrower than the 165 but the tread contact patch is wider due to the better aspect ratio. Diameter of the 175 is an exact match for the factory tire.
    There is also a Yokohama 175/55 that I intend to give a try. Good looking tire and would pair well with the Yoko rear.
    We do not recommend nor install cheap Chinese tires on bikes. Stick with top tier brands. Not Chinese copies.
    Blue Flame Spyder F3-S
    2015 F3S , Blue Flame
    Vermont
    Here is an other picture of the Continental Contiprocontact tire on my 2014RTS-SE6: New Front Tires ( Continental) 013.jpg space the same thickness as my finger. Sent pm. Deanna
    Gremlin Bell
    Sway Bar with Links
    Half Cover
    Jun 2010
    Las Vegas
    I do really like the Federal Formoza. It is available in the stock size and I found the handling is much better than the Kenda or the Federal Evo. I bought mine at newegg.com
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
    Sep 2014
    USA
    been running the Federal Formoza Tires on mine and been happy with the handling since the switch.
    Active Member nslowmotion's Avatar
    May 2015
    https://t.me/pump_upp
    Default front tyre
    Do you like the Formoza or the Kumho Kh16 better?
    May 2017
    GULFPORT MS
    Default TIRES WEARING OUT
    I have a 2014 RT Limited with 32k miles. The front tires have wear on the inside tread and almost no wear on the outside. I want to replace with Michillen or Bridgestone or Perilli. Can't get the tire guy to change from 165/55 to 175 or 185. Any suggestions? I am about to take a east coast tour and need to get new shoes.
    Very Active Member bcer960's Avatar
    Jul 2016
    Kamloops B.C.
    [PHP][/PHP]
    I can't believe no one else asked........ how does an axe hit your tire if you are doing 70 mpg???
    2017 RT-S
    Bump Skid - Spyderpops
    Wrap - Wrapmyspyder
    swaybar - Bajaron
    Sena 20D & SM10
    3 PC Mesh Zippered Lid Net Set - TricLED
    A arm LED's - Safety LED's - TricLED
    Mirror Sequential turn signals
    Glo-riders
    LED rear turn signals and reverse lights
    Front Grills
    Third Brake light
    Larson Scanner
    Light Up - Sue Hopper
    Default TIRE ISSUES
    Quote Originally Posted by DOC BARNES View Post
    You have a typical alignment issue and should find someone who does the ROLO / Tru Trac LAZER alignments ..... check the HOME page ( SQUARED AWAY ) ......... have the alignment done before you change the tires - otherwise the tires will be ruined ........ There are front tires ( NOT KENDA's ) out there in the OEM size ( or very close ) that you can use without any fitment concerns............ Mike
