How did you hook up SM10 to the radio? With the cable that comes in the kit from BRP. Make your own custom cable. Get the cable from Motorcycle Dave.
2018 F3 LIMITED
Originally Posted by Spyder33
May seem obvious, but the SM10 needs to connect to the entertainment center. Hopefully you got this wire from Motorcycle Dave when you purchased your SM10.
Yep! Bought the SM10 & cable from motorcycledave
If the radio is muted. That will mute the feed to the SM10. Except for GPS alerts. So make sure it is not muted. Volume has no effect on the headset volume.
2018 F3 LIMITED
Hearing music thru bike speakers but nothing thru helmet speakers
Have you played with the volume setting of the headset while radio should be playing.
Keep in mind that volume setting while speaking with passenger is different from setting for the radio, each must be adjusted while that function is active.
Spoke with Sena today and they suggested factory reset on headset. Came in did reset, repaired units and Bam! Finally, sound in speakers. Thanks for your suggestion.
Tags for this Thread
