Results 1 to 25 of 25
    Oct 2016
    Faribault, MN
    Default Does IPOD in trunk connected to Audio Input draw power when bike is off?
    OK, I forgot to remove my IPOD (connected with the Factory adapter) in the trunk when I put my Spyder RT Limited in winter storage.
    Does it draw any power at all while the bike is shut down?
    It's stored in a environmentally controlled locked storage unit that's not easy to access until spring...
    Safe Rides,
    David and Sharon Goebel
    Both Retired USAF Veterans
    IBA 70020
    Active Member woodyaa's Avatar
    Mar 2015
    Harvard, Il
    The iPod is powered and charging while your ignition is on. When off no power goes to the iPod and if you don't power it down, its battery will go dead over the winter. The spyder battery is safe.
    Oct 2016
    Faribault, MN
    Thanks, I wasn't even thinking about that IPOD battery, so concerned with the Spyder's battery.
    Guess I gotta go get back in the storage unit.
    Safe Rides,
    IBA 70020
    Feb 2016
    Jupiter, FL.
    Winter storage.... What's that?
    Here in Florida the best riding weather is just beginning!
    Sent from my SM-G920V using Tapatalk
    Very Active Member youngers's Avatar
    Sep 2016
    clark county indiana
    Quote Originally Posted by Mango Man View Post
    soooo left front tire , or right front tire first
    Dec 2013
    Youngers, I'd aim to just clear the end of its tail with my front right - assuming the oncoming lane is clear, of course!!
    If you can, always try to evade behind an 'animate obstacle' or human controlled obstacle - that way, at least they hafta turn before they grab or hit you!! You might get as much as a whole extra second to get past safely!
    As for putting Spyders into storage, that doesn't happen here either, altho I gotta admit that I almost didn't ride today, the local temps were expected to be quite high, & ended up just topping 40 deg C! And that meant that, as expected, the Brown Snakes & Tiger Snakes were out frolicking on the blacktop (late spring friskiness, it's been too wet for them up until just recently!!) Despite the 'old school' practice of trying to kill them that way, you really hafta try to avoid running over snakes here, even their tails, cos if you get a tire on them pretty much anywhere they can flick up & will get angry, very angry; then they can wrap around axles etc, & just hang around waiting for a chance to bite - & a bite from either of those types of snakes pretty much means curtains unless you can get antivenine into you in sufficient quantity within about 15 minutes - and most of my ryding is somewhat more than an hour from the nearest hospital or ambulance; that is if there is even any telephone service to call for help in the first place!!
    Enjoy your winter, we are starting to get the HOT weather now!
    Sep 2013
    Houston
    Ipod or not, the spyder battery is not going to last the winter in storage without a battery maintainer connected. It will go dead in a few weeks. The Spyder computer draws a small amount of power continuously.
    Blue Flame Spyder F3-S
    2015 F3S , Blue Flame
    Very Active Member Grandpot's Avatar
    Oct 2014
    Fort Mill, SC
    Quote Originally Posted by youngers View Post
    Here kitty, kitty, kitty!
    2011 RTS (Sold to a very nice lady)
    1998 Honda Valkyrie
    2006 Mustang GT. Varooooom!
    US Navy Veteran
    SC Law Enforcement Boat Captain
    CNC Machine Service Technician
    President: Rolling Thunder SC1
    Member: Disabled American Veterans, Rock Hill, SC
    Member: American Legion
    Experience is recognizing the same mistake every time you make it!
    Dec 2014
    Toronto
    Default Winter here comes the BLOW
    Just started to snow total snow 10" coming maybe rain, ice pellets snow.
    Location Mouth of the St. lawrence river.
    I think that the gator didn't make the final cut, in the auditions for this picture:
    He was going home to pout...
    Newfoundland, Canada
    Quote Originally Posted by DGoebel View Post
    The ipod is not draining on the Spyder battery when the Spyder is not running. If you have not disconnected the Spyder battery then most likely it will be dead by the time you take it out in the spring anyway. The Spyder's on board computer alone will keep a continuous drain on the battery enough to have it go dead over several months. I even notice a lag in the starter when my Spyder has not been running for a few weeks so it will definitely go dead over the winter. My suggestion is if the storage unit has an electrical outlet then pick up an intelligent trickle charger. A decent one will run around $100. If there is no place to plug in a trickle charger then I would suggest disconnecting the battery all together. Hope this helps.
    Richard
    Default You may have missed it....
    There are no end to the posts and threads on battery maintainers and their impostance when storing a spyder over the winter. Options are, a battery tender, disconnecting the battery, and or taking it home for the charging. The RT have a lot of controling stuff so they for sure will need help over the winter...
    ​2012 RS sm5
    Don't forget to bring the I-Pod home; this is the perfect chance to add to your Library, and perfect your playlists!
    (At least this is when I work on mine... )
    I also pulled my GPS... In case any map or software updates show up; I can plug it in, and grab them also!
    Active Member tmcquain's Avatar
    Apr 2016
    Tennessee
    Is the audio plug in the trunk on the same circuit with the dc outlet? I have changed my fuse to make the dc outlet hot all the time and I was wondering if that made the ipod hot all the time too. If it does and the ipod is plugged in, then it would be drawing off the battery. I didn't even think about that...does anyone know ?
    " Fat people are harder to kidnap "
    2015 RTS-SE6 Circuit Yellow
    Akrapovic Exhaust - BajaRon Sway bar
    Rivco rear Trunk Rack
    Lamonster LED Head Lights - LED Fog Lights
    Spyder Cuff - Hwy Pegs
    Ultimate Midrider Seat w/ Yellow Trim - Rear Armrests
    Spyderpops Bumpskid with LED - Full view Turn Signal
    R/T Front grill Inserts
    3rd Brake light - Saddle bad LED
    Baker Built Air Wings
    Doc's Spring Stiffeners - Vibration Dampener
    TRICLED underground LED'S
    Oct 2016
    Faribault, MN
    Thanks all for all the inputs, Have removed and brought home the IPod, disconnected the battery, brought home the GPS as I've purchased Lifetime Maps updates for it, and gave one last longing look at it there in the dark.... sniff
    For my fellow Floridian, Australian, San Diegan and other folks who don't get to fully experience our 4th season called Winter here in Minnesota and points north, I'm sorry you'll miss the cross country skiing out the back door,
    Or the snowmobiling from the garage out through the country approved trails to the open fields of
    Can't do that on a Spyder.....
    I LOVE the Spyder, but there's more......
    Safe Rides,
    IBA 70020
    Oct 2016
    Faribault, MN
    Quote Originally Posted by tmcquain View Post
    Tmcquain, No, in my case at least, the IPod was only hooked up to the Audio Input side jack with the factory connector cable, the 12v jack (though set as always hot) didn't have anything in it. But I've also discovered through posts here that I need to disconnect my battery or have it on a Battery tender all winter storage season long. Both of my old bikes used to sit in the same storage all winter and started up 1st time every spring without battery tenders connected (though I had the connectors attached just in case.... (but they were standard cycles without the Spyder's computer system, I know now, I know...
    Safe Rides,
    IBA 70020
    I thought I heard somewhere, that your four Seasons in Minnesota are:
    Dreading Winter
    Shoveling snow
    Wishing it would go away'
    Repairing potholes
    May 2011
    Round Rock, TX
    Dreading Winter
    Shoveling snow
    Repairing potholes
    There are really only two; winter and road repair.
    (Used to live in Rochester.)
    thehawk
    In theory, there is no difference between theory and practice ... in practice, however, that's just a theory.
    Oct 2016
    Faribault, MN
    I served 14 years at Altus AFB, OK, they only had two seasons, wet and green (end of April - June), then dry and brown, late June through Mid April.
    I love looking out at Green, Green grass as the snow falls and covers it up.... and Fall colors on the trees (I get a color tour out my windows, don't need to go on a road trip for just that), Oh yea, when Minnesotan's say it's sweltering hot, they mean high 80's, not the triple digits of Tx with 89% humidity...
    Safe Rides,
    IBA 70020
    Registered Users lou49's Avatar
    Sep 2013
    lake mary fl.
    yeap!
    Oct 2015
    Lynden, WA
    Default Minnesota Spyder Storage
    The coldest winter I ever spent
    was that summer in Duluth.
    MN native born and raised in Mpls.
    Now living in Pittsburgh, PA.
    Idaho
    No. The iPod gets its power from the radio. Key off, radio off, iPod off.
    2014 Copper RTS
    Dec 2014
    Central, Florida
    Get a battery tender.....
    Sent from my SM-G935P using Tapatalk
    Apr 2016
    Bloomington, Minnesota
    Dave, I always pull my batteries and charge them inside. If a battery gets low, it can freeze (in Minnesota they can) and then it is game over for it. Being I have several of them, it is just easier to pull them and keep an eye on them from an inside room.
    Oct 2016
    Faribault, MN
    Quote Originally Posted by PapaHotel View Post
    Done, though the Spyder is in an above freezing heated winter storage. ( I gotta guy.....( he actually wanted to talk to me with out all the other storage customers so he could get on the Spyder and check it out, he likes....))
    Safe Rides,
    IBA 70020
