Fog lights out
I noticed both my fog lights out today . I checked the fuse and its good but replaced it anyway to be sure. I think it's unlikely that both burned out at once .
Any ideas ?
Leon
2022 marsala red RTL
AND
2014 RT S SE-6 COGNAC, 2010 RT 622 TRAILER TIMELESS BLACK
BRP trailer hitch, Utopia back rest, Baja Ron sway bar , heim links. Elka stage 2 shocks front and rear.
TricLed fender lights, saddlebag lights and mirror lights. LED headlights and fog lights, Wide vu mirrors.
spyderpops LED bumpskid ,zippered cargo bag linings, Laser Alignment by Netzleys Tire, Stebal air horn
stant gas cap,( Dimple oil plugs REMOVED ) JT dash mount.
(Onboard) Lamonster Garage air compressor and intelliboost charger.
I just took a quick look in the Owner's Manual (Page 149), and couldn't figure out which relay to inspect.
Can you tell us which one we should be looking at for this?
Thanks!
I, too, noticed my fog lights wouldn't come on ... but only in the daytime. At night, they both come on! I've tested this a few times and get consistent results. It seems to me that fog lights will only come on when the bike senses it's night time. Call me crazy, but ...
Ozzie Ozzie Ozzie
They aren't triggered by their switch AND the day/night sensor for the dash lights, are they?? Or have you (or the installer) inadvertently chosen a trigger source wire that is controlled by this sensor?? Does putting a 'black out' card or cloth over the analogue speedo & digital dash display let them come on in daylight/bright light conditions??
Surely if BRP had intended this to be a feature we'd have heard about it before now?? Has anyone heard that? Or is anyone aware of the Spyders (of any model) having low-light sensing fog light activation??
Mine are on all time. Never turnoff need all light i can get.
No sensor involved 14 rt se
I love R&R put another dime in the jukebox baby!
Mine are on all the time as long as I have the switch turned on I have 2015 RTS
My engine has to be running for the fog lights to come on.
otherwise be a vulgar brawl.
Cognac 2014 RT-S
Always on
I ryde with fogs and high beams on---except at night following another vehical. Both bikes have headlight modulators ( and tail light modulators). Also high mount BRAKE lights on all three. Can't have enough.
Kaos
Reason: speeling
Fog light switch
My fog lights on always, 2014 RTL. I noticed them out 1 day on pre ride check. It turned out the switch had failed. Warranty replaced switch. Since then I replaced my headlamps and fog lamps with Xenon extreme LED lamps. Very bright and run cool 😎 with less draw,on battery.
2020 RTL - Petrol Blue Metalic / Black, dark model.
Colour match rear tail cover, Garmin GPS.
Heated Ultra Comfort driver seat & backrest.
LED headlamps, LED Front corner lamps and lower front LED lamp.
Baja Ron sway bar.
Ride Til You Rot!
