Results 1 to 14 of 14
Thread: balance
    Nov 2016
    Maryland
    Question balance
    just bought a 2010 rss spyder ive riden it twice now and was wandering what is the bet way to turn without feeling like your going to be slingshotted off of it .so different from my vw trike around turns ..thank u in advance
    Jul 2014
    Mint Hill, NC
    otherwise be a vulgar brawl.
    Cognac 2014 RT-S
    Very Active Member JimVonBaden's Avatar
    Oct 2016
    NoVA
    Lean 3X harder into the turn than any conventional bike. Even then, the Spider is a lot more work to ride aggressively than a conventional two wheeler. Just don't tell my wife, she thinks it is easy!
    Jim
    2013 ST-S (wife's)
    2015 BMW R1200GS (mine)
    1981 Yamaha XS400 Scrambler Custom (mine)
    Nov 2016
    Maryland
    thanks for the advise rode all weekend getting better with every mile
    Jul 2014
    Mint Hill, NC
    Quote Originally Posted by wheels View Post
    ! That's all it takes, miles!
    Cognac 2014 RT-S
    Jul 2010
    Las Vegas, NV
    Default Turns
    Lean into the turn, try to kiss the back of your hand....it works!
    Joe Meyer
    Very Active Member Devious56's Avatar
    Oct 2015
    N.E. Florida
    Try to relax a bit, and push on the handlebar instead of pull. It's easier, and helps to settle your butt in the seat. Also, use your feet.
    David
    How old would you be if you didn't know how old you were?
    Default As I see it...
    It's a matter of time and miles. Rule of thumb...for those that have no or little ryding experiance it will take 300 to 500 miles to get the confidence and comfort to start pushing the twisties. It is also your comfort zone so take your time relax and enjoy the ryde and it will all become easy to you...
    ​2012 RS sm5
    Very Active Member Zip's Avatar
    Sep 2016
    LI NY
    and safe riding
    2010 RTSM5
    2010 RTSM5 , stock Stock Silver
    Very Active Member WA5VHU's Avatar
    Cooper, TX
    Are you nearby? If so, let's go for a ryde!
    Current:
    2016 Honda CTX700 DCT ABS (faring model)
    Kip Moto SherpaX Cargo Trailer
    Wife Has:
    2014 Can-Am Spyder RT Limited
    2016 Lees-ure Lite Camping Trailer
    Previous:
    2013 Can-Am Spyder RS SE5, zoom-zoom!
    2011 Can-Am Spyder RT-S SE5, Foot Burner - Gasoline Boiling Stinker - Gas Tank Vacuum Puller
    and
    Like they said above:
    : Don't overcontrol. A light grip on the handlebars. Do not break the eggs between your hand and the grip.
    : Push/pull motion on the handlebars. To little is better than to much.
    : Plant the outside foot on the footpeg. Lean slightly into the turn. This dissipates the g forces.
    : Enter a curve at a speed that does not require applying the brake. You should be able to accelerate slightly during the turn.
    Practice will make perfect. The learning curve for most is 300 - 500 miles.
    Nov 2016
    Maryland
    thank you for all the replies doing better on the spyder...just to clarify about using the feet thing ive been in a wheelchair since i was 2 yo and to transfer from vehicle,boat,trucks bikes i cross my legs indian style just so much more mobility and i've been riding my vw trike 13 years now with no issues until my brakes went out taking a turn i would had loved to use my feet that day lol....thank you gain on the responses it has helped a great deal......
    Nov 2016
    Maryland
    [QUOTE=WA5VHU;1203100]Are you nearby? If so, let's go for a ryde![ im about 20 min from ocean city md sir
    Nov 2016
    Palm Desert
    I've found using your legs to press against the body of the bike to counter the centrifugal force works best around corners.
