Results 1 to 19 of 19
Thread: HEADLIGHT BULBS
    Apr 2011
    GREENVILLE, SC
    Default HEADLIGHT BULBS
    I'M ABOUT TO (AGAIN) REMOVE THE TOP OF MY F3 TO REPLACE A HEADLIGHT BULB...
    THIS WILL BE THE 4th TIME (5 BULBS), THAT I'VE REMOVED THE TOP OF MY F3 TO REPLACED ONE OF THESE BAD-BOYS....
    MY NEXT REPLACEMENTS WILL BE OTHER THAN THE 'GLASS' TYPE H4 BLUB, AND I WILL NOW INSTALL THE L.E.D. BULBS....
    IS ANYONE ELSE HAVING ISSUES WITH BULBS BURNING OUT...?
    AND IS THIS ONE FROM CYCLE GEAR A GOOD CHOICE....?
    https://www.cyclegear.com/parts/xk-g...conversion-kit
    YOUR HELP IS ALWAYS APPRECIATED....
    DAN P
    SPYD3R
    Active Member papanorm's Avatar
    Aug 2016
    central texas
    I went with the H4 LED replacements from Lamonster and am very pleased with the brightness. Lamont also has an install video for the F3 Limited. He says they are the best and the money was reasonable too. My wife also noticed how bright they were when she drove ahead of me.
    2016 F3L , Big Bike Parts Black
    Apr 2011
    GREENVILLE, SC
    Default THX
    Quote Originally Posted by papanorm View Post
    THX papa....
    but what i'd REALLY like to know is: has anyone had 5 bulbs fail in a short period of time...?
    and do the LED's burn out quickly as the 'glass' bulbs do....?
    Dan P
    SPYD3R
    Dec 2012
    Murphy, NC
    Default Headlight Bulbs
    Dan when I had my ST-S I only had one bulb burn out in 25,000 miles. With 5 bulbs burning out on your F3-S I'm wondering if you might have some sort of electrical problem. Possibly an occasional surge of electricity that would blow a bulb?
    2020 F3 Ltd
    Spyderpops Bumpskid
    washington state
    Handle the bulb with no bare skin. use gloves.
    Jun 2010
    Las Vegas
    Quote Originally Posted by SPYD3R View Post
    THX papa....
    Dan P
    SPYD3R
    My right headlight on my RT has burned out at least four times. The last time it fused the electrical connector that goes into the housing. The entire headlight was replaced under warranty.
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
    Apr 2011
    GREENVILLE, SC
    Default RIGHT
    ANN;
    STRANGE, BECAUSE IT'S ALWAYS MY RIGHT SIDE BULB THAT BURNS...... hmmmmmmmmmmm....
    DAN
    SPYD3R
    Feb 2009
    Ceresco, Michigan
    THX papa....
    Dan P
    SPYD3R
    The LED bulbs should never burn out. I'd spend a little more and get the ones Lamonster sells.
    Mar 2015
    Kansas City North, MO
    Default LED's
    What I have read/heard is that ya want to stay away from "fan cooled" LED's. May want to do additional research for yourself prior to jumping on those...FWIW.
    Springfield, MO
    THX papa....
    Dan P
    SPYD3R
    We're seeing a lot of bulbs burnout on the new Rt's mostly. Our LED lights come with a 2 year warranty and we have yet to have to replace one and we have a bunch of them on the road.
    I had to replace one on my 2014. Still okay on the 2011.
    Nov 2016
    Hummelstown.Pa.
    Quote Originally Posted by Lamonster View Post
    I just bought a pair from you for my F3T and I'm going to order another set for my Big Dog motorcycle, the one I have now has a fan on it and others that have the fan LED's are coming apart
    Harrington, Australia
    Quote Originally Posted by SpyderF3 View Post
    So how does the single LED switch between high and low beam? I have an ulterior motive for this question. I have Lamonts LEDs that I bought before I realised that the Euro/Aussie model had two separate lights for high and low beam, unlike the US model. Is the LED effectively on high beam all the time and there is some kind of "shutter/screen" when on low beam? (If that makes ANY sense)
    HeliBars Handlebars
    Kenda Kanine rear.
    Houston
    On the RT that is exactly how they work. ON the F3, Hi / Lo is via a dual filament lamp. The LED replacements have dual sets of LED elements at different focal points.
    Blue Flame Spyder F3-S
    2015 F3S , Blue Flame
    Jun 2015
    Hobart, IN.
    Default Bulbs
    Usually that tells me it is a bad ground. With any electrical problem start with the ground circuit........
    Jun 2013
    Fleetwood, PA
    Default Lamonts LED's
    If you are going LED I also recommend Lamont's LED'S. I also have his LED fog lights and I am just about to hit 10,000 miles on both of them with no issue. I also never turn off the fog lights and have had no issue.
    Apr 2010
    Thorn Hill, TN
    I also recommend Lamont's LED bulbs.
    Active Member woodyaa's Avatar
    Mar 2015
    Harvard, Il
    I have Lamont's LED's and his LED fog lights on my 2015 RTS.
    I love them both, huge difference in the amount of light. I'm very comfortable riding at night now.
    Nov 2016
    Hummelstown.Pa.
    Quote Originally Posted by woodyaa View Post
    X2 in my 16' F3
