Page 2 of 2 FirstFirst 12
Results 26 to 31 of 31
  1. #26
    Very Active Member Trbayth's Avatar
    Jun 2014
    Schenevus NY
    Saw that. $33 per litre. Did not lokk to see, is it possible that is oil used for dry clutch style engines.
    Amazon has it for $66 for 4 liters. https://www.amazon.com/Motul-300V-Sy...motorcycle+oil
    Trb-- (Roger)
    2014 Cognac STL:Ultimate Seat, Nelson Rigg Tail Pack, Nelson Rigg RS/ST Half Cover, TL fender lights, Squared Away Laser Alignment, BajaRon sway bar and links, Akropovic Sport Silencer
    2022 White Pearl F3T
    Gone but not forgotten: 2019 F3S Special Series Liquid Titanium
    Spyder States Visited
  2. #27
    Member DSSpyder's Avatar
    Feb 2015
    Waynesville, OH
    Great discussion on oils! Thank you all. Discussions backed up by technical data are much better that "it's what my dad used!"
    I got introduced to Mobil 1 industrial oils working in the electric production industry where everything was backed up by analysis. We used it as predictive maintenance for repairs and oil changes. That Mobil support was so impressive I use Mobil 1 in everything I drive. RAM diesel, Goldwing, Spyder, 30 years +
    Question; has anyone contacted Rotax for their 2 cents? They design and build the engines.
    Hope to see you all at Homecoming this year!
    Ride Safe!
  3. #28
    Nov 2012
    North Las Vegas, NV
    Quote Originally Posted by DrewNJ View Post
    It will take some time, but this is a fantastic read. https://www.google.com/url?sa=t&sour...RiPF0bsOjzhEnw
    Sent from my Nexus 6 using Tapatalk
    He rates the oil Doc is running as a good one.
    2016 F3 Limited
    2019 Ryker Rally
    2014 Suzuki V Strom 650
    2020 CSC TT 250
  4. #29
    Nov 2012
    North Las Vegas, NV
    ......................I also got the feeling that He has something to do with SELLING - " EXTREME OIL CONCENTRATE " , since He adds it to almost every oil He tests !!!!!!! and it IMPROVES all the oils !!!! Interesting ....... Mike
    Actually it doesn't improve all the oils, some of them get worse.
    2016 F3 Limited
    2019 Ryker Rally
    2020 CSC TT 250
  5. #30
    Very Active Member KX5062's Avatar
    Aug 2012
    Central Coast, CA
    Nope. It's wet clutch rated.
    Amazon has it for $16.50 per liter, free shipping.
    https://www.amazon.com/Motul-300V-Sy.../dp/B000GU5QDA
    2020 RTL SE6
  6. #31
    SoFlo
    Quote Originally Posted by KX5062 View Post
    Let me know how well it works. No plans to go away from Mobil 1 Sportbike oil. Easy to get on the day I need it, costs less and is well rated.
    If a 1330 made respectable HP or I was spraying it, then maybe. As is, the RTS is heavy, is not a high rpm, high output engine, so stresses should be low.
    Two up with full fuel and no baggage, 13.356 lbs/hp. With riders, no fuel or fluids, no baggage, basically empty wt, still comes in at 9.56 lb/hp.
    Pretty low too in the hp/ci numbers too @ around 1.4
    Fun machine, does well as designed and intended.
