Results 1 to 24 of 24
    Mar 2013
    Default Brake Fluid After 3 Riding Seasons
    Flushed my fluids although the Coolant looked ok the brake fluid (center jar) not so much. I should have changed that last year.
    2021 Sea To Sky, 2020 RTL
    but our benefits don't?
    2015 F3S , White & Blue
    Very Active Member JimVonBaden's Avatar
    Oct 2016
    NoVA
    I don't know the service schedule, but on a typical motorcycle the brakes should be done every two years. Motorcycles tend to be harder on brake fluid than cars, and have a lot less of it. Also, it is hard on ABS modules to run dirty contaminated fluid.
    Jim
    2013 ST-S (wife's)
    2015 BMW R1200GS (mine)
    1981 Yamaha XS400 Scrambler Custom (mine)
    Jul 2011
    Mitchell, Ontario, Canada
    I agree that brake fluid needed to go.
    2018 F3 LIMITED
    Which reminds me to change mine at the start of next season; thanks!
    Jun 2013
    The looks of that fluid may be why your Owners Guide says to change the brake fluid every two years . . .
    Mar 2013
    Quote Originally Posted by Dan McNally View Post
    I agree!
    For me was wraping my head around the fact that my 2014 in 2016 = 3 years of riding and not 2 years.
    Good idea. Another item to add to my spring tune up list.
    Quote Originally Posted by PW2013STL View Post
    I agree!
    Bossier LoUiSiAna
    2yr~14,000miles per schedule I got srz bout pic there is more info you can find tho
    2013 STL SE5 BLACK CURRANT
    SpyderPop's: LED bumpskid
    minispyder dash toy
    Lid lox
    KradelLock
    Pakitrack
    FLO (Frunk Lid Organizer)
    BRP fog lights, trailer hitch
    SENA 20S EVO
    Very Active Member Bensonoid's Avatar
    May 2014
    Benson, NY
    Default Yuck
    Be careful where you leave that jar. Someone might spread that goo on their toast.
    2015 RTS Special Series
    Russell Day Long seat
    F4 Customs windshield
    Sena 20s
    Quote Originally Posted by Bensonoid View Post
    Mmmmmmmmmmmmmmmmmmmmmmm
    Jun 2016
    Harrington, Australia
    Default Vegemite
    Looks like Vegemite........send it over.....this could be another delicacy for Aussies to eat
    Pete
    2021 RT Limited
    HeliBars Handlebars
    Kenda Kanine rear.
    Mar 2013
    Pete
    Remind me not to try any Aussie delicacies
    Invalid Emails
    Nov 2009
    Peterborough, Ontario, Canada
    I have a 2008 RS and just checked my original brake fluid. The fluid is still very clean looking like it always has and brake performance has not changed. How would the fluid get so dirty on a closed system? 40 years of driving and I have never encountered it.
    Very Active Member SPYD3R's Avatar
    Apr 2011
    GREENVILLE, SC
    Default FLIP
    SHORT OF FLIPPING MY F3 UP-SIDE-DOWN, HOW DO YOU DRAIN THE ANTI-FREEZE...?
    WHERE IS THE DRAIN PLUG...?
    SPYD3R
    Jul 2011
    Quote Originally Posted by SPYDDER View Post
    How did you check the brake fluid? Did you bleed some out? Because the stuff in the reservoir will look just fine.
    2018 F3 LIMITED
    Mar 2013
    Quote Originally Posted by SPYD3R View Post
    SPYD3R
    On my RT I had to cut off the lower right hose clamp and pull the hose off to drain it as per the manual.
    Mar 2013
    I agree as mine looked fine in the reservoir, but as soon as I started pumping it into the jar it was apperent how dirty it was.
    Active Member woodyaa's Avatar
    Mar 2015
    Harvard, Il
    Well, glycol-based brake fluid is very hygroscopic. This means that it will aggressively absorb water from the moment the container is opened. Many manufacturers pack brake fluid under nitrogen to extend its shelf life. Brake fluid will absorb water through minute, even microscopic pores in brake hoses, lines and piston seals and when it is exposed to air. In South Florida, where the humidity level is usually very high the problem is exaggerated. Also, as caliper and brake line temperatures increase and then cool repeatedly, condensation occurs, leaving behind an increase in moisture.
    Sep 2013
    Houston
    SPYD3R
    Why
    would you be draining antifreeze on an F3? Its no where near old enough to require that yet.
    Blue Flame Spyder F3-S
    2015 F3S , Blue Flame
    Apr 2011
    GREENVILLE, SC
    Default READ
    Why
    IF YOU WOULD READ YOUR MANUAL, YOU WOULD SEE THAT THE ANTI-FREEZE IS TO BE CHANGED AT 28,000 MILES.... I DON'T LET MINE SIT IN THE GARAGE, I RIDE MINE.... I HAVE 28,000 ON MINE....
    SPYD3R
    Nov 2013
    Central Texas
    I've always wondered what causes brake fluid to degenerate in that way. It's not like it's an open system that allows contaminate in. And why does it last so much longer in cars than on motorcycles?
    Dec 2015
    Galax VA
    Quote Originally Posted by oldguyinCT View Post
    Actually it doesn't last any longer in cars or trucks. As was previously mentioned it absorbs moisture from the air. the master cylinders are vented. I used to replace the brake fluid in my race car before every race.
    Sep 2013
    Houston
    SPYD3R
    Well
    lets just say I disagree with a mileage limit on antifreeze that only ages by using up its anti corrosive agents over time. Its easy to verify the quality of the antifreeze solution with test strips. That same coolant is rated for 5 yrs in heavy duty service. Suit yourself. You drain it via the lower radiator hose.
