Results 1 to 11 of 11
    Active Member First Timer's Avatar
    Jul 2016
    East Peoria, IL
    Default Wheels rollers...
    Has anyone ever used wheels rollers under your Spyder for ease of movement into tight spaces for storage during winter months. Was looking into buying a set to use. Any suggestions or comments...
    Thanks...
    Very Active Member ingramwc's Avatar
    Oct 2008
    Kingsport, TN
    Sounds like a great idea! I figure you are thinking about the cradle type with 4 dolly wheels on each. Obviously you would need 3, and it should make moving the Spyder around
    very easy. Good luck. Let us know how it works for you!!
    Current ride: 2013 Circuit Yellow ST-S SE5
    Member mmiehe's Avatar
    Jun 2016
    Ontario Canada
    Default Dolly for Spyder
    IMG_20161107_095511.jpgIMG_20161107_095455.jpgIMG_20161107_095432.jpgIMG_20161107_095425.jpgIve just complete what you were asking about. The dollies are nothing special just moving dollies. Each on can handle 500 lbs, so three more than covers the weight of my ST-S. My softail slim in the back ground is sitting on one, 900 moving dolly. Each of these move around easily by one person.
    The only issue I had was strapping the front wheels down so it wouldn't move off the front dollies.
    Easy project, very handy when I want to work and move things around
    Default Work well...
    Several folks here have used them and find them very helpful and easy to use. harbor freight as them and some you can roll on to then raise them to roll..
    ​2012 RS sm5
    Registered Users meljr's Avatar
    May 2016
    Marianna, FL
    Thats a great idea.
    Sent from my SM-G935V using Tapatalk
    Default DOLLIES
    I got 3 at Home Depot years ago .......they were cheap at the time , ...... so check there or Lowe's ...... Mike
    Active Member Bogie's Avatar
    Feb 2014
    Brown City Michigan
    There are sold in sets of 3 for snowmobiles.
    Very Active Member Trbayth's Avatar
    Jun 2014
    Schenevus NY
    Last year I just left the parking brake off and used a couple of wheel chocks to keep it from moving when I didn't want it to.
    Trb-- (Roger)
    2014 Cognac STL:Ultimate Seat, Nelson Rigg Tail Pack, Nelson Rigg RS/ST Half Cover, TL fender lights, Squared Away Laser Alignment, BajaRon sway bar and links, Akropovic Sport Silencer
    2022 White Pearl F3T
    Gone but not forgotten: 2019 F3S Special Series Liquid Titanium
    Spyder States Visited
    Quote Originally Posted by Bogie View Post
    Shop the snowmobile accessory catalogs for them!
    Northern Kalifornia
    Jul 2016
    East Peoria, IL
    Thanks for all the great information and links. Going to Farm and Fleet tomorrow and look at a set of car dollies. Next will be to read the manual to find out the jacking points for each wheel.
