Page 2 of 5 FirstFirst 12345 LastLast
Results 26 to 50 of 108
Thread: Belt tensioner.
  1. #26
    Active Member DunaJ's Avatar
    Feb 2013
    Rowlett, Tx
    Completed my installation over the weekend.
    AWESOME UPGRADE BYE BYE Vibrations!!!!!!!!!!!!!! Totally different ride with the VIBs gone.
  2. #27
    Dec 2014
    NY
    So glad that I installed my Smooth Spyder over a year ago.. Couldn't have waited this long..
  3. #28
    Very Active Member Ron2andia's Avatar
    Jun 2012
    Phila
    Have a dealer appointment to do it because he said the belt tension has to be changed as well. Is that the case?
    Live, Love, and Ride! God Bless!
  4. #29
    May 2016
    Blackwood, N.J.
    Default F3T
    Have a F3T, will it work on it and where can you order it from?
  5. #30
    Active Member bigwhammy's Avatar
    Nov 2014
    Penrith NSW Australia
    Red face 4 In stock in Australia with BRP Asia Pacific
    Yahoo finally arrived in Australia.
    Put mine on today and it works.
    Pn 219800412
    Mat. Desc. F3 Idler Pulley Kit (Esemble Roue Libre F3).
    Known in Australia as a Idler Belt Kit.
    For the technically minded.....
    Appears that the swing arm (injection Moulded) and roller are made from Acetal so will be strong and last along time.
    Japanese NSK roller bearings in roller and possibly in the pivot point.
    Bolts are Class 8.8 medium Carbon Steel Heat treated. Proof load of 600 Mpa with Nilock nuts.
    The spring looks like good quality also But I will be keeping an eye on it for corrosion.
    The bracket is 2.5 mm (1/10 inch) plate steel.
    It has about 6.5 kg pre load when flat.
    Shame on BRP for not putting this on originally.
    BRP will most probably still have it as an option to recoup R&D costs and hence avoid liability for an imaginary vibration (one that most of owners have experienced).
  6. #31
    Jun 2016
    Harrington, Australia
    Quote Originally Posted by warrensr View Post
    Yes, and read the earlier posts, warren.....
    2021 RT Limited
    HeliBars Handlebars
    Kenda Kanine rear.
  7. #32
    Jun 2016
    Default Yeah!
    Just had a message from my dealer that it is in. Thank you, Americans, for finally letting some reach the other ends of the earth. I have to pop my F3 in for a checkup and laser alignment once I get me new Kumho on, so I might get them to do that at the same time.
    Are you serious, Whammy? The bolts are only Class 8.8? I will send it back and demand at least Class 8.9 ........Seriously though, thanks for the info.....even though I don't have a clue what acetal is, it's great to know that it is made out of long lasting materials
    2021 RT Limited
    HeliBars Handlebars
    Kenda Kanine rear.
  8. #33
    Nov 2014
    Default POM Du Pont Delrin / Ertacetal = Polyacetal Resin
    Yes I would have preferred class 12.9 bolts (1220 Mpa Tensile Strength) but it is hard to find class 12 nuts so I would have to make do with class 10 nuts.
    Polyacetal (Acetal POM) is basically a Thermosetting Plastic it is hard, stiff, resists creeping, has dimensional stability with a low coefficient of friction (stay away from jokes about this material). It is replacing precision metal gears and bearings, great for things that are in hot water up to 60 to 90 C.
    I fitted it in less than 30 minutes so make sure you do not get charged extra for morning tea and lunch breaks. They should be able to do it in less than 30 minutes. I had to make 2 trips from my car parking garage to my workshop garage which added 8 minutes. So BRPs estimate of 0.3 hours (20 minutes) is correct.
    Note for Australian fitters .. . the instructions illustrate the USA version with the larger rear sprocket hence the idler roller sits lower on the European / Australian models with maybe a little less tension (less than 3kg (= 0.5 kgf)).
  9. #34
    Very Active Member irvin48's Avatar
    May 2016
    mt morris il
    what is used for bearings inside the roller ? think it will be long lasting ?
    --irv
    2015 rts-white pearl- mods- '16 F3 fat 6 chrome wheels,
    and some little stuff. setback utopia backrest, baja ron
    sway bar, oem adj. air deflectors, marlin gps compass,
    lamonster fbb foot pegs[modified brackets], lamonts
    vibration damper, rock guard, and side case stiffener kit,
    . brp comfort seat. , fomozas and
    altimax, magic mirror mts, and wide mirrors.
    [joyce & irvin toms]
  10. #35
    Very Active Member Firefly's Avatar
    Feb 2009
    Ceresco, Michigan
    Quote Originally Posted by Ron2andia View Post
    Whiles it's a good idea to check your belt tension and make sure it's in spec, it is not a requirement. There is no recommended change in the belt tension when installing this option.
    Spyder #1 - 2008 GS SM5 Premier Edition #1977. RIP after 80,000 miles.
    Spyder #2 - 2012 RT SM5. Traded in after 24,000 miles.
    Spyder #3 - 2015 F3 SM6. Put 13,000 miles on and sold it.
    Spyder #4 - 2017 F3 SM6. Too good of a deal to pass up!
  11. #36
    Mar 2013
    Quote Originally Posted by Joyce47 View Post
    --irv
    Check post #30 for your answer.
    2021 Sea To Sky, 2020 RTL
    but our benefits don't?
    2015 F3S , White & Blue
  12. #37
    May 2016
    mt morris il
    oops . didnt read well. was getting all the plastic parts specs instead. thank you !
  13. #38
    Nov 2014
    Default nsk
    --irv
    Japanese NSK as good as you can get. Not crappy Chinese ones.
  14. #39
    Registered Users pdxsenior's Avatar
    Apr 2015
    Tualatin, OR.
    I received my kit yesterday and have printed out the instructions.
    Here is the deal guys, I also found out yesterday that I have to have spine surgery next month so please go easy on the back-and-forth about my question, I'm just not in the mood... sorry.
    Where can I get a video of how to install it?
    15' F3S SE6 owner
  15. #40
    Heal quickly and completely...
  16. #41
    Active Member KJWEB's Avatar
    Jun 2015
    Midland, TX
    Quote Originally Posted by pdxsenior View Post
    15' F3S SE6 owner
    I sent you a text message
    www.sasspyders.com
    2016 F3T
    2015 Freedom Trailer
    Sypderpops BumpSkid Plate
    Lamonster ISP Key Cover
    Lamonster F3 Bar Clamp and Power Port
    Lamonster RIP floorboards and frame caps
    Lamonster Chevron Highway Pegs
    BajaRon Swaybar & Heim Links
    F4 Custom 21" tinted windshield
    BRP Cannonball Seat
    BRP F3 Idler Pully
    FOBO TPMS
    LidLox (dual)
    Garmin 660LM GPS
    Cat Delete Performance Pipe
    F3T Top Case
    PPA Black Widow Wheels
    Custom Frunk Wrap
  17. #42
    Default INSTAL VIDEO
    15' F3S SE6 owner
    Lamont did an excellent one with some handy tips ...... M
  18. #43
    Apr 2015
    Tualatin, OR.
    Well, a very good and dear friend of mine, Kevin, in the Seattle area is going to ride down here, Albany, and install it for me. What more could a guy ask for... nothing😊
    15' F3S SE6 owner
  19. #44
    Feb 2009
    Ceresco, Michigan
    15' F3S SE6 owner
    Go to Lamonstergarage.com. He has a video of the install.
  20. #45
    Invalid Emails
    Jun 2014
    Green Lake, WI USA
    Had my BRP tensioner put on yesterday by my favorite dealer in Wisconsin Rapids. Noticeable difference in ride quality. There's still a hint of vibration but not sure if that's from the belt or not. Definitely a great mod for the bike!
  21. #46
    Apr 2015
    Green Bay, WI
    Quote Originally Posted by reissooz View Post
    Yes--regardless of what other posts may say, it does not solve the problem for all of us, I can understand their loyalty, but bull**** has never satisfied me, why else would I say this if it wasn't true??? The problem is engine vibration in the 3200-3800 range--the engine is not balanced--the entire site can blame it on the belt---so why do some of us still feel vibration after the BRP roller assy is installed???
  22. #47
    Active Member tmcquain's Avatar
    Apr 2016
    Tennessee
    After looking at Doc Humphreys video and all for the RT mod for this, I had to pull the trigger. I have wanted to get a tensioner but the 200-300 price range always seemed really high, the brp part is 35 bucks and docs mod is 40, and it looks easier to install than either the Baker or smooth spyder....we'll see i'll update when I get it installed !
    " Fat people are harder to kidnap "
    2015 RTS-SE6 Circuit Yellow
    Akrapovic Exhaust - BajaRon Sway bar
    Rivco rear Trunk Rack
    Lamonster LED Head Lights - LED Fog Lights
    Spyder Cuff - Hwy Pegs
    Ultimate Midrider Seat w/ Yellow Trim - Rear Armrests
    Spyderpops Bumpskid with LED - Full view Turn Signal
    R/T Front grill Inserts
    3rd Brake light - Saddle bad LED
    Baker Built Air Wings
    Doc's Spring Stiffeners - Vibration Dampener
    TRICLED underground LED'S
  23. #48
    Very Active Member bruiser's Avatar
    Eastern North Carolina
    Installed mine today. Huge difference. I'm pleased with the product and very pleased with the smoother ride. Now my teeth don't hurt at the end of a long ride.
    USAF '69-'89 E7
    Thailand/Vietnam 1972
  24. #49
    Feb 2009
    Ceresco, Michigan
    Quote Originally Posted by Wildrice View Post
    Christ on a cracker! Engines give out vibrations... get over it already. The belt tensioner GREATLY helps reduce vibration. The Spyder vibrations are nothing compared to other motorcycles on the market, except the gold wing which is damn smooth.
    If you want a ride without any engine vibrations then perhaps a car would be a better choice for you. Seems like you're far too sensitive to vibrations to be riding a motorcycle at all.
  25. #50
    Apr 2015
    Green Bay, WI
    Quote Originally Posted by Firefly View Post
    Sorry to have offended you and a few others. My goal was to have BRP correct the problem on future productions. My other bike is a 2007 Suzuki Hayabusa with a Stage 2 Velocity Turbo putting out 344 rwhp & 210# torque on a 530# bike. This isn't my 1st rodeo. Could I have some cheese on that cracker?Darrell Feit Dyno Graph2007 Busa.jpg. Dyno chart attached.
