I am due for an oil change on my 2015 RT. Last time, even after watching Smoak's videos, there was a mess with oil tracking onto the plastic panels underneath. I used my J&S jack with spyder adapter as well as the oil diversion pan. Before I started the change, I trimmed the openings that the draining oil is SUPPOSED to drain thru. I marked some painters tape after determining there was no danger of damaging anything under the panels. A dremel with a small cutting wheel did the job. I "cleaned" the trim job up with a ting sanding disc and it is all done. Oil ended on the drain diversion and into the drain pan. I could catch both drains with one pan!! I did find one wrapped electrical cable underneath the trans side but luckily didn't hit it.
2015 an Am Spyder RT Limited
2013 Yamaha WR250R - Sold
2011 Can Am Spyder RT-S SE5 Limited - Sold
2011 Aspen Sentry Trailer
2003 BMW K1200LT - Sold
2007 Unigo Trailer - Sold
2001 BMW K1200LT - Sold
2001 Honda 750 NightHawk - sold
2015 RT Ltd , Canamspyderaccessories Brake pedal ext. Red
Call them for the adapter for your specific spyder!
I've used Fumoto valves on my cars as well. General consensus here was that there isn't enough clearance under the bike for the valve. Although they do have a low clearance version that could work.
Trb-- (Roger)
2022 White Pearl F3T
Good info. I'll see when I do mine in the next couple of weeks. The bike only has 1600 miles on it, but is an 03 with an undocumented maintenance history, so I think I should just reset the clock on it.
....we would use a 90 degree to install the valve horizontally....?
Richard
* 2012 RS SE5 (hers)
* 2013 ST SM5 (mine)
Daughter RSS SE5 2014
Son in law RSS SM5 2013
P.S. 3 Kumho AST 225/50R15 and 1 Toyo Proxies 4 225/50R15 rear tires
2 sets of Kumho 175/55R15 front tires
1 set of Hankook V4
1 set of Canadian Tire General tire Evertrek RTX in 14" for the 2012 ...
