Results 1 to 15 of 15
    Active Member Lone Spyder Ryder's Avatar
    Feb 2009
    Citrus Heights, CA
    Default Wont start. 2013 St Limited automatic
    Will not start. turn the key, get black screen with can am then Orange/Black screen that says (Before operating read safety card then push mode button. Done it over and over. push mode, disconnected battery hoping that might reset it. Nothing. Any ideas other that have it picked up and taken to the shop.
    thanks for any help
    When you change the way to look at things,
    the things you look at change!
    Dr.Wayne Dyer
    Very Active Member youngers's Avatar
    Sep 2016
    clark county indiana
    could it be a fuse ? connected too starter , or start switch fuse { something in this idea ?
    Default Have to ask....
    Does the engine crank/turn over but not start or do you only hear a click or nothing. if an se/automatic is the kill switch off and are you stepping on the brake..?
    ​2012 RS sm5
    Dec 2013
    You have made sure that you have your foot on the brake pedal while you're trying to start it haven't you?? If for whatever reason it didn't get to neutral when you shut it down or the clutch isn't feeling up to letting you start for some reason, then having the brake pedal pressed becomes an essential thing!!
    With that in mind & practice, if you get to the 'press mode button' screen so you push the mode button, get the normal dash screen & lights, but then get nothing when you hit the starter button, the next thing to check is the Kill switch - is it in the Run position or the Kill position? Regardless, operate it a couple of times anyway, try it in both positions, flick it back & forth a bit; I have had one (not on a Spyder tho) that somehow got gunk inside it & the first flick still didn't make contact, it took 2 or 3 flicks for it to click!!
    Still no go, then check the battery condition, cables, & connections, actually take the connections off & make sure the posts & seats are clean, same deal with cleaning the cable ends, BOTH ends, then connect them back up firmly - they've gotta be clean & tight.
    No go there, stick the battery on a boost unit or try jump starting it. If it still doesn't start after all that, you really start getting into the area of visiting a Dealer or knowledgeable Spyder/motorcycle mechanic - sorry!
    Good Luck!
    Very Active Member GOZFST's Avatar
    Oct 2014
    SD &AZ
    Quote Originally Posted by Lone Spyder Ryder View Post
    thanks for any help
    How long has it been since you last rode it? Do you keep it on a battery tender? Put a charger on the battery and let it get up to full charge, if it still has the same problem test the battery. It's not uncommon for a 3 year old battery to die.
    Bob S
    Bossier LoUiSiAna
    thanks for any help
    Does the mode button screen go away?? If not something is wrong with button or wires. One member has reported a thief trying to steel his tank bag cut his wires to no avail but still damaged the bike. Hope is not the case,
    but if the mode button fails its as bad as the kill switch. We need more info plz
    2013 STL SE5 BLACK CURRANT
    SpyderPop's: LED bumpskid
    minispyder dash toy
    Lid lox
    KradelLock
    Pakitrack
    FLO (Frunk Lid Organizer)
    BRP fog lights, trailer hitch
    SENA 20S EVO
    Aug 2016
    Australia
    Put your foot on the brake pedal
    Jul 2011
    Mitchell, Ontario, Canada
    If I understand you correctly and that the mode button does not work. The left handlebar controls may have become unplugged. Do the lights come on for the command center buttons when the key is on?
    Defect in the handlebar controls and needs to be replaced. If so needs to be plugged into BUDS to confirm.
    thanks for any help
    2018 F3 LIMITED
    Oct 2016
    Faribault, MN
    LSR, I have a '13 RTL and find that I have to rock the kill switch (as others have mentioned above) when it won't start as expected. Dunno why it acts that way, but rock/rock and it starts next try.
    Just showed that to another ryder last night when his Spyder inexplicably wouldn't start like it had the twenty times before....
    Safe Rides,
    David and Sharon Goebel
    Both Retired USAF Veterans
    IBA 70020
    Very Active Member ingramwc's Avatar
    Oct 2008
    Kingsport, TN
    Make sure the Kill Switch (red switch on right side of handle bar) is in the Run position...
    Current ride: 2013 Circuit Yellow ST-S SE5
    Registered Users Dawnie89's Avatar
    Sep 2016
    Loogootee IN
    thanks for any help
    I just had this issue and did a full maintenance done for selling my 2013 ST-L. It has the original battery. I had to replace the battery = problem solved.
    Sent from my SAMSUNG-SM-G870A using Tapatalk
    Feb 2009
    Citrus Heights, CA
    Default Same old problem and still no answer. Ideas anyone. Thanks
    thanks for any help
    Got it back home after this SPEED-PROG was replaced. It started up when I went in to pick it up. Started a couple times at the shop before leaving. Drove it 40 miles back in the rain. Parked cleaned it up. Two days later weather cleared so I went to run a errand and S.O.S. Nada, Same screen, same story, back at the shop.
    I have had this problem from day one. Same thing as happened at least 8 times and had to be tow to the shop everytime. That is $400.00 in deductible's alone. Can't trust it to run and can't know if it is fixed or not. Been told 8 times it was fixed. Any one else had this problem. Thanks.SPEED_PROG Replaced.jpg
    Dr.Wayne Dyer
    Very Active Member Trbayth's Avatar
    Jun 2014
    Schenevus NY
    Methinks it's time to get Steve from BRP Care involved.
    Trb-- (Roger)
    2014 Cognac STL:Ultimate Seat, Nelson Rigg Tail Pack, Nelson Rigg RS/ST Half Cover, TL fender lights, Squared Away Laser Alignment, BajaRon sway bar and links, Akropovic Sport Silencer
    2022 White Pearl F3T
    Gone but not forgotten: 2019 F3S Special Series Liquid Titanium
    Spyder States Visited
    Feb 2009
    Citrus Heights, CA
    thanks for any help
    Trbayth
    Who is Steve from BRP. Phone #
    thanks
    Dr.Wayne Dyer
    Very Active Member ottawa-rider's Avatar
    Sep 2012
    Casselman, Ontario, Canada
    Trbayth
    thanks
    Steve is a contact person at BRP, not sure of his title, he posts on here every now and then, his email is brp.care@brp.com.
    2018 RT LTD , Black
