Don't know if I should have...
... but I did... use the cruise control on my RT SM5 while pulling our Bunkhouse trailer. Have I messed up here? I am back home after 2000+ miles and Hi-O Silver is in the garage. Hope I haven't ruined anything....
Jim
Ryde, eat, sleep.... repeat
2019 Spyder RT Limited Pearl White/Dark
LaMonster drink holder with X-Grip
LaMonster Belt Dampener
Lamonster USB cable with extension
Variously called Stormtrooper, Pearl, and Goober by wife and various (friends?)
I think you are probably OK, if something was going o happen, I think it would have all ready happened.
Cruzr Joe
Not sure about your trailer but I use cruise control all the time with mine.
2015 ST Limited SE5 in Vegas White Serial Number 0162
BRP Backrest, BRP Travel Bags, Larger break pedal
Baha Ron Sway Bar & Links, SmoothSpyder Belt Tensioner
BRP Trailer Hitch, 2011 Rt-622 Trailer (Pearl White)
Laser Alignment -(wasn't needed???)
IPS Holder, X-Grip Phone/ Cup Holder
It wouldn't affect anything: all will be fine!
I use my cruise control to do a better job than I can do of maintaining a constant speed, which is normally the safest thing you can do when ryding (or driving). Unless you were hauling a$$ to the point of strain that the byke wasn't designed for, I can't image cruise control doing any damage. Even then, it would be the heavy throttle that did the damage, not the cruise control. I use mine when I haul my Aluma trailer.
I'm presuming your engine temperature didn't get into any dangerous zones?
2020- RT Limited
Chalk White, Can-Am rear passenger armrests, Comfort Seat, Grip puppies, RAM Cup Holders, Providence RAM Mount
FOBO2 TPMS
Aluma MCTXL trailer
BRP hitch
Big Bike Parts wiring harness
Permanent Smile!!!
I am confused. Why would you think that it is a problem to use the cruise control while towing?
2018 F3 LIMITED
Sooo...
Do you use the cruise control when you have a passenger...?? no difference...Relax and enjoy the aftermath of a great trip and be ready for the next...your spyder is....
2012 RS sm5
My biggest concern is that this could cause a DESS failure, and your Winshield Support Arm to break! Also be sure to check your blinker fluid!
This is the only Blinker Fluid that won't void your warranty.
Cruzr Joe
I use my cruise pulling my trailer whenever I can and no issues in over 46,000 miles.
2021 Sea To Sky, 2020 RTL
but our benefits don't?
Cruzr Joe
the only one I use!
Dang, I used ACME Brand XX to fill my blinkers AND my drive belt. Warranty is shot!!
2020- RT Limited
FOBO2 TPMS
Aluma MCTXL trailer
BRP hitch
Permanent Smile!!!
Jim
Did you have it in "trailer mode" ?
That would be a concern.
2013 STL SE5 BLACK CURRANT
SpyderPop's: LED bumpskid
minispyder dash toy
Lid lox
KradelLock
Pakitrack
FLO (Frunk Lid Organizer)
BRP fog lights, trailer hitch
SENA 20S EVO
[QUOTE=Cruzr Joe;1195270]This is the only Blinker Fluid that won't void your warranty.
Is that available at Walmart?
That would not be a concern to me. Trailer Mode just forces higher rpm shift points.
2018 F3 LIMITED
I still don't see the concern since the trailer mode will only cause the bike to downshift earlier. Going down the road in 5th (no trailer mode if you have 6 speeds) it will make no difference. If it downshifts for a hill, that's just standard operation that would require you to upshift once the hill is past and then re-engage the cruise control. The operation would be virtually identical with the cruise control engaged or not engaged.
2020- RT Limited
FOBO2 TPMS
Aluma MCTXL trailer
BRP hitch
Permanent Smile!!!
[QUOTE=5Wheels;1195295]
Only one of them. We could tell you which one but then we'd have to, well, you know the rest!
Trb-- (Roger)
2014 Cognac STL:Ultimate Seat, Nelson Rigg Tail Pack, Nelson Rigg RS/ST Half Cover, TL fender lights, Squared Away Laser Alignment, BajaRon sway bar and links, Akropovic Sport Silencer
2022 White Pearl F3T
Gone but not forgotten: 2019 F3S Special Series Liquid Titanium
Spyder States Visited
Using cruise while towing....
I had read that there was such a thing as trailer mode on the Spyder - I didn't find one on my 2010 RT SM5.... so I just wasn't sure about using the cruise.... I've only been a Spyder Ryder for a short time and this is the first long trip we took towing....
I used Windex to refill my heated grips and Nanny immediately sensed it and alerted BRP. They came out an hour later and hauled off my Spyder.
2015 Sypder RT-S SE6
2016 Polaris Sportsman 570 ATV
2003 F250 SuperDuty
American Saddlebred Horses
Well, I was going to offer an opinion on using cruise control while towing (I do), but this thread seems to have gone haywire.
News to me yes it changes the shift rpm but also the brake balance & few other things im sure. Tighter tolerance for nanny. More for me to learn but for sake of peace on forum, trailer mode is there for a reason cruise control is a combination & a privilege. As i see it pulling trailer improperly (no mode) risk damage & the other does not. IMO
minispyder dash toy
Lid lox
KradelLock
Pakitrack
SENA 20S EVO
