Results 1 to 16 of 16
    Very Active Member armyspydervet's Avatar
    Nov 2015
    Occoquan, VA
    Default How do I lift my Spyder?
    I know it has been discussed on here but I can't find it...or I'm too lazy to look. What is the best (affordable) lift and front jacks to use to lift my Spyder for removing front tires and oil changes. Also, where are the lift and Jack points on an F3-T.
    Thank you all!
    Chris
    2016 F3-T SE6
    Active Member WEB-WVR's Avatar
    Sep 2009
    Albany, Oregon
    I and many have one of these. You can get it at Harbor Freight. They are often on sale and they let me use the 20% off coupon on mine. A little spendy (under $200) but you are lifting an expensive machine.
    Craftsman sells one, a clone of this one, different color.
    If you search this forum.....you will find photos showing where to place it.
    Craig From Albany Oregon
    Sep 2009
    Albany, Oregon
    Here are the location photos and a yellow one.....exact same unit, different brand on it.
    Feb 2012
    Spring City,Utah
    the most affordable is the good old standby floor jack that you have seen in every auto service shop you have ever been in. You can get a suitable one and and a couple of floor stands for under $60. If you don't need/want to remove the wheels just get a couple of ramps, that should be around $25.00. You may already have some of this stuff and if it works on your car it will work on your Spyder.
    I have a simple floor jack that I have used and 2 sets of ramps. I use the jack to raise one side at a time,if it needs to be up for awhile or I am going to be under it I put some big wood logs I saved from one of our wood gathering expeditions,but your local lumber store will have old railroad ties cheap and they will cut them into sections for you,mine did for free. I use the ramps for oil changes,just back the fronts wheels 1/2 way up then jack up the rear and put a ramp under that.
    Long answer to a short question but hopefully you can begin to see the possibilties of what you may already have.
    Happy TRAils/NSD
    Paul
    2012 RT L
    AMA 25 years Life Member
    TRA
    PGR
    Rhino Riders Plate #83
    Venturers #78
    TOI
    Chris,
    It's mot that difficult...
    You find a real strong overhead beam in your house, and buy a block & tackle...
    Default You beat me to it....
    Quote Originally Posted by WEB-WVR View Post
    Was going to post mine but you already did...this one I got at sears on sale. It's a craftman but same design...
    ​2012 RS sm5
    Active Member BamaJohn's Avatar
    Feb 2015
    Talladega County, Alabama
    Default lifting your spyder...
    Quote Originally Posted by armyspydervet View Post
    Thank you all!
    Be sure to bend your knees and NOT lift with only your back......
    JB
    John B.
    Current ride: 2020 Spyder RT-s Petrol Metallic Blue dark with OEM top case
    Quote Originally Posted by xwingnut View Post
    JB
    It also helps to have about a dozen friends on hand... friends from your gym!
    Sep 2009
    Albany, Oregon
    Don't forget, after you jack it up (no matter what you use)....put jack stands under it for safety !!!!
    Nov 2012
    Pueblo Colorado
    Default If you use a floor jack, use a 6X6 square of 1/2 inch OSB or plywood
    Or better yet make a rubber pad to help the metal swivel head grip to the main frame box channel. Metal on metal will slip off at the slightest misalignment. A scrap of rubber tire tread, keeps things secure until you get stands situated!! I recycled a piece of tire tread that was slung off along the road, and trimmed it to size.
    Or the motorcycle jacks are more stable, but obstruct a lot of space depending on what you need to do underneath.
    2015 RT , OEM Black Gloss
    Registered Users Jul0682's Avatar
    Sep 2015
    Ottawa , Ontario
    Hey guys, for u guys who store it in the winter do u lift your spyder to remove weight from the tires or just leave it as is? And if so do u just leave the jack in place with floors Jacks and leave it or is there another way..
    Cheers
    Sent from my SGH-I317M using Tapatalk
    Sep 2009
    Albany, Oregon
    Quote Originally Posted by Jul0682 View Post
    Cheers
    I just leave it..... have not experienced flat spots, I dont think there is that much weight on the tires. I have a show car....much heavier and it does get flat spots. There are flat stop preventers (a ramp cut out for the tire) for cars....not sure the Spyder being so low to the ground could get in and out of them.
    Sep 2015
    Ottawa , Ontario
    Makes alot of sense, thanks
    Oct 2016
    Central Valley, Ca
    Default Lifting and washing
    I saw this video in a youtube. If you scroll to 6:15 you will see how it stands and how to wash the Can Am Spyder.
    Unless you want to compare:
    Nov 2013
    Oro Valley Arizona
    Thank you all!
    Just remember it takes two hands for beginners!
    Jack
    2015 BMW R1200R LC
    2014 RTL SE6 Pearl White
    2012 RT-622 trailer viper red
    2011 Polaris Ranger green
    2016 Can Am Maverick
    Very Active Member bmwlarry's Avatar
    Mar 2012
    Beaverton, Oregon
    I use the J&S jack with the Spyder adapter that was made for the 15 RT. It is truly a very secure and very maneuverable jack while the spyder is lifted. There is even a oil drain pan that goes into the jack that catches the oil from both drain plugs at one time.
    2015 an Am Spyder RT Limited
    2013 Yamaha WR250R - Sold
    2011 Can Am Spyder RT-S SE5 Limited - Sold
    2011 Aspen Sentry Trailer
    2003 BMW K1200LT - Sold
    2007 Unigo Trailer - Sold
    2001 BMW K1200LT - Sold
    2001 Honda 750 NightHawk - sold
    2015 RT Ltd , Canamspyderaccessories Brake pedal ext. Red
