Page 2 of 2 FirstFirst 12
Results 26 to 50 of 50
  1. #26
    Very Active Member JimVonBaden's Avatar
    NoVA
    Quote Originally Posted by Aracknoid View Post
    Jim, I just bought a 2013 ST in Sept. low miles and an extended warranty, great machine. I have changed a few things.e.g., Seat(Ultimate, ebay 1/3 cost of new), front and rear tires. The front tires are Federal and the rear is a Kuhmo. The difference is night and day, runnin 20 psi front and 26 psi in the rear.
    I rode to eastern Tenneesee about 1100 miles, used about 3/4 qt of oil averaged around 35mpg, great ride.
    Items added: BRP fog lights, custom dynamics led package and BRP did the "Good Will" heat deversion, at no costs.
    I am sure you will like the unit.
    Good Luck
    Cool, I'll take a look at those tires.
    My wife is loving it so far, especially as I keep adding farkles. Still on the list are a set of driving lights. I already have the comfort seat, which is very good.
    Thanks,
    Jim
    2013 ST-S (wife's)
    2015 BMW R1200GS (mine)
    1981 Yamaha XS400 Scrambler Custom (mine)
  2. #27
    NoVA
    holy cow ! look at all the stuff hanging , and inside the machine !!! any parts left over ...
    Two screws, but the kit came sith some, so I figure I am good.
    Jim
    2013 ST-S (wife's)
  3. #28
    Sep 2016
    Alma,Arkansas
    Default 2013 ST
    Quote Originally Posted by JimVonBaden View Post
    Thanks,
    Note, if you have not added the heat reducing panels, do it. This is a "Good Will" move on BRP part. The panels make the 2013 look like a 2014. Your dealer can request the panels, time line about two weeks. Costs: $0.00.
    Good Luck
  4. #29
    NoVA
    Good Luck
    Thanks, they have already been done by the PO.
    Jim
    2013 ST-S (wife's)
  5. #30
    NoVA
    Another question. Who sells nose protection for the ST? My wife's leading edge catches the driveway nearly every time. A metal skid plate would solve it. Does anyone make this, or do I need to do it myself?
    Jim
    2013 ST-S (wife's)
  6. #31
    Jun 2014
    Schenevus NY
    Spyderpops (a sponsor here) sells a better bumpskid.
    Trb-- (Roger)
    2022 White Pearl F3T
    Spyder States Visited
  7. #32
    NoVA
    Quote Originally Posted by Trbayth View Post
    Thanks, I didn't see them in the Supporting Vendor section!
    Jim
    2013 ST-S (wife's)
  8. #33
    Nov 2012
    North Las Vegas, NV
    http://spyderpops.com/
    2016 F3 Limited
    2019 Ryker Rally
    2014 Suzuki V Strom 650
    2020 CSC TT 250
  9. #34
    Mar 2013
    Maumelle, AR
    Remember, the bumpskid will lower the front end at least an inch. Try approaching the driveway/road at an angle, both coming and going. This way you won't mess up your new bumpskid.
    2020 RT Limited , Chalk
  10. #35
    NoVA
    Quote Originally Posted by Copperman View Post
    That is one of my fears. I may have to look at a different option, maybe home brewed.
    This is our driveway:
    It doesn't look steep, but my car touches too. As you can see it is on a 4 lane road that has heavy traffic at times, so often you are turning left not only going faster than you might want, but the angle isn't the best.
    Jim
    2013 ST-S (wife's)
  11. #36
    Mar 2013
    Maumelle, AR
    That is one of my fears. I may have to look at a different option, maybe home brewed. It doesn't look steep, but my car touches too. As you can see it is on a 4 lane road that has heavy traffic at times, so often you are turning left not only going faster than you might want, but the angle isn't the best.
    Your driveway is plenty wide to pull in on an angle. It also appears to be wide enough to turn around so you're pulling out in traffic (on an angle). Try it, you'll like it.
  12. #37
    NoVA
    Pulling out is not the problem, pulling in is. If there is no traffic, very rare, it is fine, but usually we have to move quickly while watching our back. It isn't easy living on a busy 4 lane street. There are literally accidents in front of my house every week.
    Anyhow, do you have actual suggestions on protection for the front lip?
    Jim
    2013 ST-S (wife's)
  13. #38
    Active Member greybeard's Avatar
    May 2013
    indianapolis indiana
    Default 2013 sts
    Hey Jim
    I have the same machine. Lots of fun, you definitely need the bajaron swaybar. Will cut down on the wandering from cross winds and semis plus big difference on cornering. Mine didn't run well until after the second computer upgrade. Enjoy
    Paul
  14. #39
    Registered Users lou49's Avatar
    lake mary fl.
    NICE HOUSE!
  15. #40
    NoVA
    Quote Originally Posted by greybeard View Post
    Hey Jim
    Paul
    Hi Paul,
    What computer upgrade are you referring to?
    Thanks,
    Jim
    2013 ST-S (wife's)
  16. #41
    Very Active Member ingramwc's Avatar
    Oct 2008
    Kingsport, TN
    I don't know about an ECM upgrade, I picked my 2013 ST-S up in May 2015. It was new, just a left over, I have not had any dealer shop work done since I picked mine up.
    But, I have no complaints about how my Spyder runs, it runs great!!! Oops, I forgot, I did have the BajaRon sway bar and billet links installed and a laser alignment done at a dealer's shop nearby home. Dealer I purchased from is 105 miles from home, the other one is 35 miles away. Oh, I also had the 2014 vented side panels installed.
    Jim, If your Spyder does not have the BajaRon sway bar and links installed, you may want to consider it. This vastly improves the handling of the Spyder, it feels like a different machine!!! The factory links are plastic, the BajaRon links are billet aluminum, much better!!!!
    Current ride: 2013 Circuit Yellow ST-S SE5
  17. #42
    NoVA
    Quote Originally Posted by ingramwc View Post
    Thanks. I have the Fox adjustable shocks and sway bar. How much better is the Baja Rod Sway bar?
    I do have the updated side panels.
    Jim
    2013 ST-S (wife's)
  18. #43
    Mar 2013
    Maumelle, AR
    [QUOTE=JimVonBaden;1203589 Anyhow, do you have actual suggestions on protection for the front lip?[/QUOTE]
    Other than the bumpskid, no.
  19. #44
    Jul 2013
    Marietta, GA
    Default wear bar
    http://www.bigbikeparts.com/template...9&GroupGuid=78
    might help.. make sure to get correct one for your year spyder
  20. #45
    Sep 2016
    Alma,Arkansas
    Default front protection
    Jim, I have had very good luck with UHMW poly, cheap, easy to work with. Mount the poly under the lip and secure with a couple of small screws,(wood screws work well due to the large thread form). the ploy will move if it is struck with the drive way paving and slide over it. Works for me, does no good if you run intp a parking lot bumpers, don't ask how I know.
    Good Luck
  21. #46
    NoVA
    Good Luck
    Good info. I was thinking something like that. Maybe with some thin SS or Titanium strips as slider attached. Hmmmm, new mod to do !
    Jim
    2013 ST-S (wife's)
  22. #47
    SpyderLovers Sponsor GloRyder's Avatar
    Apr 2009
    FL
    Thanks Derk, how do these turn on? Are they light sensored, assuming the batteries are good?
    Hi Jim,
    Just passing through and did a search and saw your post from October, Did you ever get a solution for your Glo Ryder wheel lights? If not let me know at sales@gloryder.com and we will take care of you
    Will
  23. #48
    NoVA
    Quote Originally Posted by GloRyder View Post
    Hi Jim,
    Will
    Hi Will,
    I found that I need a remote. The original owner is looking for it, but if he doesn't find it I will give you a shout!
    Thanks,
    Jim
    2013 ST-S (wife's)
  24. #49
    Aug 2015
    Cleveland, GA
    Default non-Givi ST panniers?
    Oh, and I ordered a set of panniers for it, not GIVI, so we shall see how they work.
    Would you share what brand panniers you selected and how they're working for you?
    Thanks,
    Pete Tamblyn
    Cleveland, GA
    2020 F3 Limited (black)
    Time Out XL1800 cargo trailer
    2019 Royal Enfield 650 Interceptor
    2018 Kawasaki Versys-X 300
    2013 ST (sold)
    2015 F3-S SOLD
    2014 RT-Limited (cognac) SOLD
  25. #50
    NoVA
    Quote Originally Posted by motoswami View Post
    Thanks,
    Hi Pete, I used these, then made custom mounts. The mounts that come with them work, but are universal mounts. http://www.ebay.com/itm/Detachable-H...19.m1438.l2649
    Jim
    2013 ST-S (wife's)
