DOT HELMET STANDARDS
Occasionally on SL, we'll have questions on helmets... people ask which are the best, etc...
my answer always was, "if it has a DOT sticker on it, it means it meets the gov't standards"...
i no longer think this way after reading various articles such as these:
https://ultimatemotorcycling.com/201...e-22-05-snell/
http://www.bikersrights.com/nhtsa/fmvss218.html
http://silodrome.com/snell-vs-dot-vs...rds-throwdown/
After educating myself, i'll be looking at helmets from a completely different perspective... hope you do too....
SPYD3R
SpyderLovers Sponsor
Thank You
Super good info: everyone who values
their head and what is inside it should
read this.
thanks for posting
MC Dave
Originally Posted by SPYD3R
Hi SPYD3R,
Re: "if it has a DOT sticker on it, it means it meets the gov't standards"...
I spent 30 yrs employed by the US gov't. in contract management. One of my primary functions was enforcing 'gov't standards' and accepting certifications. You get a little numb after awhile.
IMO far too many gov't. agencies accept certifications without any effort whatsoever to determine if they are valid.
Their mindset ( again IMO ) is that if it has a signature it is OK.
Can you spell horsepuckey?
Jerry Baumchen
'I'll never forget what's her name.'
'Things are more like they are now than they ever have been before.' Dwight Eisenhower
2008 GS SE-5
$20.00 helment for a $20.00 head.
If I can't fix it, I will fix it so no one can fix it. Sypder Loco!
Meets Government Standards
Well, most politicians also meet "government standards," so I am not so sure if that is a positive or not.
Seems these days the standards are pretty low.
Spyder3 what did you see that has caused you look at things different, and what are you going to do differently?
Happy TRAils/NSD
Paul
2012 RT L
AMA 25 years Life Member
TRA
PGR
Rhino Riders Plate #83
Venturers #78
TOI
SNELL is the highest standard. Above and beyond DOT. They are an independent testing agency Typically, only full face helmets get both the DOT & SNELL ratings.
2017 Champagne Metallic RT-S SE-6 Rivco Dual Flag Holders; Slingmods Highway Pegs; (Hate Them) Airhawk Seat Cushion; Show Chrome Black Touring Rack w/ Risers & Touring Windshield; RAM X Mount For TXTAG; TackForm Phone Mount; Lidlox; Magic Mirror Mounts; Guardian Bells; WOLO "Bad Boy" Air Horn; Dual USB Power Outlet With Voltmeter; Spyderpops Full View Mirror Turn Signals; Large Brake Pedal; Kott Grilles; Large Mud Flap; BajaRon 3 Piece Sway Bar, Last But Not Least, Kuhmo Rear Rire, Vedrestien Fronts.
ECE surpasses DOT and Snell and is pretty much the standard for bikes. ECE is the only one of the 3 that does abrasion testing.
Keep in mind that just because a helmet isn't Snell rated doesn't mean it wouldn't pass. Snell currently will not pass helmets with internal visors or modular helmets, even if they would physically pass the tests. Many manufacturers forgo Snell testing because due to the cost to test.
http://shorecyclesusa.com/blog/2016/...s-snell-vs-ece
Personally, I worry more about the type of helmet I wear vs the certification (full face vs open face vs 1/2). It's been proven that the cheeks/jaw/facial area is the most common area for damage in a crash.
WHAT
WHAT CAUSED ME....
read the post from DREWNJ which is 2 below yours, Drew has the perfect answer as to why i'm giving way more consideration to helmets....
SPYD3R
Hi DrewNJ,
Re: ECE surpasses DOT and Snell
I am not familiar with ECE, could you provide some more info?
I used to keep up with this stuff, not much so more.
ANSI still has their Z-90 standard: http://standards.globalspec.com/std/437430/ansi-z90-1
ANSI is recognized thoughout the engineering world for all kinds of standards.
Jerry Baumchen
2008 GS SE-5
Originally Posted by JerryB
Hi DrewNJ,
Jerry Baumchen
Here is a good read with a link that has all the regulation 22 info. The actual download reg will surely put you to sleep....[emoji1]
http://billyscrashhelmets.co.uk/ece-...crash-helmets/
Sent from my Nexus 6 using Tapatalk
Here is a pretty good Reddit conversation too. Not technical, but a good discussion none the less...
https://m.reddit.com/r/motorcycles/c...met_overrated/
IMHO, I don't worry so much about the specific certifications. It's hard to go wrong with any modern major manufacturer full face helmet. The key is also that it fits right. [emoji106]
Hi DrewNJ,
Re: Here is a good read
Thanks for the link; I might just spend a night reading all of it.
However, when the article says: They test helmets in a few funky ways under a few even funkier conditions.
they get me to wondering what the real testing is.
Thanks,
Jerry Baumchen
2008 GS SE-5
Bob, did this depiction come with an explanation as to why the two helmets have different numbers? Other than the helmet on the left being smaller, they seem identical. Are we to assume that size alone can create different levels of protection (between identical helmets) among the various areas that they differentiated for evaluation?
2015 Sypder RT-S SE6
2016 Polaris Sportsman 570 ATV
2003 F250 SuperDuty
American Saddlebred Horses
Same helmet, different sides.
Jim
2013 ST-S (wife's)
2015 BMW R1200GS (mine)
1981 Yamaha XS400 Scrambler Custom (mine)
So why the different values? Why would the left side protect differently than the right side?
2003 F250 SuperDuty
This is a depiction of where helmets are impacted during collisions, not where they're test impacted nor the impact resistance. It would be good to know where the data comes from but it looks like the right side takes more hits than the left side. This would kind of make sense if the data is all from right hand highways and so many of the collisions are with cars coming from the right.
I didn't add them up but the total of all the percentages should be right at 100%.
2014 Copper RTS
Harrington, Australia
2021 RT Limited
HeliBars Handlebars
Kenda Kanine rear.
That is not about protection, it is about frequency of impacts by percentage.
Jim
2013 ST-S (wife's)
It came from the Hurt Report.
https://en.wikipedia.org/wiki/Hurt_Report
Jim
2013 ST-S (wife's)
Originally Posted by Peteoz
Bob, that didn't have a frontal view as well, did it? I'm claustrophobic, so I only buy 3/4 helmets, and then only Shoei and Arai that wrap around the jaw further than most. It would be great to see the front chin impact.......not that I would change, of course
Wearing a 3/4 doesn't change the percentages. It just means you are 30-45% less protected based on the impact studies and your helmet configuration.
Jim
2013 ST-S (wife's)
You mentioned that it came from the Hurt Report: how oddly appropriate!
