rapid turn signals
Any help will be appreciated. working on adding the led fender lights from TricLed with the optional turn signal module. since adding the module the signal starts normal & then speeds up. I think there had been a way to "reset" the turn signal that I had read somewhere. thanks "wired"
GOS member (Girls On Spyders)
Turn Signal Reset -- 2014 and Newer
Yes, you can reset the hyperflash as follows (if you have a 2014 or newer machine, I believe) -- instructions from Spyderpops:
- Turn key on and let computer boot up; press mode to get fully up.
- Press and HOLD the hazard flasher button for 35 to 45 seconds
- Release and press again to turn hazards off
- Turn the key off, let the computer shut down (display now dark).
- Turn key on, wait for boot up (push mode if needed).
- Activate the left turn signal and after one blink, turn the key off (display now dark).
- Activate the right turn signal and after one blink, turn the key off (display now dark).
- Turn key back on and test the turn signals ... they should operate normally now.
All the best .... Ann
__________________________________________________ _
2016 RT Limited -- "Jubilee" (as in Cherries)
Guardian Bell (gift from spyderowboy)
ISCI Dual Flag Mount – Tall Poles
Lamonster Bottle Holder and Spyder Cuff
Spyderpops Missing Belt Guard
Spyderpops Bumpskid
Spyderpops Rear Run / Brake / Turn LEDs
Spyderpops Mirror LEDs
Custom Dynamics HMT Brake
Spyderpops Keep Out The Trash (KOTT) Grills
Don't Eat Mud / mudflap
__________________________________________________ __
When I switched to LED turn signals on my Harley they listed a similar procedure that Ann posted to reset the flashers. They also said that you could just ignore the procedure and the bike will learn the new LED s. I didn't go through the procedure listed and everything was reset on the first ride.
This only works if you have a 2014 RT or above.
If you have below, you will need to use resistors to balance the circuit.
Bob
2011 RT-S SM5 - Black
You forgot one important step. You must hop on one foot while doing the above.
2014 RTL-SE6 8,600 miles
2011 RTS-SM5 5,000 miles
2010 RTS-SM5 59,148 miles
2010 RT- 622
I aasume you're referring to dancing a one foot jig?
Tri-Axis Chrome Handlebars
Sena SM10 BT Dongle
Double USB Port/Volt meter
LaMonster Magic Mirrors
BajaRon Swaybar
HALO Skid Plate
Shorty Antenna
LaMonster Cat Delete
Akrapovic Muffler
FOBO2 TPMS
Rear Trunk Rack
Bruce Erickson
Chilliwack, BC
Canada
2014 RTS-SE6 - Cognac
HA HA HA
You are funny Ann! Thanks, I need the humor these days. All the best .... Ann
Spyderpops Bumpskid
rapid turn signals
thanks
Thank you to all whom have responded (especially Spyder-cowgirl). It is a relief for an old school wanna-be mechanic to have this kind of support. It certainly will help me save what brown/white hair I have left. I will wait till I have a few captain morgans & pepsi for the 1 footed jig...P.S. my wife & I both promised no booze on two or three wheels..thanks to all again.
I have a 2016 F3-T and was able to reset my hyperflash by following Ann's steps but I was able to stop after step 4. I did not need to do the rest. Also, lamonster has a YouTube video describing this.
Chris
2016 F3-T SE6
mission accomplished
many thanks to spyder-cowgirl, followed detailed instructions & turn signals are back to normal..thanks to all..
