Results 1 to 25 of 44
    Jan 2013
    lancater ohio
    Default Metal on drain plug
    Just did the second oil change on my 2015 f3 that I bought new 3 months ago. When I did the first oil change there was tons of metal onot the magnetic drain plug. So now that it has 13500 miles time for the second and the same thing. Is anyone seeing this.20161013_180220.jpg
    My engine is a 2014 and the oil changes at 7,359 and 14,100 total miles showed no such particles on the transmission plug magnet. I put Dimple plugs in at the 14K change and am particularly interested to see what will be on the crankcase drain plug at the next change that is due in about 1K.
    Jan 2013
    lancater ohio
    Thank you for the info
    washington state
    Looks bad, there must be something not normal. I hope its just left over dirt but you need to be vigilant. You should let the dealer and show this evidence. Good luck.
    Default METAL ON PLUG
    Quote Originally Posted by greatrides View Post
    I also have a 1330 engine .... first change was at 2200 and had some metal but not as bad as yours..... have done five and not really very noticeable except for that first one. My last three had the Gold plugs....... Mike
    Active Member Michaelscs's Avatar
    Sep 2015
    Cold Spring, MN
    I had the same thing on my two oil changes on my 2015 F3. I don't think it'd out of the ordinary. Is yours a SM6 or SE6? Mine's a SM6.
    2020 RT Limited
    2020 RT Limited , Petrol Blue
    Jan 2013
    lancater ohio
    Quote Originally Posted by Michaelscs View Post
    It's a sm6
    Member Spyder_Ryder's Avatar
    Aug 2016
    Huntsville, AL
    I just recently got my first Spyder it's a 2015 F3-S/SE6 with 1,500 miles does it come standard with a OEM magnetic oil plug?
    Sent from my VS986 using Tapatalk
    Dec 2015
    Galax VA
    Did you open up the filter to see what is in it?
    Sep 2014
    USA
    my first had some metal on the trans plug everything else good ever since. Really see no metal at all on mine
    Mar 2008
    Hesston, PA
    Default Metal on Drain plugs
    Do a search on this...I think Lamont posted something about metal on his F3 drain plugs sometime ago??? larryd
    Invalid Emails
    May 2010
    Chelan, WA .. the dry side!!
    Default Consider getting
    the Dimple plugs...based on my research I found them "cheap" insurance....
    Aug 2012
    Central Coast, CA
    It looks to be very much excessive to me.
    2020 RTL SE6
    Default WELL - MAYBE
    Quote Originally Posted by murphybrown View Post
    Unfortunately there have been a few posts recently of the " DIMPLE " brand plug - - FAILING - - one with catastrophically expensive results ...... from PICS it may be the hole drilled to put the Magnet in is too large and weakens the THREADED wall and it breaks ...... The " GOLD " brand appears to not have this issue . In any case be Very very careful how much Torque you apply to either one ....... If it leaks just tighten a bit more .........JMHO........Mike
    Jan 2013
    lancater ohio
    Quote Originally Posted by Sam Mac View Post
    Not yet but I saved it.
    We're curious to hear what you find in it...
    Jan 2013
    lancater ohio
    I went for a ride today so I will pull the filter apart tomorrow. But I did take a little look at it and I don't see anything.
    Quote Originally Posted by Spyder_Ryder View Post
    According to the BRP parts lists for the 2014 and 2015 1330 engines, the part number for the crankcase drain plug, 420441681, is the same for both engines and there is no magnet in that plug. The only magnet is in the clutch cover, a.k.a. transmission, drain plug. That's one of the reasons why some folks switch to Dimple or Gold Plug brand plugs because there is a magnet in each plug in addition to the plugs having hex heads.
    Jan 2013
    lancater ohio
    Sep 2014
    USA
    Take the bike in for service ASAP
    And take all of this evidence with you...
    Something just ain't right in there!
    Sep 2014
    USA
    way to much metal fragments in the filter and drain magnet
    Mar 2015
    forrest above Reno, Nv
    Question Magnet???
    I agree--- way to much metal. Try a magnet on the metal in the filter. Non magnetic, brass tinted metal may be bearings, Magnetic may be gears.
    Get it to the dealer, PLEASE DON'T LET HIM TELL YOU " THEY ALL DO THAT". Hope BRP honors its warrenty.
    Kaos
    2014 RTS , Circuit Yellow
    Jan 2013
    lancater ohio
    Quote Originally Posted by kaos View Post
    Kaos
    Bought it new not 4 months ago..they will honor the warranty or they can have it back!!
    Jan 2013
    lancater ohio
    Default Update
    Dropped the spyder off at the shop just before Christmas. The shop is 120 miles away so it can be a little cold and snowy in December in Ohio!! I was not going to give up one day of nice weather so that is way I did not take it right in. I gave them the oil filter that I kept and showed them the pictures. The shop was a couple weeks behind so I hope to hear back in a week or so!
