Only hitting on one
I have a 2010 RS and the other day I started my bike and it was only hitting on one cylinder so I thought it was ether plugs or wires so I changed them but still the same thing any thoughts?
Did you check the spark? Sounds like you make have a breakdown in the coil?
Happy TRAils/NSD
Paul
2012 RT L
AMA 25 years Life Member
TRA
PGR
Rhino Riders Plate #83
Venturers #78
TOI
no it has no spark to the back cylinder
Then you have a problem further up the line from wires and plugs.
Happy TRAils/NSD
Paul
2012 RT L
TRA
PGR
Venturers #78
TOI
I already knew that but what else
Coils....
Only thing left is the coil or the power to the coil. After that you have the electronic ignition... if you have or can get a shop manual (on line $20.00) it will show you the steps to track it down...
2012 RS sm5
no fire
my 09 did that and wound up having to replace the plugs and wires
On my '11 RS it was the ECM,it was replaced under BEST($50.)
2015 RT White,Tj's Dash mount,Rivco's Duel Flag Holder,SealsFloorBoards(Pups),Custom Dynamics fender lights(R/W)Bajaron's Swaybar & links,Lamonster's LED headlights,lidlox.Wiredux A-arm driving lights(upper&lower)FOBO TPMS system,Spyerpops lighted bumpskid,Foom handgrips. tobor9@me.com
