Results 1 to 10 of 10
    Very Active Member Firefly's Avatar
    Feb 2009
    Ceresco, Michigan
    Default F3 Frame question...
    Anyone know what they did to fix this issue on the 2016 or 2017 models?
    2015 I know they added the plate near the top of the shock.
    Wondering if they just add the plates from the factory... or did they redesign it?
    Spyder #1 - 2008 GS SM5 Premier Edition #1977. RIP after 80,000 miles.
    Spyder #2 - 2012 RT SM5. Traded in after 24,000 miles.
    Spyder #3 - 2015 F3 SM6. Put 13,000 miles on and sold it.
    Spyder #4 - 2017 F3 SM6. Too good of a deal to pass up!
    Aug 2008
    MA & NH
    From what I heard it was only reinforced, not a redesign. I'm sure you'll get more replies.
    Sep 2014
    Los Angeles
    Just a bracket was added
    Sent from my SM-N910V using Tapatalk
    The bracket...
    Mar 2013
    Oz
    And as far as I know they have brought out the 17 F3 and F3s with the same poor rear shock which bottoms out too easily, arguably - along with maybe a weld issue - a cause of the frame issue.
    It would not have cost too much to have the two-up shock as standard - a cheap way to gain happy customers, a good reputation, and more sales for BRP.
    my husbands F3S, soon to be mine, needed the two up shock just for him at 95kg weight. Very poor, BRP.
    May 2012
    sussex, nj and tug hill, ny (west turin)
    Quote Originally Posted by loisk View Post
    2016 and 2017 t and limited has a new swing arm. along with that, a new shock was added in 2016 and yet another upgrade in 2017 spring models from what I understand!
    Very Active Member bscrive's Avatar
    Nov 2012
    Ottawa, Ontario
    from what I understand the new f3t and F3 limited have the RT swing arm but the original F3 still has the same frame as the 2015. I imagine they added the extra plate at the factory.
    Default FRAME
    Quote Originally Posted by bscrive View Post
    The swing arms both styles fit ALL the F-3's. So they are interchangeable and retro-fittable, as I understand it ......Mike
    Mar 2013
    Oz
    Yep I know the T and Ltd have better frame and rear air shock, my point was that BRP have persisted with the substandard shock on f3 and f3s.
    The whole back end on the T is different.
    Its not the swing arm which is cracking so swapping would not solve this.
    We have the bracket and two up shock on f3s, just hoping we didn't have to do the same on the new Daytona . Looks like we do.
    Active Member HIspyder's Avatar
    Sep 2014
    Kauai (The Garden Isle), Hawaii - USA
    Quote Originally Posted by Firefly View Post
    If you look at the parts diagram of the frame you can see the 2016/17 F3, F3-S has been beefed up where the rear sub frame bolts onto the rear of the main frame.
    Just another crappy day in Paradise....Aloha!
